Question about RTO Fillpro Anti-Siphon Toilet Tank Fill Valve
Fill pro anti siphon - RTO Fillpro Anti-Siphon Toilet Tank Fill Valve
How to check a miele novotronic anti syphon unit
During rinse, water usually flows through the softener dispenser. The cup fills up and a small siphon tube triggers a siphon action
which pulls the softener and water into the washer. This siphon tube is probably blocked with crud. See if you can pull a small cap like part out of the softener dispenser area. Clean both the inside of the cap and the hole under it. This will allow the water to flow into washer instead of flooding.
Jul 06, 2016 | Miele Novotronic Premier 500 Front Load...
I can't fill up with gas. Even when near empty, it shuts off the flow off gas. Makes as "burping noise" then lets me add another gallon or 2 and repeats. Help!
This is a common problem with many vehicles. The filler neck has an anti-siphon flapper in it that prevents siphoning the fuel. This also restricts air flow around the nozzle when filling. There is a vent tube, but it often isn't large enough to purge the air out of the tank as fast as the fuel is running in. There are two ways to alleviate this issue. First is to reduce the rate you fill the tank to allow more time for the air to purge. Another way is to pull the fuel nozzle back slightly from the vehicle to allow more room for air to escape around it. Ensure that the nozzle is still past the anti-siphoning flap however, or you may get fuel splashing back.
Oct 17, 2015 | Hyundai Motor 2003 Sonata
Our local housing inspector says a toilet fill valve must be anti-siphon. I have Kohler k-9262 fill valves in my bathrooms. Are these anti-siphon models?
the fill valve is under constant mains pressure so it will not siphon out. However if there is a problem you can buy a non-return valve from your local hardware/plumber shop and fit it in the line between the cistern tap and the cistern
Jan 28, 2015 | Kohler Home
Can u easily siphon gas from a 98 montana? We cant get the rear bolt off thermostat housing to change the thermostat and just filled the tank
Cars and trucks manufactured since the late 70's have anti-siphoning screens at the bottom of the fill tube to the tank. So, sorry to say, no you can't siphon this new gas. I can truly commiserate with you as it's happened more than once. I've just filled my tank and the vehicle bites the big one. The only way to get to that gas is to drop the tank.
Oct 09, 2014 | Pontiac Montana Cars & Trucks
I have a fill pro water intake. The small whit screw with the spring has fallen off. I have tried to screw it back in but cant get the threads to take. Do I just need to replace the whole thing.
You can try to put several wraps of telflon tape on the screw to build it up a little. You can also go with a self tapping screw one size bigger and as long as the body it is screwing into is not cracked or split that should hold it.
For no more than they cost I probably would go ahead and replace it. Thank you and good luck.
Jul 10, 2011 | RTO Fillpro Anti-Siphon Toilet Tank Fill...
Faucet leaks through anti siphon valve
They make a repair kit for the anti siphon valve.Pop cap off (be careful not to break clips on anti siphon cap) remove old anti siphon valve and put in new replace cap problem solved.It screws out.
Jun 04, 2011 | B&K Plumbing
Gmax flushing system won't stop
WATER LEVEL IS NOT PROPERLY ADJUSTED. REDUCE WATER LEVEL TO FILL LINE
Jan 07, 2010 | Toto Drake Tank W/GMAX RH COTTON WHITE...
Water running out when washing machine is filling?
Hi jojolevaokah
Water siphoning out the drain line
If the water is continues to fill and water is draining while it is filling or agitating, Check the height of the stand pipe. It should be about 36" above the floor. If the height is correct it may need to have an anti-siphoning valve installed into the drain line.
Apr 07, 2009 | Whirlpool LSQ9520L Top Load Washer
Water drains out as fast as trying to fill
hello, have you checked to see if your drain valve is'nt stuck open ?
Mar 31, 2009 | Washing Machines
Whirlpool washer fills, begins to agitate, then drains
moz-screenshot.jpgThe washer fills and drains at the same time only on the rinse cycle.
Shut the machine off with timer during this period and raise the drain hose. If the water continues to drain, you will need to install an anti-siphon kit.
Please leave a solved rating before you sign out
Jan 31, 2009 | Whirlpool LBR4121JQ Top Load Washer
RTO Fillpro Anti-Siphon Toilet Tank Fill Valve  Logo
Top RTO Home Experts
Donni Steen
Tom Chichester
Are you a RTO Home Expert? Answer questions, earn points and help others
