Question about Dell 924 All-in-One InkJet Printer
Ink replacement When I try to print it is telling me I have to order ink but the cartidges are more than 75% full. Obviously they want me to order ink through them. So i did. Is there a way to overide the fact that it won't let me print. Error message says cartridge is icompatable. They were supplied by Dell
  • 57 Answers
Call Dell Tech support & let them work on the issue, it might be an issue with the software provided with the printer. Try to update the printer drivers, or better do not install the CD that came with the printer, just install the printer driver only.
Posted on Aug 06, 2007
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Will the cartidge box move if cartridges are empty?
For your information obviously the cartridges will move while you turn on the printer or give a print job if the cartridges are full or empty, but it will not print and will show a massage that "cartridge are empty" or "Ink level is too low". If there is any stuck on the way of movement then the cartridge will not move.
Apr 26, 2011 | Canon PIXMA IP5200 InkJet Photo Printer
Hy everyone.I've got a problem.I am having canon pixma MP190 and when i click "Print" the printer shows "The following ink cartidge cannot be recognized : Color".Please i need help !
antonyo,
is there an error code, i know with cannon it has to be there cartidges or you will get and error code( as in a #) now i also remember that on a canon both cartidges have to be in machine and in the correct slots and in a tight position. try hitting ok on printer and see if it prints even though you get an error message that would tell me it is bypassing the ink cartidge and then if i were you go back through the steps i the manual for replaceing an empty cartridge with a new one .
hope it helped
Sep 29, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Printer wont print
Try remove all cartridges then put back it one by one.Make sure the color cartridges are not empty too.The printer need all cartridges not empty to initialized and working.
Nov 25, 2009 | Brother MFC 490cw Color Inkjet...
After putting in black ink cartridge in and charging it wont work
in Epson MFP u have to replace all 4 cartridge to print..even if u want to ptint only black and white...
Jan 10, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Hp 7310 all in one
First check that printer is not set to print B&W. Open an application to print a page, for example Word. Chose print command from the file menu on top bar , the print window will open.
In the print window press the 'properties' button, and check tha printer is set for color printing.t
Once you are sure printer settings are not in B&W, read the following.
Even if it shows color at 75, the printer color level may had not been reset since the cartridge had been replaced, in this case the cartridge may be empty.
If the cartridge is not empty it still can be faulty (eg. ink insid is dry).
In either case replace color cartridge with new original one.
If after you replace the cartridge it still does not print colors, then color head is faulty, at this point consider having the printer repaired by a technician.
Jul 22, 2008 | HP Officejet 7310 All-In-One Printer
Canon MP170 printer
I HAD THE SAME PROBLEM WITH THIS SAME PRINTER THE ANSWER IS THE INK OVER FLOW SPONGE IN SIDE THE PRINTER IS MOST LIKELY FULL NEED TO BE CLEANED OUT
Jul 02, 2008 | Canon PIXMA MP160 All-In-One InkJet...
MP530 will coply but won't print
sir,
Try to replace the cartidge maybe your cartidge is not fit to work properly and also the ink is not compatible with your printer
then after you replace the cartridge do the nozzle cleaning until its ok.
yours,
alecz
Apr 23, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Ink cartidges practically full but printer says they need replacing
Sometime the ink dry if you do not use it.....Try this :
Put warm water on a soft clothe and gently press the clothe with the printhead you'll suppose to see ink on your clothe. That's the better way to clean a printhead.
DO NOT SCRATCH THE PRINTHEAD WITH YOUR CLOTHE..
Mar 26, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Dell 924 All-in-One InkJet Printer Logo
27 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
