Comfort zone heater
Model WW-15073DO It is showing AO5
3 Suggested Answers
micromatikal
  • 2777 Answers
SOURCE: I have an AO5 error
This indicates a power fault inside the actual heater. Have you tried unplugging the heater, letting it sit for a good 2 minutes, and replugging it back in? If the problem persists you will unfortunately need a repair. Please let me know if you need more information on this. You can also contact comfort zone, the manufacturer, located in Canada, at 780-420-6572.
Thanks so much for the question,
Tim
Posted on Sep 09, 2010
emissionwiz
  • 78238 Answers
what is A05
Posted on Sep 10, 2010
Have a comfort zone inferred heater that the display comes on but won't heat up. When I try and turn up temperature I get a AO5 code. What does this mean?
Make sure the unit is clean. Especially, the blower wheel. If that doesn't resolve your error code then follow these instructions.
http://screencast.com/t/RoXS239ndAhF
Look that over please, you can clean the blower wheel at the red arrow, jumper the two switches at the blue arrows as *brief tests only* just to see if the unit runs and begins to heat with the jumpers in place.
If it runs, replace the item that failed open.
If it does not run, the control module, Item 5 marked with green is most likely bad and needs to be replaced.
Jan 20, 2017 | Comfort Zone Heating & Cooling
My comfort zone infrared heater wont work. It shows coFL
You did not post the model number but from the error message it could be the intake filter is dirty. They have a lifetime filter but it has to be cleaned occasionally
Nov 20, 2016 | Comfort Zone Heating & Cooling
A05 on screen. Will not let me change temperature. Will not come on.
turn on heater ao5 comes on hit temp switch clicks but goes back and forth from ao5 to temp degree is it the printed circuit board please email at archieholdsworth@yahoo.com
Jan 08, 2016 | Comfort Zone CZ1500WC Infra-Red...
How do I reset my Comfort Zone Heater Model CZ20118
no sign of power ===main power line or power switch may be defective,,,if u want to reset===power offf main power & wait for tan minutes
Feb 20, 2015 | Comfort Zone Heating & Cooling
Error code AOS
its show flashing AO5 code and than shut off
Nov 18, 2013 | Comfort Zone CZ1500WC Infra-Red...
Flashing AO5
if the relays are clicking there are 2 1000uf capacitors on the main board that will be bad. If you know how to work on electronics you can unsolder and then replace them problem solved I just fixed my dads heater today cost about 2.00 bucks :). The capacitors have to be 1000uf 105c google them.
Jan 04, 2013 | Comfort Zone CZ1500WC Infra-Red...
I have a Comfort Zone CZ1500W showing an AO5 error code. I have 9 ohms across each element. The fan thermostat reads open. When I bypass it the fan runs, but no heat. The element thermostat reads
Everytime I turn on the CZ heater, the display reads A05 and then it goes away when i set the temp. As far as I can see and feel, I'm not experiencing any issues with the heating, fan, or thermostat or the extension cord running hot. I'm concerned that something could be wrong or unsafe, with Comfort Zone filing for Chapter 7, anyone know who is offering support or a number I can contact?
Dec 02, 2011 | Comfort Zone CZ1500WC Infra-Red...
My comfort zone infrared hearter has a display message of A05 and will not run, what does that mean? How can I fix it?
Hi. I have the Comfort zone 1500 (cz 1500) and just ran into this AO5 problem. Turns out the thermostat was set lower than the actual room temperature. I just turned up the heater temp and it kicked right on. Hope this helps!
Nov 16, 2010 | Comfort Zone Heating & Cooling
My Comfort Zone Infrared heater by Earthwise is showing two different faults on the display, ao5 and doFL, what do they mean?
this means if it does not reset by pushing up,down,enter and clears and no heat then the main control board is shot i have 2 in my shop and the capacitors have popped
Oct 30, 2010 | Heating & Cooling
Comfort zone infrared heater
Hello all , just push and hold the two buttons on the right for 3 seconds and it will reset. Joe
Oct 03, 2008 | Comfort Zone Heating & Cooling
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
