Mi TV/dvd RCA modelo L26HD35D no se ve imagen
No se ve imagen
pazman
  • 81 Answers
SOURCE: pantalla se ve como infrarojo
possible que tienes que deconnectar todos los cables y reconnectar los patras, Y tambien la coriente de la tele.
Posted on Apr 09, 2008
dave1645
  • 834 Answers
SOURCE: RCA tv dvd combo L26HD35D programming codes
not gonna happen
Posted on Sep 20, 2009
  • 2318 Answers
SOURCE: Por Favor me gustaria que
Podrias proporcionar el modelo completo de tu plasma?
Cuando proporciones el modelo te indicare donde esta la falla y tambien donde comprar la parte(s) para reparar tu TV.
Posted on Sep 12, 2010
TV #1
  • 129 Answers
SOURCE: El screem del Tv
Necesitas cambiar un tablero que se llama DMD module. Cual es el modelo del TV?
Posted on Dec 18, 2010
SOURCE: The disc in our tv (RCA L26HD35D) will not eject.
The best way to get you dvd out of the side slot without scratching it is to set the t.v. on a soft surface screen side down. (Carpet works great) Then remove all the screws from the back of the t.v. including the mount stand and take off the 2 panels on the back of the t.v.. One will be in the middle use a flat head screwdriver and lift upwards on the side nearest to the screw, the other on will be in the top left corner do the same here. Then you will want to unhook the wires from the motherboard (they will be bundled) do this by pulling gently on the connecter head (do this as evenly as possible to avoid damaging the pins) remove both connector heads then take the whole back of the t.v. off. After all that you can easily use the white plastic manual dvd release lever. I hope that helps some of you that got this poorly built product. If RCA was thinking about the customer when building this product they would have made a panel right over the dvd player and that would have saved a lot of hassel of course doing what I've suggested will most likely void your warranty and then they wouldn't get to make as much money off you. By the way their customer service is out of Japan and good luck getting anywhere with that.
Posted on Apr 19, 2011
Mi problema es con mi mi televisor mitsubishi vs-50501 enciende y cuando va a entrar la imagen se apaga a veces si entra y se ve medio rara como que tiene dos imagenes un poco separada o se ve la imagen...
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Dec 19, 2013 | Mitsubishi VS-50609 50" Rear Projection...
Tv lg 32ld330 enciende con sonido y sin brillo
Mi tv lcd es marca LG modelo 32LD330, al encenderlo se escucha y cambia de canal pero el video lo emite a mitad no da la imagen completa que puede ser?
Aug 18, 2012 | Televison & Video
TvRCA d52w20 52 pulgadas doble imagen
mi tv rca no enciende solo dejo de funcionar y ya, que es lo que debo de revisar en este caso?
Jul 21, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Mi televisor enciende , pero no se ve la imagen , solo se escucha el sonido , eso a que se debe? por favor ayudenme
mi televisor plasma no se puede ver pero se olle que sera
por favor me pueden ayudar
Nov 11, 2010 | RCA 20F420T 20" TV
Por Favor me gustaria que me respondierais a la mayor brevedad posible y en español. Mi lg pdp42,estaba funcionando perfectamente y de pronto se escuchó un ruido,como cuando se va la luz,como si...
Sep 12, 2010 | Televison & Video
No funciona
Ulises,
A ver si me entendes, el televisor se ha descalibrado con el control remoto.
o por la tecla que apretaste o por algo que paso.
Para que funcione nuevamente simplemente debes volverlo a programar.
Ya se que no anda, y ya se que probaste mil veces.
Ahora empeza de nuevo y programa el control remoto como si empezaras desde cero
Para ello necesitas el codigo de tu TV para ingresarlo en el control remoto.
Los codigos normales del Silvania son 0054, 0030, 0020, 0096
Si estos numeros no funcionan dame la informacion que te pido abajo
modelo de tu Sylvania
modelo de tu y marca Remote
Oct 19, 2008 | Vehicle Parts & Accessories
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
