Question about Pinnacle VIDEO CAPTURE| PCTV PRO (PCTVPRO)
Capturing video While capturing video by pressing record button on pctv remote, application stops displying message that pctv vission main programme has encountered a problenm hence it needs to close. please suggest solution.
    Novelist:
  • 231 Answers
Hi I think you have a corrupt driver file. the best way to fix something like that is to delete the driver and then reinstall it fresh, this should cure your problem. Goodluck Regards Mistyman
Posted on Aug 06, 2007
SOURCE:
How do I record a series on my new Bush recorder, which button on the remode control is it?
Usually to record a series the epg, electronic programme guide, needs to be open. Find the programme you want to record and highlight it using the navigation buttons on the remote.
Pressing the record button at this point will set the system to record the programme but if it is a series a window should open asking if you want to record the series.
There are usually two buttons coloured red. One red button will be in a line-up of four coloured buttons. The record button is generally the other one.
Apr 28, 2018 | Bush Televison & Video
Need manual for toshiba D-vr 610 recorder
For VHS -> DVD dubbing, make sure that you put in a compatible writable DVD with enough space for the video. For dubbing a DVD to VHS, make sure that you have a VHS tape with the erase protection tab on the tape. Insert the blank media in the correct side and the media that you want to record in the other. Press Setup on the remote, then select the General Settings menu. Then select Recording and finally Dubbing. (Use the up/down arrows to navigate the menus and press Enter to select an option.) Select the type of dubbing that you want to do. Press Setup to exit. Then press the DVD or VCR button (with the item to record) and press play and pause when you reach the point that you want to start the recording. Then press the other device button and press the Dubbing button (on the remote or the unit). Press Stop when done recording the selection.
Note: copy-protected videos can't be dubbed.
Crutchfield and Toshiba both have the manual for the DVR-610 . Crutchfield has the manual here: http://a248.e.akamai.net/pix.crutchfield.com/Manuals/052/052DVR610.PDF . See page 49 for a set of screen captures of the steps for duplicating a video.
I hope this helps.
Jan 20, 2012 | Televison & Video
How do you make recordings on your motorola L6 (record things)
Hello there,
To make recordings on your phone is quite simple. All you need to do is to go to the phones menu, select multimedia, then in the multimedia list you will see recording, then you select it, you can either make video recording or audio recording.
When you are ready just select the record button.
Shortcut to recording a vidoe, just open the camera from the menu, then you select option and select video recording, it will bring out the record option and from there you can record the video you are willing to make.
'''''Thank you for using fixya
Caseytech
Jul 06, 2011 | Motorola Mobility L6 Cellular Phone
When ever I use my Pinnacle Instant DvD Recorder program the video and audio desync when I try to capture video from my T.V. My video capture device is a Dazzle 100. I use Vista 32 bit, and my computer is...
Common problem with their software (its junk).
Try using Corel Video Studio to run the card - they have a free 30 day trail download. Their package is about the best that I have seen so far.
Apr 07, 2010 | Pinnacle VIDEO CAPTURE| PCTV PRO (PCTVPRO)
Pctv hardware failed to initialized
contact pinnacle as it is a driver conflict and download uniblue driver scanner from http://www.liutilities.com/products/driverscanner/
Jan 11, 2009 | Pinnacle VIDEO CAPTURE| PCTV PRO (PCTVPRO)
Pctv hardware initialization failed
first unistall the software. and then remove the hardware device and re insert the slot again. after that install the software. If any other doubt please come to gmail chat at salnazi@gmail.com
Jul 03, 2008 | Pinnacle VIDEO CAPTURE| PCTV PRO (PCTVPRO)
PCTV 50i
Your PCTV card has got S-Video input. Just connect the S-video output of the Tata sky box if available or use a RCA to S-video adapter to input the video to the tuner card. Now for audio u can connect it to line in of PC. To watch or Record, just select the input as S-Video in the channel selection in PCTV application
Naveen
naveen.karuthedath@gmail.com
Dec 28, 2007 | Pinnacle VIDEO CAPTURE| PCTV PRO (PCTVPRO)
S-video on pc
the audio gets plugged into the sound card (or on-board sound system) audio input jack.
Aug 05, 2007 | Pinnacle VIDEO CAPTURE| PCTV PRO (PCTVPRO)
Capturing video & audio through s-video input .
Hi, try this, go to control panel-click sound and audio devices and ensure that your system is configured to the right devices for recording from your camera. The easiest way to run any of this equipment is to set all systems at default. and purchase a USB sound/video adaptor [cheap from china] and plug your camera into this when you wish to record from it. when finished, remove the adaptor the same as you would with any USB hot swap device, your computer will revert to the default settings. Next time you use your camera , plug it in and windows will auto detect it again. Goodluck. mistyman
No Sound when Capturing
ah. This happens to me sometimes. Well, for some reason it always works when i first open USB streaming tool( this program is not for recording)use the program to edit the video, like to fix brightness etc. Then open capturing tool. This is what you use to capture the video to your computer. What i do is to press the play button in the program, not the capture button. The video on the camcorder and the video on your screen should start playing. I do this just to test the video if its gonna have sound or not. Then you rewind the video by pressing the rewind button in the program. After that press the capture button. Sometimes it records and you don't hear the sound on the computer, I'm not sure but maybe after its captured into the computer, the video will have sound. If you do record, but with no sound, record about a minute and then stop it. Go to where you saved the video and check if there is any sound. Hope this helps you. Sorry if it's kinda confusing because i don' use the program no more. I use a DVD recorder which you connect your camcorder to the DVD player and it burns the video directly to a DVD. Its much mroe easier but you can't play around with it on the computer.
Jan 12, 2007 | Sony Handycam DCR-HC32 Mini DV Digital...
Pinnacle VIDEO CAPTURE| PCTV PRO (PCTVPRO) Logo
60 people viewed this question
Top Pinnacle Televison & Video Experts
Mark Klabunde
Level 1 Expert
Daniel Dollive
Daniel Dollive
Greg Ulan
Are you a Pinnacle Televison and Video Expert? Answer questions, earn points and help others
