Question about Poulan Pro 22" Self Propelled High Wheel Mower
Toro 20071 my gas tank has started leaking around the seam and they have discontinued the tank how do i fix this or is it all junk?
Can I add something to my car's gas tank that has a slow seam leak?
there is nothing to stop leaks in fuel tanks
however a cheap fix is to go to a wreckers/junk yard and get another tank
Nov 30, 2016 | Cars & Trucks
How do I replace a fuel tank on a toro 38586 snowblower that is leaking?
You need to remove the body cover first. The fasteners are all around the edge of the cover. Once that is free you remove the gas cap and lift off the ocver. The tank is only held on with a couple screws. A new tank can be sourced online for about 30 bucks. At bit pricey I know but it is a discontinued unit. Be safe and good luck!
Nov 22, 2014 | Toro Garden
How to fix a leaky Toro 20007 fuel tank
If the fuel tank is metal take it off and clean the seam with sandpaper and use JB weld to repair it- If plastic tank, use a glue gun.
Apr 18, 2014 | Toro Lawn Mower With Toro Power Tools
Gas leak at grommet on gas tank where gas lines enter and leave tank
Yes you should be able to replace the rubber tank seal that the fuel line goes through. Be sure to replace the fuel line(s) when you do.
Apr 01, 2014 | Toro 2-Cycle 25.4 cc Straight Shaft Gas...
My tb425cs leaks gas when it is running. It drips from the bottom of the gas tank.
Be sure to not overfill the tank. Just load it with gas up to the bottom of the neck and be positive you're not cross-threading the cap when twisting it on. If it only leaks when operating, see if there is fuel bubbling out through the vent(s) in the top of the cap or out from under it. Also wipe the tank clean and dry to be positive it is not leaking from a seam or crack in tank or around fuel lines. If leaking from cap, might have to replace as they do have an internal rubber seal that could have gotten dry or cracked. If it's from the tank seams or fuel lines replacement may be neccessary of either one or both.
May 02, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
I have a toro snowblower. Pull start and oil/gas mix. It was running fine then I ran out of gas, refilled and have not been able to get it started since. I don't know if my solution was too rich with oil...
The carburetor probably sucked up junk from inside the gas tank. Never run the tank dry. Take the bowl off the carburetor and clean out the Jets.
May 29, 2017 | Toro Garden
I need to replace my drive assembly on my Toro model 20071. How do I go about it?
WHere is a toro dealer that does warranty repair work in Jacksonville, FL?
Jul 01, 2009 | Toro Lawn Mower With Toro Power Tools
Gas leakage
David, you need to go to a junk yard, and buy a newer gas tank. A temporary fix, would be to use a ton of JB weld on the leaky seams.
Sha'ul
Jun 27, 2009 | Garden
Poulan Pro 22" Self Propelled High Wheel Mower Logo
43 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
