Whenever I try to print, I get a message that there is more than one ink cartridge of the same colour (black). That's how it's supposed to be and this was not a problem when I used the printer from new in the first 6 months. THe error message says that only one ink cartridge should be used each time suggesting that there is nothing for me to do but merely a warning message that it will only use one of the two black ink cartridges. When I click OK, the message reappears and I am stuck in a loop with the only option being to cancel the print job. I reinstalled the printer twice so far with no effect.
Can anyone help?
Comments:
Aug 05, 2007
- Thanks for posting a reply informatica! Just tried taking them all out and re-inserting them in the right order but I still get the same message. I used only Canon original tanks and recently re-filled three of them (but not the "problematic one")
-   Yes. I have got the same problem. More than one Cyan in my case. I take out the inktank and put it back. This sometimes work. Other times I lose patience and shakes the printer; and the problem is solved until the next print !!
I'm very near to buying a new printer !!
Erik Denmark-   ErikStorm
There are 2 types of black cartridge, CLI-8Bk Black Ink Tank & PGI-5 Pigment Black Ink Tank. These must be installed in the correct order as below. Have you replaced a black cartridge & perhaps used a different type?
Hi My printer is not taking paper and it seems the roller that feeds is not working. the light...
(More)
Hi My printer is not taking paper and it seems the roller that feeds is not working. the light flashes 11x which I saw means 'ap position error' does anyone know if this can be repaired? Or how? Many thanks,
Pixma ip5200 has mail lable wrapped around roller and is printing white streaks on printouts. How to...
(More)
Pixma ip5200 has mail lable wrapped around roller and is printing white streaks on printouts. How to remove and clean or replace roller?
I have just changed the ink cartridges but the printer is not used for quite some time. After it is...
(More)
I have just changed the ink cartridges but the printer is not used for quite some time. After it is switched on, all seems normal except that the printer can't form feed the paper to print. The papers are placed properly and print job is in order, but even I have reset the printer a few times, it still does not print. Please advise the solution. Thanks.
Whe I try to open the CD Lable print program this message appears in a box on the screen I used it...
(More)
Whe I try to open the CD Lable print program this message appears in a box on the screen I used it Yesterday morning without any trouble suddenly it hangs up after I used Task Manger to quit the program I restart my computer re-install the printer drivers etc but is still appears when I'm trying t locate the program to print on the CD's please I'm stying in Sout Africa. nicolene.heydenrych@gmail.com
I have a Canon Pixma iP5200R which has been going great up and until now! Now the print outs are...
(More)
I have a Canon Pixma iP5200R which has been going great up and until now! Now the print outs are coming out in colour but with purple tinge. Checked all cartridges - switched off computer and printer and restarted. This solved it for about 5 print outs, now it is back. Why?
