Question about Aquatronics AMS602WR Coaxial Car Speaker
Marine stereo (Aquatronics) Turns on and then shuts itself off
When I turn on my boat radio after a few seconds it shuts off. I turn it back on and it shuts right back off.
    New Friend:
Aquatronics model ms-1000 led display lights and nothing else
Posted on Aug 09, 2014
3 Suggested Answers
SOURCE:
  • 16 Answers
SOURCE: how do i remove an aquatronics MS1500B marine
remove the dask or go under the dash and remove the bracket screws and then unplug the harness.
Posted on Aug 20, 2009
SOURCE: Aquatronics Radio MS1550G 4X40W
I have an Aquatronics MS1550G radio on my 2006 Suntracker. The radio speakers have sound, but the sound is barely audible. I have used the reset button with no success. Is there a quick fix to this problems?
Posted on Apr 08, 2010
Why does my pyle marine radio keep shutting off when I start my outboard.
Aouns like wiring problem with ground wire. Why dont you install dedicated switch for stereo. It is unsafe for electronics to be on while starting motor.
Sep 10, 2018 | Boating
Put new marine stereo in boat when hooked up battery crossed wires with second battery and blew fuse, now keeps blowing same fuse
If you mean you put the two batteries in series and loaded the radio with 24 volts, you need a new radio. You will have melted components inside and are causing a dead short.
Aug 14, 2015 | Cars & Trucks
Stereo turns on shuts off after few seconds
This is a bad power supply. You have to do some serious work at the component level of the unit to fix it.
Jan 22, 2014 | Sharp Electronics - Xldk257n - Xl-Dk257n...
High Battery alarm goes off while boat motor is running
power supply for the radio taken from a source wire that is affecting the voltage regulation
take it in or have a radio technician come and check the installation
Jan 09, 2018 | Uniden Solara DSC VHF Marine Radio
Aug 08, 2009 | Aquatronics Car Audio & Video
How do i remove an aquatronics MS1500B marine am/fm/cd radio from my boat
Jul 30, 2009 | Car Audio & Video
Radio shutting down after 60 minutes
Hello peter79,
Ive had similar problems with my radio on my sailboat.
This really depends on how you have your radio housed. Is it inside a cabinet, or perhaps sealed in a water tight enclosure ? Is it in the cockpit of the boat or inside the cabin ?
The reason I am asking these questions is because I believe your problem is heat related. If the unit is getting overheated after an hour of use it will shut itself down to cool off. I imagine it starts working fine again after a little while.
The only solution is to make sure it is getting proper ventilation and that you also protect it from the elements. You may even look into buying a Marine Stereo as they will last a lot longer on a boat.
Post back with any answers or anymore info so that I can be of further assistance. Thank you for choosing Fixya!
Jul 14, 2009 | Pyramid WX61 Car Subwoofer
JVC KD-LX333 car stereo turns on, but then shut off and wont...
TAKE IT OUT AND TRY IT ON A 12V BATERRY AND IF IT TURNS ON ITS GOOD AND IF IT DOESNT IS NOT GOOD. IF IT TURNS ON FOLLOW UR CONSTAN AND UR POWER WIRES AND SEE IF IT HAS A FUSE BOX IN THE BOAT/ CHECK THOSE FUSES. AND CHECK UR BOAT BATTERY TOO CAUSE IT COULD HAVE DIED WHEN TESTING THE STEREO TOO IT HAPPENS ALOT ON BOATS
Jul 04, 2009 | Sony CDX-GT210 CD Player
Is this considered clipping in marine boat stereo help!!!!
if your radio is puiing more power your ground might not be good enough, use the same spot but remove the ground and rough it up a little on the base with some sand paper or add a metal o ring to get a better ground.
Jul 30, 2007 | iLO XM-MP3-CD Car Stereo
Volume turned up, kenwood shuts off briefly...
I had this same exact problem when my last older Kenwood Marine stereo cooked itself while I had it up loud for a few weekends on the lake. (smelled like it had burned inside). I went out and bought a new Kenwood KMR-550u stereo deck. (I do not have an additional amp). I hooked it up to the exact connections where my older Kenwood stereo unit had been hooked up, as I never had a problem with this for the past three years until it failed after smelling of burning elelectrical. I had chalked the problem up to heavy rain we had one day. Every time I turned up the volume, sometimes up to 27 out of 35 possible, or 29, or 32, the stereo would suddenly shut off as if I had turned it off. After a few seconds the stereo would come back on, but unless I was quick enough to turn down the volume it would do it again right away. Of course on a boat, we were beached in a cove and the engine was not running when I encountered this. I searched the internet finding hundreds of similar complaints and several dozen theories of all types, but only a couple that pointed me towards the power (voltage) idea as the problem. I put a volt meter on the positive & negative wires powering the stereo. I watched as I gradually turned up the volume, the voltage on the power wire gradually decreased from 12.5 volts, down into the 11 range, and as it hit 10.9 or 10.8 volts it shut off typically around a volume of 32. The red power wire in my boat that never seemed to have an issue with my old stereo until it fried was determined to actually be inadequate for the power flow for the new Kenwood, and probably was the culprit of my failed older unit. I offer this sound advice: Run a new pair of positive & negative wires directly from the battery (with an appropriate fuse of course (the deck has a 10 amp fuse in it's back so I would use that at the battery) to the stereo. Check the voltage as you turn the volume up into the high 20's and low 30's to ensure you are still getting voltage in the mid to high 11-12 volt range. The stereo is designed to require a minimum of 10.8 volts to operate, and when it drops below that it protects itself and shuts down.
Mar 24, 2007 | Kenwood Sirius KDC-MP522 CD Player
Aquatronics AMS602WR Coaxial Car Speaker Logo
508 people viewed this question
Top Aquatronics Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you an Aquatronics Car Audio and Video Expert? Answer questions, earn points and help others
