Question about Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
Hoover SteamVac V2 - won't release water
We've had the SteamVac for a couple of years and had no problems with it. Recently, however, the water has stopped coming down. The detergent releases just, and the vac sucks up the detergent to the waste bucket , so those mechanisms work fine. Has anyone run into this problem? What was your solution? Thank you!
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
Re: Hoover SteamVac V2 - won't release water
Sorry this is so late. the problem might be that the tubes are clogged. after each use most people just put the machine away. in most cases the soap is still in the tube,and when it hardens it clogs the tubes. after each use you should run clear water to get rid of any soap in the tubes before putting away.
Posted on Feb 10, 2008
0 characters
3 Points
Hi my hoover f7425-900 is not releasing water from the clean water tank but the detergent is being released can you help me? thanks
The most common reason for this problem is that the solenoid operated valve on the rinse cycle has failed, and is not opening. The solenoid assembly will probably require replacement.
Mar 21, 2011 | Hoover F7425-900 SteamVac V2 Widepath...
I have a Hoover v2 steam vac F7430-900 the water container will not dispense water only soap yes, any idea to fix this problem?
This is most likely due to a problem with the solenoid on the rinse side not opening. The solenoid may require replacement.
Jan 17, 2011 | Hoover F7425-900 SteamVac V2 Widepath...
I have a Model F7431-900 and is a SteamVac V2. When I press the trigger for water or cleaning solution, the water just runs right through it even after releasing the trigger. What kind of problem do I...
This sounds like a stuck solenoid. The Dual V models use solenoids to contol soap and water flow to the floor, along with a pump unit. If your unit is 12 months or less it is under warranty. I am not sure about the cost of the solenoid.
Apr 14, 2010 | Hoover SteamVac V2 6-Brush Widepath...
I have a Hoover V2 Steam Vac widepath and the
This is a notorious problem with the Hoover V2 SteamVac's. In fact the tank design by Hoover on your SteamVac was so bad, that Hoover redesigned this tank almost immediately due to the numerous problems customers were having.
For your particular problem, you really have two options. The first option is putting a bandaid over the problem, but will still fix it. We sell the entire gasket assembly on the bottom of the detergent tank as a replacement part. Unfortunately it's sold together with the seal, spring, and valve together as an assembly;
You also may wish to fix the problem completely by replacing the entire clean water solution tank. Hoover has redesigned this tank, and the new one I don't see near the amount of problems that I do on the older style tanks. The plastic is much more sturdy, and less prone to having the gasket and valve issues that the old tanks do. It's important to point out that the new tank does not come with the handle. You'll need to remove the handle from your old tank if you buy a new tank assembly complete. Rest assured that if you do purchase any part from GoVacuum, you'll have 60 days to return it for a full refund, just in case the repair doesn't work. Not only do we not deduct restocking fees or shipping charges, but we also include a return label with every order that you may use to return any item to us, and we'll even pay for your return shipping!
Here's the Hoover SteamVac V2 Clean Water Solution Tank, Part 12002549
If you'd like us to do a repair photograph series on this repair of the valve and gasket assembly, please just request a repair clarification here on Fixya, and we'll be happy to do so. If you found this helpful, please be sure to rate the review as helpful by clicking on the 4 Thumbs Up Icons in the top right hand corner of the repair.
Thank you so much,
Chris J.
Mar 23, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
Need directions
This is an older model Steam Cleaner. The upper tank, fill with hot tap water up to the fill line, then add 5 ounces of carpet solution to the water using the upper cap to measure. Make sure the lower letank is secured and turn it on, tilt the handle back, pull trigger to release solution to floor going forward, then release when pulling back slowly to extract. I am not sure if the manuals are available online, however you may be able to locate a Hoover dealer which may have a digital copy. They can be found through the
Jan 19, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover V2 SteamVac
Under the detergent side, there is a metering plate,(located on the machine) which can be removed. ensure that this is installed. have you verified whether the machine will dispense detergent only without any water in the water tank?
Jan 03, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
#for hoover steam vav ve with rinse
Here is a link
Or go to, scroll down and on the left click on downloads, enter your model number and a pdf. file will come up that you can download.
Jun 10, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Need help!!!!!
Need help!!!!!
Hoover F7425-900 SteamVac V2 Widepath Upright
I read the manual and tried my new Hoover, the brushes spin, but the waters not going to the bottom tank, what does that mean and what can i do?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You could have a bad water release valve on your water tank of which holds the water, the trigger assm might not be connected, bent or broken. Check the trouble shooting owners manual --- also there are hoses that could be crimped or bent, or clogged or not connected, but it is my guess it is the water release valve. Try to back track the water from the holding tank and test all the valves on the system and you might find the problem by the process of elimination. Feel free to contact you local vacuum cleaner dealer in the yellow pages or contact the Hoover Co @ the information listed below: Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Apr 22, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover SteamVac
My Hoover Steamvac won't puo=ll out the water when I try to cleean the carpet. What do I need to do?
Dec 30, 2007 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
Replacing valve on water tank on hoover steamvac
buy the whole tank not worth the time to repair the valve
Oct 08, 2007 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
Hoover F7205900 SteamVac V2 Wet/Dry Vacuum Logo
353 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
