Question about Home Security
Genie sp99 cannot find adjustment screw on genie sp99. Can you tell me where it is?
My Genie CM8600 garage door opener runs, but prematurely goes back up. No obstructions, settings adjusted on power head-- maxed out. It seems like it reacts to resistance. Is the motor just old? I r
Try manually disconnecting the door and run the mechisim up and down using the opener..see if it runs the entire length up and down... If it does it most likey the door or its mechinism is binding...good luck
Dec 06, 2014 | Genie Pro Screw Drive Garage Door Opener...
Genie 900 door operator
hello,there is an adjuster on the side of the motor,also check that the micro switch[if fitted on your particular type} is 'clicking' and actually in contact with the arm as it revolves closed. hope that helps, cheers
Jun 02, 2014 | Genie PowerLift 900 1/2 HP Screw Drive...
Genie trac drive
Over time, grime gets into the tracks, lubricant gums up in the rollers, and more pressure is needed.
On the ceiling mounted motor unit, there should be a pair of adjustment screws.
On my LiftMaster, they're labeled "OPEN FORCE" and "CLOSE FORCE".
These will increase the force exerted in the respective direction.
Make sure you are not adjusting the two screws that control the travel limit.
Adjust a LITTLE (like 1/8 to 1/16th of a turn at a time) and test before adjusting further.
Oct 07, 2013 | Building Materials
Answer to riddle about 2 genies
Ask Genie #1 what Genie #2 would say, then do the opposite. You are in essence asking in one question of a truthful Genie what the untruthful Genie would do, or vice versa, so you must receive an untruthful answer.
Mar 23, 2013 | Cars & Trucks
My nes will not turn on without a game genie, whats happening???
I think that the game genie destroyed the console then so don't use any game sharks or game genies as they screw up the consoles Nintendo made it so you can't cheat then on their games so fair and square us how I do it then
Sep 09, 2012 | Nintendo NES Console
Genie auto garage door. closes then imediately re...
GET A COPY OF THE ADJUSTMENT INSTUCTIONS FROM THE GENIE WEB SITE - IT IS A SMALL AND SIMPLE ADJUSTMENT - BUT, IF YOU MESS IT UP THE DOOR WOULD BE UNSAFE.
May 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Opener only raises the door one foot.
IF THE DOOR IS BALANCED TRY ADJUSTING THE SENSITIVITY.
THE DRIVE SHOULD BE LUBED WITH WHITE LITHIUM OR GENIE LUBE 2 TIMES PER YEAR TO KEEP THE UNIT QUIETER AND PREVENT EXCESS WEAR.
IF YOU USE THE WRONG LUBE - GREASE ETC. THE UNIT WILL GET GUMMED UP AND WILL HAVE PROBLEMS IN COLD WEATHER.
ONCE YOU ADJUST THE SENSITIVITY YOU SHOULD BE OK.
Aug 24, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Genie garage door openner won't stop when it goes down or up
there should be a "travel distance" adjustment screw on the opener.
Apr 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
35 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
