Question about GE GSS20IETCC 20.0 Cu. Ft. Side-By-Side Refrigerator w/Dispenser & External Temperature Controls: Bi...
Ge PSC23MGMA ARTICA
LOUD FAN, SHUT DOWN AND HEATED WITH HAIR DRYER, BUT CAME BACK. ALOT OF FROST IN DISCHARGE CHUTE
3 Suggested Answers
aasc
  • 1606 Answers
SOURCE: GE profile Artica side by side. I am getting a frost build up
Sounds like the dispensor flap is not closing completely , pulling outside air in . Using a flashlight on the outside of the flap , look inside to see if any light is visible . If so , then the ice flap plunger and solenoid will have to be replaced . Also , excessive crushed ice can also cause frosting .
Posted on Jul 19, 2009
Sea Breeze
  • 4654 Answers
SOURCE: ge profile artica ice dispenser and chute frosing.
This may be because the chute door is not all the way shut when off. If yes the warm moist air is being pulled through the opening and causing this. Sea Breeze
Posted on Oct 21, 2009
Testimonial: "new here--did not mean to rate you low..sorry!"
Top part of the chute on my snow blower seems frozen
Take a couple of buckets of the hottest tap water you can get and pour it slowly down the discharge chute until the ice melts.
You can also use a hair dryer on it, but it takes longer
Mar 05, 2015 | Garden
GE Artica (pss26msrss) both the freezer and the refridgertor will not cool down...
Unplug and manually defrost with a hair drier because that ice you see on back wall of your freezer is a result of frost buildup behind that rear panel. Place all the frozen items in another safe place until the defrost is complete.Here is what your freezer may look like behind that rear panel. Not much cooling in freezer or fresh food section because this frost is blocking airflow.
The replacement parts for your model are the=> WR51X10042 Defrost Heater Assembly
7_12_2012_8_36_56_pm.jpgWR51X10042
And then the defrost thermostat=> WR50X10068 Defrost Thermostat
7_12_2012_8_45_50_pm.jpgWR50X10068 If you would like instructions on how to remove and replace I will be here to answer any questions you may have. How to test these parts can be found on the same page as the replacement parts, Thanks Sea Breeze
Jul 12, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile artica ice dispenser and chute frosing.
Oct 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer at 21 degrees , refer at 44 degrees, will not get any colder.
If your model number is the Profile/Artica PSS26 model the most likely reason for this is a burned out defrost heater. Look into back of the freezer and tell me if a layer of frost is building up on the rear wall of the freezer compartment. If yes then unplug and remove the rear panel in the back of the freezer to expose the evaporator coil. If frosted over then you need to defrost with a hair dryer or leave a bucket of hot water in the freezer compartment until the ice melts away. Sometimes the defrost drain is frozen over and then the beginning of the frost becomes heavy quickly and temperatures begin to increase in both sides of your side by side. Lately I seem to be here and ge no response from anyone. I want you to a the least let me know if you need my help to resolve this. Sometimes the main control board causes this but not as likely as the defrost thermostat and defrost heater. Sea Breeze
Sep 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My ice dispenser in my GE Artica is clogged. There is frost and ice on the dispenser and at the top of the chute. What is the problem?
The dispensor flap is not closing . Usually the flap solenoid rusts causing non closure . When not closing , warm air is sucked in by the fan , causing frost . Without model number , cant give you the part number you need . Solenoid and plunger is the part name .
Aug 09, 2009 | GE Profile Arctica Stainless Steel Top...
Jul 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Frost in freezer
The door seals on the refrigerator and freezer doors will not cause the frost at the ice chute. Frost will build up where warm moist air meets cold air. Your ice chute door seal is bad, so you need to replace the ice chut door. As far as your door gaskets go, clean the gaskets and the mating surface of the refrigerator and freezer cabinet. Use a hair dryer (NOT a heat gun) to heat the door seal up anyplace the dollar bill was loose. The magnet in the gasket will pull tight to the cabinet once the heat has softened it up. Do not open the door for 30 minutes or so to allow the seals to cool. You would only want to replace the seals if they are torn.
Jun 05, 2009 | GE Refrigerators
Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
May 18, 2009 | GE Refrigerators
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
