Question about Cisco Linksys WRT160N Ultra Rangeplus Wireless N Broadband Router Really Three Devices In One Box
MSG_100_000_000_000 the linksys easy advisor is not open
  • 174 Answers
Try to close Linksys Easy Advisor and then re-open it.
Posted on Apr 26, 2013
When i try to open linksys advisor it says i don't have administrator privlages
just reset the router to factory defaults follow the instructions that came with it. there is a pinhole reset on it, with the power on get a pin or something thin and insert it into the hole and push and hold the lights should go off briefly then start flashing again the try the advisor again with the default username and password usually admin for both.
Jan 23, 2011 | Linksys Wireless-G WRT54G Router
Error 321
Are you trying to connect a computer to the network or it is another wireless device.
For this you don't need to use Linksys Easy link advisor.
All you need to do is, open the router set up page and check the settings of the router.
according to the settings on the router, you can connect the new device to the network.
is ther any computer connected to the router?
use that cmputer to open the router set up page.
Apr 26, 2010 | Linksys WRT160N Wireless Router
Linksysfix/ela does not work
reset you router with help of reset button and re - configure your router again.
Apr 16, 2010 | Linksys Wireless-G WRT54G Router
Linksys WRT350N Connection Problem and Power Light Flashing.
Are you trying to set up the router ? For this you don't need to use Linksys Easy link advisor. Easy links advisor has bugs in it. If you call the Linksys tech support, they will also not help you for Easy link advisor. All you need to do is, open the router set up page and check the settings of the router. according to the settings on the router, you can connect the new device to the network. is ther any computer connected to the router? use that cmputer to open the router set up page.
Apr 06, 2010 | Linksys WRT350N Wireless Router
My wrt150n router cannot see the internet which is working. when I start setup in easylink advisor it establishes a new connection but I cannot see or manage it in advisor. Any ideas
Well ! this easy link advisor is not a good software to manage the network. It has some bugs. Some times even if you are able to go on line , it will show you that the router is not online. If you call the Linksys technical support, you will not get any technical support for the Easy link advisor. Even the Linksys is also not using Easy link advisor. They have a new software now called as network magic.
If you are not able to go online using the router, then you can try to set up the router maually. Ou don't need any CD or Manual or any software.
Click here for more information about router set up
Mar 24, 2010 | Linksys Wireless-N WRT150N Router
I have tried to install Easy link advisor and i keep getting an error message. (MSG-100-000-000 Unhandled error see Lela) but i cannot get to the help menu. Any thing that I am doing wrong? Thank You,Karl
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 17, 2010 | Linksys WRT160N Wireless Router
Linksys Easylink Advisor will not open up. I am trying to get in to add a new device.
advisor.
Click here for more information about routers and
network
Jan 13, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
WRT300N is no longer detected
Hook up your ether cable to a port other than the WAN port.
Type this into a browser...
http://192.168.1.1
Linksys WRT300N Wireless Router. ... Default IP address: 192.168.1.1
Oct 01, 2009 | Linksys WRT300N Wireless Router
Printing my network settings
When you have the settings on your screen. Hold the Ctrl key down on the keyboard & press the Print screen key on the keyboard at the same time. Open windows paint program. Click edit & than past. Now you can save the image as a .bmp file. Name it as you like. (This is called a work around).
Jan 25, 2008 | Linksys Wireless-G WRT54G Router
Open Questions:
Cervical Cushion- Pillows for Neck Pain Are you a very sedentary person? Do you have a classic office job and are 8 hours or more sitting in front of a computer? Then you most likely suffer from cervical pain. Cervical pain means having severe pain in the neck area because of an incorrect position of our cervix for quite some time. The cervical block or its numbness is due to the unnatural compression of the vertebrae. In this guide you will find all information about cervical pain, how to prevent them and how to cure them, but above all you will learn how to choose your cervical cushion that will help you lessen the pain or make it disappear completely. In the following table you will find some models of cervical pillows that can be found on the market, along with some of the major features that distinguish them. How to Choose a Cervical Cushion Since on the market you can find a great multitude of cervical pillow models, choose the most suitable one and certainly not a small business. First of all, choosing the most appropriate one is to understand what pathology you are suffering from. Although we often call it neck pain, cervical is not always the same in all cases. In this regard, it is understood that not everyone can use the same cushion. There are cases where the patient needs a more flexible pillow, others where there is a need for stiffer material, so before buying your new cervical cushion it would be interesting to consult your trusted physician, who can visit you and decide for you what is best suited to your pathology. Another factor could concern the price, but being in the medical field I recommend closing an eye on this item, ten euros more or less are nothing when it comes to health. Moreover, the price is directly proportional to the quality of the material used and of course there are materials that cost more than others. So as you see there are several factors to consider. Take care of all the advice you'll find on these pages and you too will be able to make the right choice. What is cervical pain and remedies? The area of ??the cervical vertebrae is that portion of our body that accuses so-called cervical pain when our neck or our head is in an incorrect position for several hours. This area is very important for our health and our well-being. In practice it connects our body and especially the spine to the head, with all the nerve endings that pass right in this particular area and very sensitive. When this area is subjected to a continuous stress, we do not only pain neck pain, but we also compromise the proper functioning of the head movement. Very often the pain becomes so strong that besides affecting the neck, it moves to the upper shoulders and joints, causing the famous head turns and also nausea. In the most severe cases a capatina is recommended by your doctor. Among the various factors that can trigger these severe pains are incorrect posture or an improper pillow. At the origin of this evil, however, there are also muscle contractions, trauma and stress. For this reason, the cervical pillow was born, which relieves the pain and allows the neck to be in the correct position. Structure, shape and material are designed to fit perfectly to the shape of the neck, sustaining it and giving it relief.
Oct 23, 2017 | Major Computers & Internet
See all Cisco Linksys WRT160N Ultra Rangeplus Wireless N Questions
Cisco Linksys WRT160N Ultra Rangeplus Wireless N Broadband Router Really Three Devices In One Box Logo
55 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
