Question about Invicta Watches
Invicta watch back removal - Invicta Watches
5 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: how to remove links on invicta russian diver watch
Hi Pate the only thing i can advice you is go to a service center near to your place.All watch technician like me have the knowledge to remove the links with no impaired damage or scratch.We know how to detach the links.So if want to know more of your watch i will give you a site that can help you and ask more information about your watch. www.invictawatch.com
Posted on Jun 17, 2008
escapement
  • 2334 Answers
SOURCE: Invicta 2875 wrist watch band too large
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 01, 2009
escapement
  • 2334 Answers
SOURCE: need to resize watch braclet on a mens invicta watch
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
Job done!
Posted on Apr 02, 2009
  • 12 Answers
SOURCE: My invicta stainless steel band has two bent
Contact Invicta for cost of repair:
http://www.invictawatch.com/support_files/service_center/ServiceCenter.htm
Posted on Jul 15, 2010
Battery type invicta watch model 4889
  • Remove back
  • Locate battery and mounting. Note mounting details for later.
  • Identify battery
  • Obtain replacement
  • Install
  • Check operation
  • Reinstall back
  • Set time, etc.
Or,
For a few dollars, have a jeweler replace it
For a few dol
Oct 25, 2016 | Invicta Watches
I would like to know how to remove the back and change the battery.
There appear to be several models in Invicta Signature Watches.
Your best bet is youtube. one is shown below Battery Change Invicta Men 2770 Force Collection super easy
Apr 02, 2016 | Invicta Signature Watches
How to remove links from Invicta 0132 wildflower
Normally on this type of Invicta you would use a slim punch to push out the little pins at each end of the link section you want to remove, then reattach the band using one of the removed pins.
In some cases one end of a pin will be slightly wider than the other so that the pin is meant to be removed in one particular direction. If you can't tell any difference, the pin will probably come out either way. You may use a small hammer to tap the pin back in if needed but don't scratch your band.
Feb 07, 2015 | Invicta Watches
Need a stem for an Invicta Swiss ISA 1872/220
You may have to refer this problem to Invicta for solution.
Jul 06, 2014 | Invicta Watches
Watch battery replacement
I believe that model's back screws in. You can get a rubber jar opener if you are having trouble gripping it. In general, the key is unscrewing it.
Elisa Jed ' http://keepingtimewatches.com/mens-chronograph-watches
Feb 15, 2014 | Invicta Watches
How do you remove the back of an invicta model 3459
here's is a video on how to open the caseback of your watch. i hope this will help you. just click the link below.
http://www.youtube.com/watch?v=bYTlqox3aA8&feature=player_detailpage
Jul 30, 2011 | Invicta Vintage Collection Chronograph...
How do I remove pins to size an Invicta Sea Spider model #0140
mcdevito75 here, Aren"t the spring bars (pins) built into Invictas Strap?? Look on the back of the Strap real close to where ot attches to the watch, see a little tab you can move with your fimger, this tab should compress the spring bar (pin) and allow you to remove the strap.
Jul 03, 2010 | Invicta Sea Spider Chronograph...
How to remove links on invicta russian diver watch
Jun 17, 2008 | Invicta Watches
Watches Logo
200 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Invicta Watch Expert? Answer questions, earn points and help others
