Question about Air Tools & Compressors
Rol-air air compressor
The wiring has been taken loose and need to know how to put back together.
JSEhandyman
  • 368 Answers
SOURCE: how to put together living air alpine bora III air purifier?
Hi Tlwynn,
The grid part of the screen should face the fan. The O3 produced by the cold-plasma discharge is what attacks the odors, and you want the fan to blow it out of the machine.
Make sure the spring-steel contacts are touching metal on both sides of the plate.
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance,
Jon
Posted on Dec 28, 2008
TheMobilian
  • 8220 Answers
SOURCE: TIMER WIRE DIAGRAM
Just attach the green wire to any screw closeby. Nothing could be simpler. Look closely and you will find a small male terminal to connect the green wire in some models.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 13, 2009
SOURCE: How to put back together a smith & wesson air soft rifle
ooof i know how to put i back together and can teach you but its a doozi over the net. hows your experiance with airsoft internals also wat type of gun is it (spring gas aeg etc shotgun assault rifle pistol etc. email me @ levis_lalancette@yahoo.ca i can help you further with that info
Posted on Aug 04, 2009
  • 48 Answers
SOURCE: Need instructions on how to put it together again.
send me your fax number so i will send manual
Posted on Nov 23, 2010
  • 7 Answers
SOURCE: my son has taken apart
Below is a internal picture of the stampede.
Contact me at mohammad7597@hotmail.com
Posted on Jan 08, 2011
My 1/4inch kobalt air die grinder was taken apart how do i put it back together?
Brian, I can not tell you how to put it back together, but I can give you a tip for next time, Take pictures as you are disassembling and tag parts.
Show your appreciation by pressing the helpful button and follow me on fixya for more info and tips
Feb 17, 2016 | Air Tools & Compressors
Air leaks continuously from bleeder valve on my rolair pancake compressor is it the bleeder valve or pump switch?
It will be the "Bleeder Valve" or it is more commonly known as the Check Valve, this valve is normally located going into the tank or connected to the tank, the pipe goes from the tank to the pressure switch, it normally sounds like air is coming from the pressure switch but its actually the check valve i mentioned.
First of all, make sure the tank is totally drained of air and the compressor is not plugged in. Next, unscrew the check valve top, and remove the spring and valve. Have a look at the seat of the valve, to see if the seat is damaged, clean it (if necessary replace it with a new one) then check inside the housing itself to make sure there is no dirt etc inside, clean it, then put it all back together again.
That should do it, this happens a lot on these smaller compressors
Mar 14, 2013 | Rolair Rol-Air Fc116022038 Valve Mk246
1994 gmc seirra air conditioning compressor wire diagramn
It should be one plug by the pulley and on plug on the back of the compressor,if you replaced the compressor sometimes you have to remove the rear sensor off the old compressor and install it on the new one, hope this helps
Jul 14, 2012 | Heating & Cooling
What grade oil do I use to change out on my Chicago Pneumatic RPC-561VNS? The manual says a compressor grade non-deturgent oil should be used, but does no specify a grade.
Hi and welcome to FixYa, I am Kelly.
Compressor grade oils are basically SAE30 W oil. Read this:
Rol-Air OILCOMP30W34C Air Compressor Pump Oil - 30W Quart features ,
Specially engineered and tested to match the requirements of Rol-Air air
compressors , Provides superior rust and corrosion protection.
I.e SAE 30W oil / the same thing you would use in an older lawn mower engine or generator.
What they don't tell you is because they have re-labeled the 30W oil to OILCOMP30W they can charge you big time for SAE 30W oil. The only difference is the label.
Thanks for choosing FixYa,
Kelly
Sep 22, 2011 | Chicago Pneumatic 60Gallon TwoStage Air...
How do i change my craftsman 919165200 air compressor from 120v to 240v?
Your Craftsman model 919.165200, 5hp, 20 gallon compressor was designed to run on 115~120v 15amp. I believe that it was made by Campbell Hausfeld and is of the oilless single cylinder type. If however your compressor is oil lubed and has a motor /drive belt configuration it may be able to convert if there is a spec plate on the motor with alternate wiring diagram. Many high-end compressors like Rol Air, Jenny, Dewalt, etc with motor/belt drive have a switch selectable voltage, however one must still change the power cord when using 220v. Good luck with your projects and post again if your have other question.
Aug 02, 2010 | Craftsman Air Tools & Compressors
Replacing electrical cable on Air conditioner
there sre clearly 2 sides on top of the compasitor one wire to apost on 1 side and 1 wire to a post on the other post sides are seperated by a L shape one of them of coarse would b a backwards L those are your 2 sides
May 24, 2009 | Heating & Cooling
Makita MAC 5200 3 HP 5.2 Gallon electric compressor
Use non detergent air compressor oil. It can be found at Lowes, Homedepot, and even Walmart. It is sold in small containers for about $2-3 dollars. A synthetic blend air compressor oil is needed when the unit is used in severe conditions. Synthetic air compressor oil sold at Lowes $6.95 and other stores will take more heat. Second choice is 30w non-detergent motor oil. Engine oils tend to produce carbon on the reed valves in the head if used extensively. I have been using the Lowes Kobalt brand of air compressor oil for some years in my Makita and Rol Air compressors with good results. The part number for Makita brand of oil is 18112-A quart size. It is only available by special order where I live. Good Luck!
Feb 22, 2009 | Makita MAC5200 Electric Powered Air...
2008 lincoln town car air sup pump
Back is ground and green does it have a stripe on it if so what color is the stripe yellow if so thats
your hot line.Hope this helps you, The other ones are for the sensors
Sep 04, 2008 | 1991 Lincoln Town Car
Air Tools & Compressors Logo
18 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
