ALTEC LANSING SPEAKERS ACS41 POWER CORD MISSING
WHAT IS THE VOLTAGE THE ALTEC LANSING ACS41 USE?
  • 277 Answers
SOURCE: Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Posted on Mar 21, 2006
SOURCE: Finding replacement Power Supply for Altec Lansing
I did the same! Thanks for suggesting a call to Customer Support (800)258+3288. The guy didn't seem overly pleased to help, but he did promise to send me a new power supply. Also, he said that they don't make the iM7 anymore, but I had already found out that the iM9 uses the same power supply. I, too, will wait and see.
Posted on Jul 07, 2008
toddg
  • 171 Answers
SOURCE: Compaq Presario v2000 ALTEC LANSING speakers not working
Go to "Start", "Control Panel", Administrative Tools, Computer Management, click on "Device Manager" on the left hand side and look on the right hand side. See if you have a yellow exclamation next to the "Sounds, Video and Game Controllers". If yes, double-click on the line with the exclamation and then click on the driver tab at the top. Click update driver and when it asks if you would like to to check the internet for updated drivers, tell it yes, this time only and continue. After this process, it should either download and install a new driver for your sound card or install the one that was shipped with your computer. If this does not work, please let me know and we will check the next possible problem.
Please remember to rate this solution.
Posted on Sep 24, 2008
  • 4 Answers
SOURCE: What's the volt & amps of Altec Lansing AVS300 2.1 speaker system
Your adapter is Part No. AVX300-A6859, Model No. 9701-00748-IUND.
Or You could get a universal that is rated for output of 18volt DC, 650ma, Center Positive.
I have used a 15volt DC, 900 ma with no problem, but I never run the volume high.
Good Luck
Posted on Dec 04, 2008
SOURCE: Altec Lansing ada745
I work for a charity that had one of these donated today and as I was looking for a new sub for my cinema system I purchased it. I have no other speakers with it and no way of switching or varying the volume. I opened up the back of the sub and slid the board partly out exposing the PCB.
[IMG]http://i134.photobucket.com/albums/q116/mm0dxc/PICT3734.jpg[/IMG]
You'll see 3 solder connections behind the scre in an "L" configuration. One of them is common, one volume and one power on. As I don't need volume, I'm happy with it being on full as my cinema system will vary the input, I joined all 3 together giving power on and full volume. It is working great now.
[IMG]http://i134.photobucket.com/albums/q116/mm0dxc/PICT3737.jpg[/IMG]
For you guys with volume controls, I would suggest shorting out the two rightmost pins in the "L" and I recon this will power it up and try varying your volume control. I recon it'll work just great.
Good luck
Posted on Jan 22, 2009
How can I splice Altec Lansing amplified speaker system 221 to ac power supply cord instead of the computer cord
Not a good idea. The receptacle that the computer cord plugs into has EMI filters in it. Bypassing it would cause an AC hum that you'd never be able to get rid of.
Sep 16, 2016 | Altec Lansing Audio Players & Recorders
How can my laptop charger fit to computer speaker?
Please do not modify your laptop charger to power your speakers. The laptop charger probably has too high a voltage and amperage output. (USB chargers don't provide a large enough output.) The Altec Lansing ACS40 speakers need a 15V 900 mA power transformer; the coaxial power connector has the positive voltage on the center pin. The model number on the transformer is 4815090R3CT . This is available through Amazon.com and other vendors. One vendor is http://www.emtcompany.com/altec-lansing-4815090r3cac-power-supply-charger-adapter/1010666.html .
I hope this helps.
Jun 03, 2014 | Altec Lansing Audio Players & Recorders
How to connect ACS41 speakers to computer
The Right an Left wires are color coded. Place the proper colored wire into the corresponding port on the computer speaker/sound section.
Dec 12, 2013 | Altec Lansing Audio Players & Recorders
I have XA3021 altec lansing but the power cable missing. Anybody can help me to get a new one?
Hello
Its original line chord is of polorized plug type. You can use any type of power chord. Choose the best quality, and compactability to your Altec Lansings' AC socket. That is all. The line voltage and frequency will differ according to your native place. If you are from US/Canada or other Latin American countries, the supply voltage will be 120AC;60HZ and for Europe and United kngdom it will be 230AC;50Hz. This is the only difference, and it will not effect the used power chord at all. OK.
Mar 28, 2011 | Altec Lansing XA3021 Computer Speakers
Lost cord!
I have them for sale AC Adapter For Altec Lansing speakers inMotion iM600.Price is $15.95 Plus $6.95 shipping . send me your email and address to this email address.princemonac0@yahoo.com and I will invoice you through paypal. Thanks
Mar 25, 2009 | Altec Lansing Inmotion-IM600...
Altec Lansing computer speakers , power requirements
You have to find out what the speakers are rated at then go form there. There is usually a placard or sticker on the back that says what watts and voltage they are rated at. Then you have to find out what plug goes in. Or you just buy an OEM plug
Dec 06, 2008 | Altec Lansing Multimedia Computer Speakers
I'vebeen given an Altec Lansing Spealer system, AVS500, for a computer, but it is missing a power supply; 18 volts DC and 1 amp. Altec Lansing no longer make that series or its components Any...
lost instructions on how to hook up. Large speaker makes static. Right speakers work great.
All colors match but can not find the proper jack for the black wire coming out of large speaker
I suspect this is the problem
Oct 17, 2008 | Altec Lansing AVS 500 Computer Speakers
Where do I plug up the altec Lansing acs41 speakers to a new Dell computer
try to plug it at the back of the computer you will see there the outlet for the speaker , it has 3 color, pink for the mic, green for the speaker , hook up the green input cable from your altec lansing to the green outlet of the PC then plug the speaker to the power and there you go h\you have your speaker running
Jul 22, 2008 | Computers & Internet
53 people viewed this question
 Grubhead
Grubhead
