Question about Panasonic CU-E18JKK-1/CS-E18JKKW-1 Wall Mounted Mini Split Inverter Heat Pump -
Clicking noise in heat pump - Panasonic CU-E18JKK-1/CS-E18JKKW-1 Wall Mounted Mini Split Inverter Heat Pump -
My 2001 xterra started making a weird sound between 20 and 35 mph. It sounds like there is a leak in some pressure system.
Common Car Noises and Their Likely Causes Noise More Details Likely Cause Fixing It Clicking noise while turning Starts faint, gradually becomes more noticeable until very loud Failed outer CV joint (constant velocity joint) due to torn boot (most likely) or old age Replace either the whole axle assembly (recommended) or the outer CV joint Water pump noises Difficult to diagnose because of water pump's location Noise usually caused by damage to the bearings in failed water pump Only cure is replacing it. If possible do it at the same time as a timing belt replacement to cut down on labor costs Squeak or squeal from an engine belt Loud, high-pitched squeak or squeal Belts either need adjustment or replacing If belts only squeak when damp, they probably just need adjustment. If they squeak constantly, they probably need to be replaced Exhaust heat shield noises Rattle that you hear when car is idling Damaged heat shield Replace heat shield
Sep 28, 2016 | 2001 Nissan Xterra
Why my 2010 Venza drive on sometimes while driving it sound like the transmission is in neutral
Sep 28, 2016 | Cars & Trucks
Air conditioner making clicking sound when it's turned on
Check the belts that around ac pump but start the car and put ac on open bonnet take a long screw driver hold it down on the pump make sure u got a clear gap and put ur hear to the other end of screw driver. And do that to water pump power steer pump u wil hear which one is noise.
Apr 08, 2012 | Air Conditioning and Heat for Nissan...
Heat selector malfunction
Where is the clicking noise coming from, the engine compartment or the dash panel? Probably not the heat selector switch, so I'm willing to bet the thermostat is sticking and not opening, which is lesding to you not having heat and the clicking noise you are hearing. Replace the thermostat.
Mar 10, 2010 | 2000 Ford Windstar
Pump makes clicking noise when powered up ?
Clicking?... not knowing which clicking noise you are hearing, I will run down the most likely on a new pump.
1. When wiring the motor you may have left a wire in close proximity to the centrifical start capacitor switch. It spins at high RPMs and can be hitting a wire not properly tucked in
2. Most pool pumps are dual voltage. If you wired motor for wrong voltage than that being delivered, the motors can sometimes make noises. Clicking isn't most common, but the vibrating hum of incorrect voltage might be interpreted as a clicking noise.
3.check to make sure no wire ties, or plastic stringy tag holding devices were left in the pump intake basket.
Aug 23, 2009 | Hayward 1 Hp Max - Flo Swimming Pool Pump
Pump is clicking very 2 seconds and then overheats
I'd say you have a problem. The clicking sound is likely a thermal overload from too much current being drawn and the temp rising.
Once it cools off a little it tries again; draws too much currrent, heats up and the thermal overload kicks it off again.
It could blow the breaker as well, it just hasn't yet. Probably because there isn't a short circuit, just thermal overload from too much current for too long. It's a built in safety device internal to the pump motor.
My guess is the pump is bad -- and either the impellers are shot or a bearing is bad.
It would be nice if you could manually turn the pump shaft and see if it feels stiff or it makes unusual grinding noises, but you probably can't get to it.
I'd also guess that a pump repair is not cost effective, 'cause if the pump is that worn, fixing it will only keep it going 'till the next odd-ball thing goes wrong with it.
good luck
May 13, 2009 | Hayward Super Pump 1 1/2 - Hp for In...
Heater in dash makes clicking noise, stopped no heat
The clicking noise you are hearing is the temp door actuator. It is located in the center of the dash. If you look behind the radio from the Passenger side of the van you will see a white square box with a black or green connector in it. Remove the connector and then remove screws that hold the actuator in place. Install a new actuator and reconnect the wire connector. This should take care of your problem and your heater will be fixed. I hope this was helpful.
Jan 02, 2009 | 2003 Ford Windstar
2005 Buick LeSabre heated seat not working
The heated seats have relays that run them. Not quite sure where they are located but. That noise is the relay clicking on and off. They are actually pretty loud. Look for faulty connections to and from the relay and check battery power to both sides of the relay.
Dec 30, 2008 | 1999 Oldsmobile Aurora
Outside unit clicks while thermostat auxiliary light flashes
Sounds like the compressor starting relay or capacitor is defective. When the compressor could not start, the electric heat came on to satisfy the heat requirement and causing the emergency heat light to come on at the thermostat. This light warns you that electric heaters are energized. And they use a LOT of electricity! Call a different company for service. And do it soon.
Ray
Nov 16, 2008 | Ruud Handler Air Conditioner
Panasonic CU-E18JKK-1/CS-E18JKKW-1 Wall Mounted Mini Split Inverter Heat Pump - Logo
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
