Califone 1420k tone arm skipping/jumping across record
Califone 1420K Record Player arm skipping or jumping across records. Doesn't look like is a weight control...any suggestions?
djproaudio
  • 515 Answers
SOURCE: Tone arm won't drop
This is a tough one. There is usually a series of gears that function in unison to make all the magic happens. These gears are usually set in motion by a smaller belt located inside the unit. If this belt has come off or is damaged, your unit will not work. Or, if the gears have cracked, or dried up, same issue.
Suggest taking it to a service center for repair.
- OPTiC
Turntable Technician
www.1200s.com
Posted on Sep 08, 2008
djproaudio
  • 515 Answers
SOURCE: Tone arm skipping/not moving on especially at end of record
The issue is with your tonearm, and not your tracking. You probably have slight damage to the tonearm bearings, which will cause this. There are 2 options... you can try to adjust the pivoting screw at the top of the tonearm ... However, WE DO NOT RECOMMEND THIS, because once you mess with this screw, it's EXTREMELY difficult to get it back to the correct setting, as this screw is machine calibrated at the factory. So, we only recommend this when you have no other choice, or it's an emergency (the middle of a set).
You can view a video on how to do this, by going here - http://djprolab.com
Eventually, your going to have to have your Technics Tonearm replaced. This should be done by a professional, as it is not an easy replacement.
- OPTiC
The Technics Expert
Technics Repair
DJ Equipment
Posted on Dec 30, 2008
SOURCE: fisher price 1978 record player
The Fisher Price record player has a device that prevented kids from pressing the needle down and sctratching the record. If you look at the cartridge where the needle is inserted, you will see that it floats up and down. The problem is that this keeps the needle from having enough pressure to play the record. Pennies just make the cartridge recede further into the arm. If you wedge something above the cartridge, the needle won't float and the it will play your records. I've had four of these and none of them worked until I figured this out.
Posted on Jun 16, 2009
  • 3 Answers
SOURCE: Califone 1420 k "Wobbling sound"
If you take the platter off you may find a rubber "idler wheel" that rides on the inside rim of the platter. It may be worn or glazed over and hardened. Might try cleaning with denatured alcohol. If that doesnt work you may need a new idler wheel. West Tech Services is a place that comes to mind that may carry what you need.
Posted on Aug 09, 2009
djproaudio
  • 515 Answers
SOURCE: the stylus skips across the record, despite
If your needle skips across the record, then there is only 1 thing wrong with it... it's broken, and needs to be replaced.
If after you've replaced the stylus, and problem persists, then you have something a little more serious... Tonearm damage. More than likely not, but just in case replace the stylus does not help.
- OPTiC
Master Tech
Digital Analog Therapy
Technics Repair : Technics Turntable Parts
Posted on Aug 30, 2009
THE TONE ARM ON MY ROCKOLA 459 SLIDES OVER THE RECORD WITHOUT PLAYING.
Hi
It sounds as if the tone arm has become unbalanced. Make sure the turntable is on a firm flat horizontal surface and at the opposite end of the arm from the needle there will be a weight and a means of altering the position of weight on the tone arm. This weight keeps the needle on the record but only lightly when positioned correctly. If positioned too far from the pivot post the needle will as you have experience skip virtually straight across the record. You need to adjust the weight so that the needle just sits in the groove and plays without being too heavy. It is best to use a record you are not too worried about for this testing as the test record can sometimes get scratched.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 11, 2014 | Audio Players & Recorders
Platter not spinning
Some turntables only move when you move the arm to the record. If that doesn't work and you have read the set up instructions correctly, as it's new contact the maker or the place you purchased it from. I'm certain they will help.
Mar 22, 2014 | Califone International Audio Players &...
Needle skips across record
your tone arm needs rebalancing most likely
Mar 19, 2014 | Sony PS-LX250H Turntable
I have a califone 1430k record player, and the arm is loose. It looks like the spring must have come loose. It is still attached by wires, but nothing else. If I take it apart, do you think I could fi
The arm should have a pin through it that secures it to the bracket that is attached to the arm bearing. There should be a long spring that is used to adjust the tracking force and it is underneath the arm.
The arm can be taken off by taking the player apart, unsoldering the wires from the arm and unscrewing the nut on the turntable bearing.
Because the arm mounts to a soft rubber grommet it should feel a little loose.
Hope this helps.
Jan 16, 2014 | Califone International Audio Players &...
Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Nov 09, 2011 | Crosley 0187SST Turntable
I have an old Califone 1400 all records skip new needle
There's not enough pressure to keep the stylus down in the grooves. Increase the weight (on the end of the arm).
Feb 10, 2010 | Audio Players & Recorders
Mar 05, 2009 | Califone International 1030AV Turntable
Tone Arm skips past first song
Hello, A. Do not try to close the case when there is a record inside!! The fact that the turntable cannot do this is not a design flaw--you'll be hard pressed to find a portable turntable that can close with a record inside because if you were to pick up the player with one inside, it could easily slip off of the spindle and scratch against the sides of the player.
B. Are you using the cueing lever to lift the tone arm before you place it on the record? Read the instructions to see where the cuing lever is (it's a little switch on the right side of the tone arm). When you lift it, the tone arm will lift up and allow you to position it wherever you want on a record, then you depress the lever to make the tone arm touch the record and being playing.
I hope that helps!
Jan 04, 2009 | Crosley CR249TA Turntable
Arm does not track properly but skips across records
Just guessing, but it sounds like you haven't counterbalanced your tone arm.  When a tone arm skips, it's usually because there's too much counter weight on the rear of the tone arm.  You want between 3-5 grams, but first you have to calibrate your tone arm (balance it so you know where zero is).  If you don't know how to do this, refer to the Ion directions called "Tonearm Setup" in the instructions.
Jan 03, 2009 | ION Audio iTTUSB Turntable
Open Questions:
93 people viewed this question
 Grubhead
Grubhead
