Question about Pool & Spa
I have a thermoflow electric heater it will heat my spa up to 98 and them makes a constant squilling sound for a few min and the heat pump shuts off it dose not throw a code
2 Suggested Answers
  • 990 Answers
SOURCE: The heater makes a banging sound after the burners
What you have is a water flow problem. The water should be going through the heater but it is by-passing it. The water inside the heater is boiling and trying to expand as steam that makes the banging sound. Their is a internal by pass in the water manifold on the side of the heater. If you take this apart you will find a disc on a spring contraption, if it is stuck open the water goes past the heater but still has pressure to kick the pressure switch and fire the heater. Either clean or replace this assembly. The other thing to check for is an external by-pass. This will be a gate valve bridging the inlet and outlet pipes. If you have one of these it should be 80-90% closed or the water goes through it and creates the same problem. This is not on all systems so don't be alarmed if you don't find it. Good luck.
Posted on Mar 29, 2010
Intex spa has power but just makes a loud constant sound. Lights go on. Pump will not flow water. What happened? Was working just fine for 2 months. Is it fixable?
It looks it would be worth fixing, first I would check the power, the plugs and voltage. it has heat so it requires the proper power cords to supply it,
If all checks out I would contact intex, if there is not any warranty, I would search your area for a electric motor repair shop, tell them its a spa pump with a heater,
I would be happy to look at it for you at no charge to see whats it's fault is. I'm in central Florida.. here are the error CODES. best of luck.. Jay
Dec 31, 2014 | Intex Pool & Spa
Fl 7 code pump will not come on
make sure you dont have the heat maintain on
May 25, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
Heater shut offs and restarts in about 10 min intervals
check to see if recirculation pump is working sounds like it is overheating
Mar 26, 2013 | Teledyne Laars Spa Works Heater Element...
Same Issue
the pump stop so will not drain spa dip # 4 may turn off for the delay but not sure if the pump will still turn off since this is new tech. good luck
Jul 05, 2009 | Jandy Aqualink Rs4 One Touch Control...
Pool heat blows circuit breaker after a few min. of running
if its a gas heater,make sure circuit is overloaded i.e.other appliances on same circ.An electronic ignition pool htr uses a very small amt of electricity.check for proper grounding.
Jun 24, 2009 | Hayward Pool & Spa
Pool and Spa Heaters pros and cons
An electric heat pump needs heat available to pump. If it is 30 degrees outside, heating a spa to 102 or so, may be impossible unless the heater has some type of alternative heat source. A properly sized, gas fired heater can take care of a larger range of heating needs. A combination heat pump and natural gas heater, probably with a controller, really makes the issue more difficult, expensive, and would require a lot of study for efficient, cost effective operation. Bottom line: In really mild climates a heat pump might do the job. In cooler climates the gas heater rules. And where a wide range of temperatures and high heat demand is wanted by the customer, a gas heater is the only way to go. A backup heat pump may take years to payout.
Aug 27, 2008 | Saunacore Special Edition Residential...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
