Question about Refrigerators
Pss27shna bs ge service manual - Refrigerators
Per Verizon I need to find out how to make sure DTMF tones are on - my cordless phone is Model No.: 27903FE1-A
Press Menu to access the main menu. Use - or + (cid/vol) to scroll to "Setup BS." From the Setup BS menu, press - or + to scroll to "Dial Mode." Use - or + to select "Tone." Press Menu to exit.
If you need a manual, you can download one at
http://www.home-electronics.net/ge/pc/IB/27903DE1_IB.pdf
Aug 17, 2011 | Uniden Cordless Phone
SIDE-BY-SIDE WARMING UP
do a full manual defrost then turn unit on and let it settle for 24 hours then check temp guage.....(try to keep doors shut when settling down)
Apr 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSL25IGRE BS slow water dispenser
Sounds like your water valve may need changing, and has filled up with sediment, slowing the water flow.
Mar 29, 2010 | GE Profile Arctica Stainless Steel Top...
GE Frig GSL22JFTA BS
If you get water at the bottom of the door then something is blocking it between there and the dispenser. Usually ice. Leave the door open and cover the freezer opening with a blanket to keep freezer cold.It should thaw in 156 or 20 minutes.
Oct 08, 2009 | Refrigerators
I CAN'T REGISTER HANDSET FOR GE MODEL 27911 DECT 6.0
Did you follow step by step instructions leading up to Registration; i.e HS Setup and BS Setup??
Dec 28, 2008 | Jwin G.E. Thompson: GE-29257GE1 Corded...
Refrigerators Logo
99 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
