Question about HP Photosmart R507 Digital Camera
HP Photosmart 507 with defect cardreader
The cardreader has a crumpled (metallic) part. How to get to it to try to fix it? Where can I find a manual (or video, or whatever) telling me how to disassemble the camera? I can see it but it is impossible to get to it.
  • evelin van hien Aug 05, 2007
    Yes, but then you are stuck with only 200 low-res pics instead of more with a high resolution and also you have to upload the pics from the camera to the PC instead of through a cardreader...
    Genius:
  • 2,985 Answers
If the camera is still functioning- let it be. Generally there are no parts or manuals for self repair.
Posted on Aug 05, 2007
  • john ash
    john ash Aug 05, 2007
    You did not describe the function of the damaged part.
    Be that as it may there are sill no parts or manual that you seek
    Check out HP customer support to see for your self.
SOURCE:
Paper mismatch officejet 6500 crumples
There could be a foreign object or torn piece of paper that's stuck further inside the printer mechanism path. Try using a flashlight and inspecting any access or clean out hatches. Sometimes something will be caught inside and cause the paper you feed in to crumple and create a jam. I watched a video on youtube giving different ideas on how to fix this problem. Fixing Paper Pick-Up Issues
May 27, 2013 | HP Officejet 6500 Wireless All-in-One...
Photosmart D7360 - message says "ink cartridge empty. To print in color, install the following cartridges: yellow. To print in black ink only, press o.k." I have replaced the cartridge (yellow) and the...
go to hp support>d 7360 >software and drivers. Download (run) latest diagnostic utility 2010-11-09. run test and print test page (only one sentence). worked for me. Took about one minute.
Sep 10, 2010 | HP Photosmart D7360 All-In-One InkJet...
My hp photosmart 2610 will not print in color
Try running a test page and see what happens. If only one or two colors print, for example you see magenta but no cyan or yellow, then the cartridge could be clogged. Try aligning the cartridges and/or cleaning them to see if that helps.
If not, the cartridge might be defective, damaged, or out of ink so try a different cartridge. It's possible that the ink dried up if the printer was left on for too long or not used for a long time, and sometimes there are just defective cartridges; this happened to me one time with a color HP cartridge for one of my printers.
Worst case scenario, if nothing is able to print or if the printer is making weird noises, it might be a problem with the headers or another internal component that would have to be fixed.
Feb 14, 2010 | HP Photosmart 2610 All-In-One InkJet...
It crumples the paper up as well
This can be caused from one or more of the following:
1) Paper can go bad if not stored flat or for too long a time,
2) Could be a prior jam not cleared completely
3) Residue on roller(s) or damaged roller(s)
4) misaligned paper tray
5) Broken/Damaged component(s)
Sep 15, 2009 | HP Photosmart C4580 All-in-One InkJet...
Paper feeds in a bit and then crumples one corner and jam. seems the rollers and not guiding it through
try resetting the printer and look for any irreguler protrusion from roller if it has ........try replacing as that is most possible cause of regular jam
Sep 01, 2009 | HP Photosmart C3180 All-In-One InkJet...
I have problem downloading the pics from it
Use a cardreader to download your pictures.
Aug 17, 2009 | HP Photosmart 735 Digital Camera
HP Photosmart C6180 all in one, does not copy or print anymore.
put the old cartridge back, if there have same error message then tell me what error message is, if not that's mean new cartridge is defect.
Dec 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
Paper jam
you can check to see if there is something in the pickup path, or take it back and have them make good on it..not usual for something this new to be that bad...
Aug 17, 2008 | HP Photosmart C4280 Aio Printer
Resource Conflict - PCI on Motherboard Bus:0A, Device:09, Function:00 = CARDREADER PROBLEM
I did try all that, and it didnt work, on a 5050 acer built on a 3100 gabinet.
I think that the problem is that the cardreader chip is not well glued to the motherboard, that's why it gives you that error. If you try pressing certain points of the computer while booting, it miraculously stops giving that conflict error.
We should be payed back by Acer, as this is an project issue =P
Jul 19, 2008 | Toshiba Satellite A105 Notebook
HP Photosmart R507 Digital Camera Logo
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
