Question about Refrigerators
Need wiring diagram or schematic for 2000 Damon Escaper RV Model # 3980
GFI outlet in bathroom keeps tripping. 3 outlets in kitchen and 1 outlet in the coach basement area are tied to this gfi outlet. GFI outlet has been replaced. Other outlets appear to be OK. Trying to determine if there is an outlet that I am not aware of. Also want to determine sequence of wiring. Thank You Debby
2 Suggested Answers
  • 103 Answers
SOURCE: GFI outlet is tripping because of refrigerator in the garage.
Hi: Yes, replace the GFI outlet. A refrigerator should not be plugged into one for what you are experiencing and food loss. This was an easy answer for me, but unfortunately not for you The owners manual covers this, but us men don't read them (Well I had to as I worked with them for 30 years). Good luck, Jeff
Posted on Jun 01, 2009
There are 2 GFI plugs in the rv. I found the one in the bathroom where is the other one?
Have you checked the outside plug? Next to the outside kitchen, It should be there. On my RV I have one next to the bathroom and outside.
Nov 28, 2015 | Keystone 2015 Outback Terrain 210TRS
I plugged a 30 amp power supply cord from an rv to a 15 amp house outlet to run a/c to rv . gfci tripped and wont reset. damaged gfci or something else?
A GFI outlet works independently of sensing an overload condition. Overloads are dealt with by the circuit breaker or fuse in your electrical panel. The GFI simply compares the current on the hot terminal (black or red wire) with the current on the neutral terminal (white or gray wire) and interrupts the current if there is more than 5mA (0.005 Amps) difference between the two.
Remove the load - in this case the RV plug - from the GFI outlet and attempt a reset. Make sure you're pressing the RESET button and not the TEST button. If it resets - you're all set. Reconnect the RV plug to a different outlet - preferably NOT a GFI type.
If it still wont reset, it is important to know that GFI outlets can be wired in such a way that any circuit extended to other outlets (lights, too) via the LOAD terminal screws will also be protected by the GFI. We need to be sure that there wasn't something else causing the fault. Check other nearby outlets for functionality. Remove plugs from any outlet found not working and attempt to reset again.
If it will not reset - it is possible that the internal sensing circuitry has been damaged due to such a large amount of current trying to pass. In this case, replacing the GFI outlet will be needed.
Oct 09, 2015 | Washing Machines
We have a 2013 aspen trail 3117rids and the outlet in the kitchen counter area, the out let on the island and the gfi in the bathroom don't work. ?
Have you done a VOM test on the house lines to the bath from the circuit breaker box? This is important, without the GFI in place, just the bare wire test? If you have voltage from the box to the Bath wires, then your power is correct and the attached outlet needs to be checked for continuity. If no power to the bath from the box, the circuit breaker may be bad, or tripped.
May 09, 2014 | Dutchmen RVs
Wiring diagram for Heartland 2013 Key Largo
Wiring diagrams are not available as the manufacturers to not publish them. You have to determine which circuit the outlets are on and then from there determine the outlet prior to the failed outlet and trace back from there until you identify the point of failure. Most trailers are wired with GFI outlets with the primary GFI being in the bathroom or the kitchen and all outlets wired after that point are controlled by that one primary. If you do not have power go to the primary and press the reset button.
Feb 19, 2014 | Heartland 2013 Landmark LM Key Largo
Home fuse box breaker issue
Hi Rex,
It sounds as if the upstairs bathroom outlet and the outdoor outlet are on the same circuit. There's a very good chance that these are GFI or "ground fault interrupter" type outlets, as these locations (and others) have required this type of protection for over 30 years. It was a common practice to run a circuit from the panel to one of these locations (or another) and then run from here to the next outlet and then on to the next. Since the GFI outlet could be purchased for around $10 instead of $30 for a GFI breaker, electricians would install outlets instead - both offered the same protection. A "regular" breaker would supply power to this circuit - but the very first outlet would get a GFI type outlet. It would be wired to the LINE terminals and the cable that feeds the rest of the outlets on this circuit would be connected to the LOAD terminals. If there was a ground fault condition, this GFI outlet would trip, but the circuit breaker would remain on. You would locate and RESET the tripped GFI outlet to restore power. The only time the circuit breaker would trip is if the circuit was overloaded. Overloads would NOT cause the GFI outlet to trip.
Now that you understand how it was typically wired years ago (and still a lot of times today), you should check all the outlets outside your home, in bathrooms, basements, garages, and inside your home next to doorways that lead directly to grade of your lawn or deck. These are required places for GFI protection. Press the RESET on any tripped GFI outlet to restore power. If the outlet will not RESET, there is a condition where the hot wire (black, red or blue insulated wire) is in contact with ground, or a device or appliance connected to the circuit has a problem. Unplug anything connected to the circuit and attempt to RESET again. If still unable to reset, open the outdoor outlet again and carefully pull it out and away from the box. Inspected for damaged or crushed insulation and repair / tape as needed. Before reinstalling, try to reset again. If it holds, trip the GFI by pressing TEST button. The RESET button should pop out. Reinstall the outlet and make sure the wires are not crushed or cut. Press the RESET button again. If it trips, you will have to remove the outlet again and take more precautions against damage to the insulation. it is also possible that the GFI outlet itself has failed, in which case it should be replaced.
