Question about Baby Gear
Combi lk 1ex 2497
Front wheels are horrableble. I need replace them, paid over $268.00 for this product you sell, and the wheels already bending and wobbles..any help please!
2 Suggested Answers
SOURCE: How To Collapse The Stroller
Lift up on the little grey plastic knob like structures on the sides of each arm. The stroller folds foward then fold in and hook the little grey latch in the middle inside of the stroller.
Good luck.
Posted on May 28, 2009
How to check & fix wiring on abs system.
If bearing/speed sensor assembly has been changed most lokely wiring. Use an ohm meter hooked between the two pins of the wiring harness side plug end. There will be resistance on this plug. Move/bend the wiring while the meter is hooked up and observe the reading. If the reading changes drastically or goes OL then the harness is bad. These harnesses are common problems as they flex as the wheels are turned. The dealership sells them for replacement.
Oct 12, 2015 | 2007 Buick Rendezvous
For a Shwinn Joyrider PR150 double kids trailer Bent connecting shaft for front wheel to stroller, within front wheel assembly. I disassembled the front wheel assembly and straightened the bent...
Depending on how old it is, I would send it back on warranty. Do not keep bending it or it will break when you bend it, or worse, while in use. It might just be better to get a new, more durable stroller all together.
Jul 15, 2011 | Schwinn Joyrider Bike Trailer Red/Black
I need a detailed instruction on how to fold a combi stroller
1. Lock both front swivel wheels. Not locking the swivel wheels before folding the stroller can damage the wheels 2. Empty the basket. 3. Fold the canopy by lifting the canopy levers. 4. Remove your player from the canopy. 5. Lift and hold the folding levers up on both sides of the handle. 6. Tilt the stroller onto its back wheels and roll it forward and then pull it back quickly and the front guardrail will fold inward. 7. Turn handle inward with an underhand hold to latch and lock.
Jun 02, 2011 | Combi Cosmo DX Stroller
Where to find replacement wheel for Combi twin stroller TS-2 7035?
Replacement parts for our products are available only through Combi. Call the Customer Relations Department at 1-800-992-6624. You will need to have your model number and serial number or manufacture date available.
Feb 28, 2011 | Toys
Hi. I have a problem with my edirol ua-1ex. When it is on my computer, some minutes after, it blows it, the blue message appears in my screan and shut down my system, i don't know why, everything seems...
It sounds like this may be a driver related issue. Can you please try downloading the latest version of the driver for your operating system from the link below and installing that to see if it resolves the problem.
http://www.roland.com/products/en/_support/dld.cfm?PRODUCT=UA%2D1EX
Robert from Blitware
Jun 16, 2010 | Edirol UA-1EX Sound Card
I have a Combi Stroller which I purchased and do how to open when
there is a small release mechanism on the front of the stroller. its a black bar that locks into a square hole. look in the front center of the stroller, about half way down, or about 4 inches above the front wheels. then you can unfold it.
Jun 18, 2009 | Combi Baby Gear
Good luck.
May 05, 2009 | Baby Gear
Edirol UA-1EX - hearing noise on audio playback
No solution, but I had the same issue with my old laptop, I tried everything, the only thing that worked, was to use a voltage generator, set it to 19.5 V (this was what my laptop was converting to) and getting a laptop power plug and creating a connection. Because the power pack is a SMPS, it was very noisy and this noise would be transferred to the recording.
Question of my own, where did you find drivers for Windows Vista 32 bit? I can only get my UA-1EX to run as speakers, not a recording device!!! HELP!
Submeg
Dec 10, 2008 | Edirol UA-1EX Sound Card
Wheels for a "combi" stroller
Take a look on amazon for them, click here: Amazon com baby stroller wheels parts. I hope this was helpful. Cheers
May 28, 2008 | Combi Cosmo DX Stroller
Combi Stroller - Can front wheels be replaced?
We loved our combi at first, but now both wheels are bad. We used to recommend the stroller because of it being so compact, but HATE the wheels. They should recall them or at least revise them.
Apr 16, 2008 | Combi Travel Savvy Stroller
Baby Gear Logo
27 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
