Question about Maytag MFD2561HEQ 24.8 cu. ft. French Door Bottom Freezer Refrigerator in Bisque
Maytag MFD2561HEQ Bottom Freezer Refrigerator - Freezer working, refrigerator not
Hi. My Maytag broke on me after less than 2 years. The freezer (bottom) still works fine, however, the refrigerator does not. No cool air seems to be pumped in. Any advice? Thank you.
  • 2 more comments
  • Marc van Nuenen Aug 07, 2007
    Apparently the fan stopped working. A service technician replaced it. Thanks.
  • CATLARREA Nov 21, 2007
    HI I AM HAVING THE SAME ISSUE WHERE ONLY THE BOTTON FREZZER WORKS AND THE TOP DOESNT WORK EVETHING ITS SO HOT WITH THE TEMP OF80 HELP
  • bevsudds Feb 09, 2009
    help - my husband has checked and the fan is running.
    Any more suggestions before we call for a repairman.
  • Anonymous Mar 14, 2014
    My maytag french door refrigerator won't cool freezer works fine
I HAD THE SAME PROBLEM,MOST OF THE PROBLEM IS WITH MY CHILDREN WHO CANNOT CLOSE THE DOOR ON THE FRIG. THIS CAUSED MOISTURE WHICH FROZE THE VENTS IN THE FREZZER SECTION. A HAIR DRYER AND 15 MINUTES OF MY TIME FIXED THE PROBLEM
Posted on Aug 11, 2007
    Novelist:
  • 159 Answers
Marc of Nc. check to make sure the fan in the freezer is operating when the compressor is on. The only thing the fresh food section gets its cool air from is the freezer. and if the fan is not operating no cold air will get up there. If the fan is running you need to make sure the air duct is not blocked with frost of the evaporator is not iced up. Check that out and get back with me if there still is a problem. Good Luck
Posted on Aug 06, 2007
Refrigerator and Freezer not cooling Maytag MFI2665XEM7
check to be sure condenser fan motor is still working bottom back of refrigerator , also is there frost at back of freezer if so you have a defrost problem,
Nov 30, 2013 | Maytag Refrigerators
My water dispenser is not working.
The water dispenser not working, this problem relates to clogged water line or faulty water valve or water supply off or water line got loose from its connections. Click this link below to get more details:--- http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
--------- This should help.Thanks.Helpmech.
Oct 17, 2011 | Maytag MFD2561HEQ 24.8 cu. ft. French Door...
I need the code to programe the refrigerator
Sorry to read about your problem, I hope this helps you out.
Their is no code to program, and their is nothing to program....
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 20, 2010 | Maytag MFD2561HEQ 24.8 cu. ft. French Door...
Bottom freezer is fine but top refrig. is warm. Have vacumned bottom front coils, unit less than 2 years old. Any suggestions, other than calling repair? thanks.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 26, 2010 | Amana AFF2534FE Bottom Freezer French...
Refrigerator running but will not cool or freeze
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 25, 2010 | Maytag MFD2561HEQ 24.8 cu. ft. French Door...
My 3 year old Maytag Fridge is on the Fritz.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 12, 2008 | Maytag MFD2561HEQ 24.8 cu. ft. French Door...
Refrigerator is not cold but freezer is still operating.
Couple things, both doing with air flow. If the fan in the lower freezer isn't working there will be no cold air moved into the upper fridge. If the defrost cycle happens to be dead then the coils down there will freeze solid and there can be no air flow over them to cool the upper area. You'll have to pull the lower drawer out and take off the interior rear panel to check these things. Hopefully it's just that the fan motor went out. It's real easy to change. Let me know what you find, if the coil is all iced up solid then there's more things you need to look into.
Jan 08, 2007 | Maytag MFD2560HES Bottom Freezer French...
Maytag MFD2561HEQ 24.8 cu. ft. French Door Bottom Freezer Refrigerator in Bisque Logo
431 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
