Question about Kenmore Top Freezer Refrigerator
363.9557880 clunk when it shuts down
My 2005 stratus was driving 65 down the interstate when I heard akot of clunking and I pulled over and it shut off tried to start it and battery was dead
is the battery dead or is the engine seized up. the lots of clunking indicates a bigger problem than the battery
May 06, 2015 | Cars & Trucks
Hotpoint fridge makes clunk-clunk-clunk noise when it shuts off
You need a new compressor. Probably time for a new frig.
Nov 18, 2011 | Hotpoint Refrigerators
Daughter ran over rock and cracked oil oil light come on but wont start back does engine have oil psi shut down
the oil pressure required to start is only like 3psi on a ford which is about 5% of what it will be going down the road. Does it try to start at all or just a hard clunk when trying to start. If it just makes a loud clunk/click then your engine is probably seized and will need to be replaced.
Jun 24, 2011 | 2002 Ford Escape
The compressor makes a big clunk clunk sound when it shuts off
The compressor motor mount is broken and that allows the compressor to flop around and clunk when shutting down.
That also allows it to twist and turn as it starts...
this will have to be fixed before the refrigerant piping breaks...
heatman101
Oct 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Motor won't start and mower very difficult to push
is there a puddle of oil under where it made the clunking sound, that would mean the engine is blown. another thing to check is to see if the motor bolts that hold down the motor came loose and is hanging down there by keeping the pullys from moving right..good luck
Apr 03, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a new 4 ton 15 SEER AC. It has been cooling great. Last week I have been noticing when the AC shuts off there is a loud clunk noise. What is going on? Thanks Steve
Is the clunk in the outside unit?
If it is it could be the mounts holding the compressor to the bottom or it may be the mount is broken on the inside of the compressor. Such as you hear when an old refrigerator
shuts down. Could be other things also. The first is most likely.
JSTACH
Aug 26, 2009 | Heating & Cooling
HP 2410 printer won't boot up, just makes a clunking sound.
Someone just had a similar problem.
Unplug your printer for a few hours.
Plug it back in and the problem clear.
Jan 29, 2009 | HP Photosmart 2410 All-In-One InkJet...
Freezer noise
clunk comes from the compressor - possibly dismounted or sometimes assembly inside hits casing on switch off or switch on. no cure except replace compressor
Jun 19, 2008 | Kenmore Freezers
Kenmore Top Freezer Refrigerator Logo
11 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
