Question about Home Theater Direct HTD Level FOUR Main Speakers plus Stands, Black Piano (pair) Speaker
Intermittent sound issue with HT=PT1200
My home theatre system works fine one time; then the next it is sound free. Nothing changes wires are all secure. When it stops working - everyhing stops - DVD, CDs computer - absoluteley everything - not a peep. The CD unit looks notmal, the tracks cound up and the remote can be used to adjst the volume level on the unit - but no sound comes out. Any ideas? After switching everhing off, it sometimes starts to work again, and then sometimes it doesn't. No apparenet reason why.
  • Anonymous Jan 22, 2009
    same problem
Cant hear my digital tv through my home cinema speakers
http://www.dummies.com/how-to/content/how-to-connect-an-hdtv-to-your-sound-system-or-home-theater.html
Matthew, I found this link which covers the basic possibilities for connections. It has a video backed up by the text version as well. Hope it helps.
Dec 07, 2013 | Samsung HT-X200 Theater System
I have a sony home theatre system ht-ddw5000. the bd channel display says unlock, how do you unlock it
did you find a fix with that problem as i have the same issue when connecting Blue ray into BD port with HD cable! is the unit not able to handle sound and video on the bd port?
Dec 17, 2012 | Sony HT-DDW740 System
How can I connect my PS3 to the HT BD2 and get it to play dolby digital or dts audio? Thanks
Use an optical cable and then it should work just fine. Just saw Avatar from my PS3 through the Samsung HT-BD2 and the sound was excellent.
So go and buy an optical cable :)
My problem is to get the BD2 to download updates. It doesn´t seem to work for me.
Apr 12, 2010 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Samsung home theatre system HT-TZ422 - rear speakers don't work
I bought the system samsung HT-TZ 422 but wireless receiver module is not connected spikers or not riding tx card.Sound test system is show all spikers but from wireless module is not hiring.When can i get any hepl.
Thanks.
Marek.
Mar 01, 2010 | Samsung Audio Players & Recorders
Gurus, I just bought Samsung Home Theater System which i connected to my Hitachi TV with HDMI cable. I have a Optical Cable going from HT to my TV Optical port. I have another connection from my cable
On the remote control for the Samsung Home Theater System look at the bottom left to a button that says "MODE", those moods change the sound each speaker gives off. if that doesn't work, you might need new wiring because there are other wires that are more durable than the ones that come with it, much better too.
Jun 02, 2009 | Samsung HTP-1200 System
Trying to get the theatre to play all my gaming systems
then you have probably connected all wires from game system to your TV. what you need is, as I did in my case with a PS3, a optical wire from your game system to your samsung home theatre system. and also remeber to configure your game system to direct sound through the proper channel.
Mar 24, 2009 | Samsung HT-Z310T Theater System
Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System
Connect the PS3 with HDMI to the Home theatre.
Connect the TV digital optical out put to the optical input cable of HT-BD2R provide your tv has a optical digital out put
You have the option of channeling the out put through either optical or HDMI in PS3.Go to the set up and set the audio out put to HDMI
Nov 28, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Onkyo subwoofer not working
I fixed my subwoofer. The resistor at R16 (right next to the fuse) was the fried component. I removed it and replaced it with a 13K ohm 5 watt metal oxide resistor (from Mouser Electronics if not available locally). Works fine now. I got the solution and the circuit schematic from an audio hobbiest at diyAudio.com. This is, evidently, a fairly common problem.
Sep 17, 2007 | Onkyo HT-S780 System
42 people viewed this question
Top Home Theater Direct Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Home Theater Direct Audio Player and Recorder Expert? Answer questions, earn points and help others