GFI circuit breakers and outlets are supposed to be tested monthly by simply pressing the TEST button and then the RESET button. Replace any GFI device that does not test correctly if wiring and devices / appliances connected are OK.
I hope this helps & good luck! Please rate my reply - thanks.
Jan 05, 2012 | Hammering
Our Magic Comfort plus is 4 years old and it keeps blowing the gfi instantly when I plug it in. I have had this problem occassionally in the past and it resolves after one or two gfi trips. Now if tripo...
The problem believe it or not your gfi is warn out. I am actually surprised it lasted as long as it has and surprised it worked at all. Espresso machines use a huge amount of power when turning on compared to maintaining power. When espresso machines first turn on the take a huge surge of power to start heating up the elements. Normally you want to put an espresso on a circuit /outlet that is directly to your breaker that is at least a 20 amp breaker. By code kitchens and bathrooms, where an outlet is near water, has to have a gfi outlet, this is for safety for something plugged in near water so it will trip if accident happens with appliance near water. The bad news there not to good with high demand power appliances such as espresso machines. Yes , you can replace the gfi circuit, by turning off main breaker, unscrew gfi from wall, pull out, and undo wires, and copy exactly when re-wiring the new one. Then turn on main breaker again. NOTE: you can buy a gfi all most any home improvement center, lowers, home depot, ace hardware etc.... Think of a gfi kind of like a advanced in line fuse, they do wear out. BUT AGAIN, my advice is plug it in a outlet that does not have gfi and is on a main breaker of at least 20 amps if you have that opportunity to do in your kitchen area. Hope this helps you, thank you....... MIKE
Jul 26, 2011 | Saeco Magic Comfort Plus Espresso Machine
Hi, I have a Kenmore top freezer refrigerator model number 363.79567990. The freezer stopped working and I found out that I had to press the "Reset" button on the outlet while it was unplugged...
It sounds like you've plugged your fridge into a GFI (ground fault interrupter) outlet.
The National Electrical Code (NEC) article 210.8 A (6) says in dwelling units, only those outlets in a kitchen (I'm assuming your fridge is in the kitchen - right?) "where the receptacles are installed to serve the countertop surfaces" must be provide ground fault protection aka "GFI outlet". Unless your town, city, county or state has laws that supersede the NEC, you should have the outlet changed to a standard, grounded outlet to prevent the nuisance tripping you are experiencing when the cooling compressor is trying to start. A refrigerator is not a counter surface appliance, and therefore does not require GFI protection.
The other outlets are fed from this outlet, so when you connect the fridge to another outlet on the circuit, the same GFI plug trips again. When you replace the GFI plug with a "regular one, the GFI plug should be installed in another outlet to provide the GFI protection needed in the kitchen - as described in the NEC above. If you are not familiar with how to do this, please, call a licensed electrician to do this very important job for you. Be safe & be smart.
I hope this helps!
Nov 01, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Jun 01, 2009 | Whirlpool ES5FHAXS Side by Side...
GE XL44 Broiler/Self Clean Trips GFI
This should be a 220 volt appliance so I'm trying to figure how this was connected to a GFI. Does it have a second connection to power the controls?
Most GFI uints I have seen are not rated for large amounts of power consumption. I used to throw the one in my bathroom if I was running the electric heater and the wife fired up the hair dryer.
I'm wondering if this indeed does require the additional 110 connection then it sould be pulling heavy current from it to aid in the cleaning process. I've never seen a stove that needed the extra. My old electric range had only the 220 as well as my elders.
So if that is the case then you should not be running that through the GFI outlet because of the heavy drain will heat the breaker in the GFI and cause it to trip. Breakers actually work very similar to how the old fuses work. Heat causes the switch to throw. GFI units have a lower tolerance (designed to detect shorts quicker to save your life) and trip quicker than breakers do.
Apr 02, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Keeps tripping GFI outlets
The key here is to identify the problem as being either the coffee maker or the GFI receptacle... a simple test can be done as follows...
Try plugging the Coffee Maker into another GFI receptacle .. you may have one in the bathroom? If it trips that too, then you have an internal wiring problem with your coffee maker.. if it doesn;t ..then your GFI receptacle may be bad or on the verge of going bad .. either way..this should narrow the problem down to one or the other.. hope this helps..
Aug 30, 2008 | Keurig B60 Coffee Maker
Refrigerators Logo
80 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
