Question about Compaq CV 7500 (Carbon, Silver) 17 in.CRT Conventional Monitor
Monitor Menu I have a problem with the monitor screen menu popping up. How do I prevent this situation from reacurring.
  • 98 Answers
Check if the Menu button is not stuck or malfunctioning.
Posted on Aug 05, 2007
SOURCE:
Pc monitor "menu" pops up on screen
Probably got over zealous with your cleaning liquid and it has destroyed the key pad behind.
Apr 08, 2017 | Computers & Internet
Osd menu popping up ..how do I stop it
just to make sure we are talking about the same thing, when talking about the OSD (on-screen display) that normally refers to the monitor only, such as the menu to adjust horizontal positioning, or the mode (digital or analog) setting. Is that what you are talking about? If so, what does it say?<br /> <br /> Did this just start? Have you recently changed resolution settings? I note in your manual the following warning:<br /> <blockquote><font color="Navy">The On Screen Display manager also features pop-up<br /> warning messages for certain situations, such as if you<br /> attempt to set the monitor resolution outside the<br /> recommended range.</font></blockquote>It also says:<blockquote>Your monitor is optimized for 1024 X 768 @ 60 Hz. </blockquote>Are all cable connections secure?<br /><br />And if you right click on the Desktop &gt; Properties &gt; Settings, what is the resolution set to? 1024x768 it will be ok<br />
Aug 30, 2010 | HP Pavilion F1503 15" LCD Flat Panel...
My auto configuration menu on the monitor keeps popping up and cannot get it to stop what can I do?
auto configuration menu stays on monitor screen constantly while trying to use pc for normaluse.
May 20, 2010 | HP Pavilion F1503 15" LCD Flat Panel...
Crt monitor turned orange and the monitor menu keeps popping up
probably its old or try to check the color status in display property in desktop properties
Apr 21, 2010 | SAMTRON 55V 15" CRT Monitor
My volume menu from monitor pops up, volume auto-decreases
Was something spilled on the volume key? Sounds like it is stuck... you can use a fine toothpick and plain water to "scrub" around the key, there may be some buildup that inhitbits the key from "unpressing".
Hope this helps!
-- RT
Sep 02, 2009 | HP w2207 Monitor
Pop up menue from monitor interferes with my
it sounds like the menu button on the monitor is jammed or damaged. try cleaning it carefully with a can of air duster.
Apr 25, 2009 | Computers & Internet
Volume pop up in the middle of my screen
no photos of said window presented? i cant see them?
must be OSD? the monitor brain on screen display (menu)?
even with the DVI cable pulled?
only a monitor stated, w1907, no PC
some monitors have button lock
read the manual ?oops HP deleted it...
it tells you to push the menu key on the monitor for 10 seconds
and it unlocks. (4 buttons right side left button is MENU)
doom?
that power deal sounds super bad, like the power supply is bad.
if the monitor fails by its self not plugged it to a PC
then the monitors is bad.
try a reset on it? ( power off for 1hr, or off then plug in with power button held? or power on with menu held (wild guesses but common practice)
ok found your manual page 4-8 shows menu page advanced
list line in list factory reset.
but if the keys are dead, and power lamp failing
the power supply is no good or worse. worse is always possible.
and expensive
ever see the support page, read the guides
https://support.hp.com/us-en/product/HP-w1907-19-inch-Widescreen-LCD-Monitor/3709665/model/3709666
its over 10 years old now. 2007?
walmart has larger one for $50
cheaper that parts or repair this.... vastly
Jul 27, 2017 | HP w1907 LCD Monitor
LCD Main MEnu
hi,
It is possible that menu button on the monitor is stuck. I suggest to call your computer manufacturer where you purchased the monitor, check for the warranty and request for a replacement.
Keep me posted.
Thanks
Dec 03, 2008 | Dell E173FP 17" LCD Monitor
Pop up menu won't go away.
If you can do the factory reset in the pop up menu, try it. You might have to try with another power supply, cord, or computer and check where the problem is.
Mar 16, 2008 | Sony SDM-HS95P/S (Silver) 19" LCD Monitor
HP flatscreen not powering up
1 situation - No leds? No menu on screen?
Take it to a service provider for repair.
2 situation - Leds on, menu on screen.
No video in your computer. Ask help for your computer.
Dec 17, 2007 | HP Pavilion F1703 17" LCD Monitor
Open Questions:
update aol password on computer @{18OO~8O31O69} phone number There are two circumstances that can cause someone to want to change his/her AOL password: 1 forgetting the AOL password and needing to recover it and 2 to change the AOL password. The latter can be because the AOL password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's AOL password at least once in a month. Contact Aol Mail Password Reset 1-8OO-8O3-IO69 . For your convenience to contact Aol Mail Password Reset We have provided all possible information of Aol Mail Password Reset. You can contact Aol Mail Password Reset on the given phone number 1-8OO-8O3-IO69. Changing an AOL Password The following steps show in detail how to change an AOL password when the current password is known: Sign into the AOL Mail Account from AOL Do you want to recover/reset your AOL email password? So you'll be do the some steps to recover your AOL password. We'll help you to fix your problem and we'll guiding the some steps to recover your AOL password. Follow and do the below steps to recover your AOL email password- Go to the AOL - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your AOL mail message on your Gmail account. AOL is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While AOL's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, AOL has made it easy to recover or reset your account's password. *Please Read* If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your AOL password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your AOL password.
Oct 21, 2019 | AOL Computers & Internet
See all Compaq CV 7500 (Carbon, Silver) 17 in.CRT Questions
Compaq CV 7500 (Carbon, Silver) 17 in.CRT Conventional Monitor Logo
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
