Question about Garden
Penncraft parts edger parts
Cannon penncraft cannon work
Get two short extension cords and cut the FEMALE end off each one. Strip back the insulation on that end. Connect the two green wires to each other, and connect the two white wires to each other.
Connect one black wire to a light switch, and connect the other black wire to a 20W appliance-type incandescent light bulb. Also run one short black wire (from a cut-off end) from the second terminal on the light bulb to the second terminal on the switch, like so:
plug -- black -- switch -- black -- bulb -- black -- plug
plug -- white ----------------------------------- white -- plug
plug -- green ---------------------------------- green -- plug
Turn the switch to the OFF position.
Start the generator. Plug one plug from your new rig into an outlet on the generator. Plug the other plug from your new rig into a wall outlet supplying 120V. With the generator running, turn the switch to the ON position.
The bulb should flash for a short while, then become steady. When it's steady, that side of the generator is flashed. Repeat for the other side of the generator if it makes 240V.
Jul 12, 2014 | Electrical Supplies
Fc-44 edger/ I need a handle
The part number you require is 4130 790 1300
I have the complete IPL, message me if you would like to have it.
May 26, 2013 | Stihl Edger Spare Parts List Manual Book...
Looking for the part number of the air filter on craftman edger model # 53685648
On the Sears Parts Direct, they show no air filter. I would recommend taking the filter to a small engine shop so they can match it up or just go to Home Depot and match it up with one of their filters they may have in the lawn and garden. Lowes has a small engine section too, most of their stuff is Briggs and Tecumseh. Here is your parts diagram, with no air filter shown.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Edger-Parts/Model-53685648/0247/1503400?sid=PDVertical
Aug 13, 2011 | Craftsman Gas Mini - Tiller/Edger
Black and Decker 2 HP Lawn edger
Ditch that old switch, and buy a better quality switch from HomeDepot or RadioShack that will suit your need. I personally ran into that same problem and brought a 2HP GP switch from HomeDepot. It works way better, than that stock swicth. ( It may require a little modification to the body though.)
Mar 28, 2010 | Black & Decker 14" Grass Hog Xp...
Part
Your part number for the belt is: MTD 954-04032B
You can get a belt fairly cheap by going to this link: http://www.jackssmallengines.com/searchdb_more_info.cfm?part_num=265252&format=searchdb
Feb 10, 2010 | Mtd 25B-520D200 CA Gas Lawn Edger
Seeking YardMan Landscape Edger Blades
Locate the model number of your machine and click here.
In the center of the page, click on "Launch Illustrated Parts Look-Up Tool".
Enter your model number and click "Search" to find your part number. You can order the part direct using "Quick Order" on that site.
Hope this helps.
Sep 29, 2009 | Yard Machines Red Edger
I need to replace a belt on a craftsman with a 42" deck.What size belt should I get.What length.
Craftsman is made by Murray Corp. who also makes Murry, YardMan, Lowes, Penncraft, and on and on. Go to your local Wal-Mart, Lawn and Garden Dept. and look for the belt that fits the Murray, YardMan, Lowes, Toro, 42" Deck 14-18 HP. Or take your old belt with you, and stretch them both end to end holding the end loops with each hand. Or you could go to Sears and just tell the parts department what your mower is and they can get you a Craftsman belt. It will be the same one you get at Lowe's, Wal-Mart, ect, probably just cost a little more. Sears doesn't make mowers, they just have their colors and names put on by the manufactorer. And Murray of Ohio is the maker of these.
Sep 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need parts for craftsman edger/trimmer 275.796432
Here's a link to sears parts website
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080129x00001
Mar 21, 2009 | Garden
Garden Logo
83 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
