Acer am5100-b5301a No boot, no beeps fans run but cpu fan vibrates at boot
  • 998 Answers
SOURCE: No display and wont boot
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Power supply is easier and cheaper to replace.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 12, 2008
  • 3 Answers
SOURCE: computer wont boot hear one beep from motherboard over and over
If your power supply is bad, there is typically a much cheaper way to fix it rather than purchasing a new one.
If you know a little about electronics or know someone who does have them open up the power supply and check the capacitors. Often times when a power supply goes bad its the result of capacitors going bad.
If you notice on the ends of any capacitors a brownish/whitish discharge or "bulging" then the capacitor has gone bad.
A new one typically cost less than a dollar and replacing it is fairly easy if you know how to solder.
Let me know if you have anymore questions and hopefully if this is the case you can save some money.
Posted on Feb 23, 2009
hotratchet
  • 952 Answers
SOURCE: CPU fan runs at high speed and won't boot
Change the setting in the BIOS menu. reboot your computer.. when you see the dell logo.. press F1 (or F2 if F1 doesn't work) button until you see the BIOS screen. Check for fan options and change it
Posted on Jun 20, 2009
  • 11 Answers
SOURCE: Acer Aspire AST690 won't boot, just beeps.
99 times out of 100 it is a memory problem. You need to clean up the memory and try it in a different slot and the same slot and it should wokr
Posted on Aug 30, 2009
SOURCE: Acer Aspire AM1640-U1401A has black screen-@ boot attempt.
Had this issue with two Acers of similar make. Replacing the Motherboard resolved the issue on both.
Posted on Mar 11, 2010
Trys to start but doesnt
The bios keeps track of all mechanical s pre-boot and post-boot. Beeps most generally mean a bad stick of ram or the ram is not seated firmly in the slot. The other issues are bad CPU or the CPU fan has stopped and the bios shuts the pc down in either case.
Apr 21, 2014 | Acer Computers & Internet
Acer am5100-u5300a
This motherboard is strange in that when the CMOS battery dies, it wont POST and wont have video output. Just replace the CMOS battery and it should work again. And also set the new date+time.
Jul 04, 2013 | Computers & Internet
Computer won't do anything, keyboard does not light up, screen is blank
So there is not so much as a BIOS message on screen? Any beeps?
If there is no life at all, you have a CPU/motherboard failure. This may be direct or indirect (e.g. no power to MoBo). Check your connections.
Otherwise, your boot device may not be operating. This is usually a dead or disconnected HDD. Check that it is plugged in. Does it get warm? Can you feel any vibrations from it? It should spin even if your cpu is dead but MoBo is alive.
Oct 26, 2012 | HP Compaq Presario SR2038X PC Desktop
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
Acer aspire l100 will not boot but fans run
Try removing/disconnecting the hard drive and see if the BIOS boots up, if it does the HDD is causing the problem. Are you getting any beeping codes on start up, if so how many and hoe long in between?
Dec 06, 2011 | Acer Aspire L100 PC Desktop
Continuous beep and the systems is not coming up {boot}
Hardware problem:
* dead RAM
* dead video-card
* RAM not fully "seated" in its slot(s)
* video-card not fully "seated"
* dead fan on top of the CPU/heatsink.
* failing power-supply.
Jul 12, 2011 | HP Compaq dc5100 Small Form Factor PC...
My Acer PC make a lot of whirring noise at start
check the screws ...all the screws, from power supply to the ones from your dvd. maybe one is coming out. or the cpu cooler can have the same problem.
Nov 16, 2009 | Acer Aspire M5100 AM5100-U5313A AMD...
Power to everything but CPU fan and case fan - won't boot
Hi this is tech crazy
The solution to the problem is as follows
The main reason for CPU fan overworking or not working is due to the load we put on the syatem while operating.So,the first reason for fan not working may be due to the SMPS malfunctionality.Better check out for it.The reason if fan is working but Overworking is due to viruses is system.So go in for format
Hope this solution helps you
Please do rate me on the above said solution
Feb 04, 2009 | Intel Motherboard
Not booting but RAM,processor,SMPS ,HD are fine.
Check without Video Card, Processor , Memory and beeps are coming
If no then this is motherboar issue, I had the similar problem. So went to the local repair shop and got the power capacitors replaced,
Jan 29, 2009 | Asrock P4i65GV Motherboard
Friend has a Emachine T1862 that won't start
May be the CPU fan is going bad. I hope it is that simple.
Dec 14, 2008 | E-Machines Computers & Internet
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
