Question about Fossil ME1020 watch
Twist how do i wind the watch?
Watch stops after wearing for a few hours
Self winding watches need motion ( wrist twist) without they can stop. Sometimes just shake your wrist for a few seconds. I purchased a winder box for times I don't wear. ( Amazon)!
it is belt driven winder, rotates watch 5 minutes every hour.
Apr 21, 2015 | Rolex Submariner Oyster Watch for Men
Fossil twist
If you do not wind the watch, and if it is electronic it obviously has a battery. Very possible even with a new watch the battery has run out. This is especially if the watch was sitting for about a year in their inventory before you bought it.
I am not sure if your watch has a kinetic type movement where it charges the watch, or it is purely an electro-mechanical type movement. I did read it has a quartz referenced movement for the mechanical balance wheel. This would certainly involved a battery. If changing the battery is not the fix you would have to send the watch for service.
Feb 11, 2018 | Fossil Twist Series ME1013 Watch for Men
How do I set the time on an old Regina pocket watch. I can wind it and it runs well. The piece to wind the watch does not pull in or out to set the hands.
If you can wind your pocket watch using the crown, but you cannot see any way of setting the watch, you probably have a "lever-set" movement, though it's possible you might also have a "pin-set" movement. Do you see a little button you can push in, either at 1-2:00 or 10-11:00 on the watch case? If you, you have a pin set watch. Push and hold that little button in while you twist the winding crown, and that will let you set the time. End of problem.
Setting the time on a lever-set watch is a bit more complicated and will require taking off the front bezel of your pocket watch--the metal ring that holds the watch crystal in place. Pocket watch cases of this time are usually made in 3 pieces: the bezel, the main case body, and the back. The procedure used to remove your bezel depends on the type of watch case you have.
Take a close look at the front of your pocket watch. Do you see any hinges at the bottom (that is, below 6:00 and where the bezel meets the main case body)? I suspect that you won't, as double-hinged cases are usually associated with an older style of pocket watch, but it's worth checking. If you do see little hinges for the FRONT (it's more likely that the back will be hinged), then look for a little lip on the bezel that's used to pry open the front. Pull on that to open the case.
If you don't see hinges, which is what I expect, your front bezel unscrews. You can try to do this with your bare hands, but it's a lot easier if you have a bit of "gripping" rubber so your hands don't slip so badly. I have a small rectangle of shelf non-slip stuff that works perfectly for this. Turn the bezel counterclockwise. It may resist a little bit at first due to accumulated dirt, but then it should easily screw off.
Once you have the bezel away from the face, look closely at about 2:00 on the watch dial. Just at the edge of the dial, you should see a little lever or button. GENTLY pull this away from the watch face until it stops. Now, when you turn the winding crown, you should be able to set the time. Once the time is set, gently push the lever back to its prior position. Now, you should be able to wind the watch without changing the time.
Be very careful when screwing the bezel back onto the watch body. These parts typically have very fine threads, and it's easy to cross-thread the pieces. Don't force the two pieces together; once the threads catch properly, the front bezel will screw on easily without resistance.
An older style of pocket watch required the use of a little key to set the time from the back of the pocket watch movement. However, these watches were also wound by the same key, so the fact that you're able to wind this watch with a crown suggests to me that your watch doesn't use this system.
May 27, 2011 | Watches
Ladies Automatic Movement With date ,The watch will not wind wth the crown or by shaking the watch.Second hand never moves.
It sounds as if your watch is in need of some TLC by a watch repairer. (I assume that it is not under warranty; if it is, go to Fossil.com and click on customer service in the menu at the bottom of the page).
Have you dropped it onto a hard surface?
If the watch is several years old, then cleaning might help.
I suggest you take it to a local watch repairer and ask him to look at it and advise you on what needs to be done.
May 23, 2011 | Fossil Twist Black Dial Watch for Men
WILL RUN A SHORT TIME THEN STOP
mcdevito75 here, I would imagine your Rolex is an automatic, not all Rolexes are. After 2 days not running at all your Rolex needs a very good start not just putting it on and that"s it. Sorry to say!, I would ask you to do this, With your watch close to your ear I would like you to wind the watch, listen closely, if you haer a clicking or a drag sound you know you have to give about 20 winds to your watch before you put it on, after the 20 winds the automatic takes over. If the stem just spins and no sound, Click or drag, then your rolex is fully automatic, after you put it on you"ll have to ttwist your wrist back and forth to get the automatic moveing to wind your watch somewhat. Twist your wrist back and forth maybe 20--30 times, this way your watch has an initial wind and as you wear it the winding continues with the motion of your wrist, after it"s wound pretty good if it stops and goes, have the watch serviced.
Jul 01, 2010 | Rolex Day-Date President 118238 Wristwatch
Is it good to change watch movement to a battery ?Watch was overwound.
There is no such things as over winding a watch. If it is not an automatic watch then the watch will wind until it stops. If the watch does not run then something else is wrong.
If the watch is an automatic then about 30 winds will fully wind the watch. But, you can continue to wind the watch forever. It will never stop winding. Again, if it does not run after being wound there is something else wrong.
To fix your watch you need to have a qualified watchmaker repair it for you.
Hope this helps,
Ken
www.yellowstonewatch.com
Apr 08, 2010 | Kenneth Cole KC1104 Wrist Watch
It just wont wind
Wind it back and forth at least 15 times, then twist the watch very quickly back and forth a few times. That should restart the balance wheel moving. Twisting motion must be around the axis on which watch hands are fitted.
Feb 28, 2010 | Rolex Day-Date President 118238 Wristwatch
Starting a stopped automatic wrist watch
Unscrew the crown and wind it, then screw it back and twist/spin your watch. If this does not restart it going, then there is mechanical problem in movement and you will need watchmakers help.
Jan 07, 2010 | Rolex Submariner 16618 Wristwatch
I have a 1968 swiss made snoopy watch. How do I wind it, it has no battery.
is this watch automatic?? if it is it will have a small weighted roller inside, if you wear the watch and twist your hand (as if using a screwdriver) it should work, these watches have to be worn all the time and rely on everyday wrist movements to keep going. good luck
Aug 11, 2009 | Watches
Seiko Diamatic Day Date Automatic Watch No: 219050
I have a Seiko Diamatic 780632. To set the day and date, pull the crown once and wind it upwards (away from you) to set the date; winding it downwards (towards you) will set the day. To set the time, you have to pull the crown twice and wind it towards you.
Oct 24, 2007 | Watches
Fossil ME1020 watch Logo
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
