Question about Boating
Tohatsu 8hp The engine seems to have seized while sitting in my shed - it ran fine the last time I used it, might have been bumped etc but hard to believe the pistons are seized
  • 56 Answers
Check out our boating forums and search for other people having a similar issue. I bet you find an answer.
Posted on Apr 26, 2013
Why is my yamaha 2003 4 stroke 40 hp seem to be seized only 400 hr ran fine last time 3 weeks ago
Water pumps fail sooner from non use than using them all the time.13 years is a rather old unit
Oct 19, 2016 | Yamaha 40N/50N 40 and 50 HP Outboard Motor...
Pressure washer no spark
Are you sure there is no spark? U guessing? could be carburation. Unit primed if necessary? Choked properly?
Did you press the throttle control/handle to on to relieve pressure on the motor so it can start properly?
Feb 03, 2016 | Cars & Trucks
I have a 2003 Yamaha beartracker 250. I haven't started it in years the engine feels seized up. what can I do a out this? it ran fine the last time I used it.
Pour a little diesel down the spark plug hole... leave the spark plug out, keep it out of the rain... let it soak for a few days, then try the cord... may take up to a month but it will free up a little at a time.... once free keep the plugs out and pull hard a few times to get the diesel out of the piston chamber, change the oil as some of the diesel will get down to the bottom... put in new plugs and fire it up.
Sep 24, 2015 | Yamaha Motorcycles
I drove my mower into my shed after the last use and now I cannot get it to move either forward or backward, even pushing it
Lift left hand foot pedal to full extent with top of foot may find that it is not engaging idle pulley, may be time for a new drive belt
May 30, 2015 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Engine seized or is it another problem?
Remove the head of the bike as six years a long period there must b some rust. sprinkle brake oil on the pistons and then simply/softly/slowly move the pistons up down. do not try to start it. once the movement u feel easy then clean the plugs, point etc air clearner/filter check the engine oil and then try to start
Aug 11, 2014 | 05 06 ZX6 ZX6R 636 Air Box Airbox Intake...
Engine hesitation
When is the last time the engine had a tune up with new spark plugs and an inspection of the ignition coils? Ignition coils were a pretty common issue with the V6 engine around that model year.
May 08, 2017 | 2003 Nissan Maxima
I have a 2005 mazda 6. it was 2 qts low on oil, i added oil, the car ran fine but had a slight rattle. 2 days later, i was sitting at a stoplight and the car died. my mechanic says the engine seized. no...
Hi . Unfortunately it's a common problem with mazda6 engine.When they run low on oil the crank shaft tend to get damaged.And some times people tend to top up oil rather than changing oil between 6000 &10000kms .Yep the engine is seized cost less replacing the engine than repairing it.good luck....
Jan 05, 2011 | 2005 Mazda 6
Pull cord getting stuck
Pull starter rope wheel is Jamming against casing usually some lube n check for ware will fix it
Mar 21, 2010 | Karcher 2500 PSI Pressure Washer
Ran fine now it seems like the engine is seized , only two years old the gas and oil mixture was fine it is a ryobi 60511b
take out plug and try to turn tines by hand and check the tines for free movement if free try to pull start it if still seized spray cylinder with penetrating oil and let sit if still wont turn over possible internal breakage-crank/piston rod
Mar 14, 2010 | Ryobi Cultivator
Boating Logo
93 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
