Question about Philips LaserMFD 6020 (LFF6020)
Philips mfd6020 Printer error , mirror
Is there a way to get screen mirroring to work with my Philips 55 pfl 4909/f7
Miracast Samsung - Philips - Support Forum
www.supportforum.philips.com > Forum > TV Forum
Jan 2, 2014 - 13 posts - ‎8 authors
I have a PHILIPS 42 PFL 5008H and a Samsung Galaxy S4 ... Samsung havecompletely butchered Miracast support on their ... Now my TV not seeing sgs4 onscreen mirroring but see it on wifi ... They answered me that the miracast function doesn't work with Philips TV ! .... Last Post: 07-11-2014, 11:55 AM ...
How can I do screen mirroring from my Galaxy S6 to a Philips HD ...
forums.androidcentral.com > ... > Samsung Galaxy S6
Apr 12, 2015 - 14 posts - ‎9 authors
First of all I dont know how to enable screen mirroring on my TV. ... You'd have tohave a compatible Samsung Smart TV in order for the built-in wireless screen mirroring to work. ... I have a Samsung smart TV and I tried to connect my phone to it last night. ... If it doesn't, the Chromecast is the best choice.Missing: 55 ‎pfl
Jan 08, 2016 | Philips Televison & Video
I have a brother mcf-8840d with an error code 71. Any thought on what to do?
Your Error 71 means that the mirror motor can't synchronize with the brains of the printer. The problem is most like the motor bearings, meaning you need an new Laser Scanning Unit (LSU), or it could be the main board acting up
Jun 29, 2008 | Brother Office Equipment & Supplies
935 service printer head error. how do I fix it?
The Mirror Motor of the printhead is unable to reach operating speed. This means you have to replace the printhead.
Mar 08, 2011 | Lexmark Optra M412 Laser Printer
I HAVE REPLACED IT WITH A NEW TONER AND IT IS SAYING REPLACE TONER CARD I HAVE A PHILLIPS LASER MFD6020
Try disconnecting the printer cable and power cable for about 30 seconds. Reconnect and the error should go away.
Jan 27, 2011 | Office Equipment & Supplies
RICOH SPC430DN error sc202
sc202 is a polygon mirror motor. The most likely problem is that the motor has gone bad, and it will need to be replaced. Occasionally this error is caused by a loose or disconnected cable, but it is usually a bad mirror motor. You should contact your local service technician for replacement of the polygon mirror motor.
Nov 18, 2010 | Ricoh CL4000DN Laser Printer
I am trying to do scanning on my laser mfd6020 but nothing is happening, please help !
Hi. What is the operating system (Windows XP, Vista, 7 or Mac, Linux) you are using? Is the printer working properly? What error do you get when scanning?
Thanks.
Jun 15, 2010 | Office Equipment & Supplies
How to rectify the the 52scanner error turn off and turn on in HPlaserjet printer
clean the scanner assembly lens with soft cloth. remove the scanner rotating mirror.handle with carefully.you can see a small lblack color latch while removing the rotating mirror. clean the coil contacts & inner magnetic part of the rotating mirror.
Oct 15, 2009 | HP LaserJet 2420 Printer
I have a Lexmark T632 that is used very often. Constantly printing over 1000 pages daily and I always get the error message Print head Error 934 - Lost Lock condition but once I shut down the printer and...
These error codes indicate a problem with the mirror motor circuit in
the printhead assembly or the mirror motor cable to the system board
cable or system board assembly. Check the continuity of the mirror
motor cable connected to J5 on the system board. If incorrect,
replace the cable. The voltage at J5-7 measures approximately
+24 V dc. If incorrect, replace the system board. If correct, replace
the FRUs in the following order:
• System board
• Printhead assembly
Dec 10, 2008 | Lexmark T632 Laser Printer
HP Laserjet 3055 with "scanner error 6 - turn off and on" error
hp laserjet 3055 by scanner error 6
Solution: I found a very small piece of paper between the glass and the scanner housing. The lamp's seen that and sent the error message. Nobody find that little stucked paper and the "IT expert" sad: need to buy a new machine because he can't repair it. So, sometimes the solution is very easy just need some attention. :)
Apr 27, 2008 | HP LaserJet 3055 All-In-One Printer
LSU ERROR shows in display panel
The LSU is the Laser Scanning Unit or "printhead". There is a mirror in there that spins really fast, if the mirror spins too slowly (bad motor, low voltage) it gives an error. Sounds like you would need a replacement LSU. Have the printer serviced.
Jan 02, 2008 | Dell 1600n All-In-One Laser Printer
Philips LaserMFD 6020 (LFF6020) Logo
19 people viewed this question
Top Philips Office Equipment & Supplies Experts
matt martin
matt martin
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
