Question about Lite On LVW-5115GHC+ DVD Recorder
Poor picture quality and sound problems on Lite-on LVW 5115GHC
Recently purchased Lite-on LVW-5115GHC and, from the start, does not have good picture quality. Also, the sound, after about 30minutes of recording, goes and is replaced by a static noise although the picture remains. The recorder is hooked up to the satellite receiver for receiving satellite channels and aerial channels (the problem occurs on both).
Have you tryed replaceing scart leads plus check if there in a priority order 2 like going form dvd 2 tv then tv 2 sat recever try going via sat recever then dvd then you tv if that dose not seem 2 solve you problen it might seen you might have dry solder point inside you dvd unit if so take bk where you buy it from and explane to then wat is happening hope helped
Posted on Feb 06, 2008
The box super, picture problem
check your scart to see if any pins are bent or even a slight bit of dirt will affect the quality of your picture
Jan 30, 2009 | StarTech.com StarView SV211K 2-port KVM...
We have lost our instruction manual for our dvd recorder
You can get the manual here, but you have to sign up to their site, which is Free.
http://www.retrevo.com/support/LiteOn-LVW-5115GHC%2B-DVD-Players-manual/id/2453ci363/t/2/
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/thomas_b78b4251cd160cd2
Jan 21, 2009 | Lite On LVW-5115GHC+ DVD Recorder
Lite On LVW-5045 DVD Recorder - won't record onto disc
Liteon lvw 5045 problem action failed.please consult our customer service for recovery. (error code: 0x810D0004)
Dec 11, 2007 | Lite On LVW-5045 DVD Recorder
DVD Recoder trouble
I have the LVW 5005 and was having a similar problem. Unplugged it tore it apart (looking if anything looked physically wrong) plugged it back in and it worked (and still is). Try unplugging it, letting is sit for 1/2 hour and plugging it back in. Might get lucky.
Dec 05, 2007 | Lite On LVW-5005 DVD Recorder
Lite On LVW-5115GHC
Try cleaning it again. Did you clean all the sensors? In order, you first remove the exterior cover with the 2 large side screws on the side (one is under a sticky label) and then on the back, remove the 4 screws around the perimeter of the cover. Pull off the cover and then remove the 2 screws on the silver colored plate over the CD/DVD drive. Then spring in the 2 tabs toward the rear that lock down the rear of the drive cover, and lift the silver cover off the drive. Now there will be an obvious lens and a couple of more light output devices that don't look like lenses. You should see them off to the side after you look it over well. Cleaned with Isopropal and dry with a dry q-tip. After I did this, I had the same problem still. I then took the unit apart again out to the garage and used a throttled back air stream from my air compressor to clean all around the the sensor head. I re-assembled it, put in a DVD and it played OK.
Sep 25, 2007 | Lite On LVW-5115GHC+ DVD Recorder
Lite On LVW-5005 DVD Recorder video is not working
try installing more codecs to your computer. search for mega codec pack.
Sep 01, 2007 | Lite On LVW-5005 DVD Recorder
Lite on lvw-5045 dvd hdd recorder
You can download from the following link: http://www.liteonit.eu/eu/DOWNLOADS/DC/LVW-5045/user_manual/en_eu/English-EU.zip
Aug 07, 2007 | Lite On LVW-5045 DVD Recorder
Lite On LVW-5115GHC+ DVD Recorder Logo
112 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
Damen Wong
Damen Wong
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
