Question about Garden
Where do I find replacement Agitator (R540-21) and Agitator Hairpin Cotter (r540-32)
My Ez broadcast spreader is in "ok" condition except that the agitator broke and I need to find a replacement part. Since Republic no longer makes this spreader, does anyone have any recommendations
4 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: lost agitater for my Scotts Spreader
I replaced mine with a clip-in cotter key, the kind they use for farm implements to keep a pin in place. I bought a stainless steel one at Lowe's for ~$1. Works at least as good as what I had.
Best regards, --W/D--
Posted on Aug 08, 2009
SOURCE: repair parts for a Republic EZ Broadcast Fertilizer Spreader
I have a problem with a broken handle it looks like there is no parts for the EZ Broadcast Spreader. The sad part is the rest of the unit is in great condition.
Looks like plan obsolescent!
Posted on Dec 16, 2009
Spinnnoz
  • 12 Answers
SOURCE: Republic EZ broadcast spreader...what number to
Hello, to solve your question about what number to use to calibrate your broadcast spreader, please use the step-by-step instructions below:
1. If you don't already know the square footage of your lawn, please walk off or measure, multiplying the length by width. For example, my lawn is 100 ft wide by 100 ft long; this equals 10,000 sq. ft.
2. Use this figure (30,000 sq ft) to determine how much fertilizer, insecticide, fungicide,apply etc., to purchase and apply.
3. To calibrate the spreader for applying your product at the correct rate, first weigh and hold out an amount of product to cover a pre-determined test area; for example, enough for a 200 sq ft space.
4. Because most lawn fertilizers are packaged to cover areas in 1000 sq ft increments, it's easy to figure how many 1,000 sq ft applications you need for your lawn.
5. Set your spreader to 3 and measure 1/5 of the recommended application on your product, to cover a 200 sq ft area.
6. Use your spreader to cover this 200 sq ft area.
7. If there is product remaining in the hopper after walking this 200 sq ft area, increase the setting number and move to another test area, repeat steps 5 and 6.
8. If there wasn't enough product to cover the test area, back the number down, move to another test area, and repeat steps 5 and 6, until you finish with product and lawn test area at the same time.
9. Remember to never leave product in your hopper because many chemicals are corrosive and can destroy the moving parts, making the spreader inoperable.
I hope this helps!
Posted on Apr 02, 2011
My scotts rotory spreader will not spin
The design is quite simple with one wheel driving a bevel gear in a gear box. If the wheel turns the axle shaft and the center pin in the spreader with the retainer/cotter pin does not turn it is likely something has failed in the gear box.
If both wheel spins and the axle does not turn than the drive wheel has disengaged the axle shaft and the cotter pin in the drive wheel needs to be replaced.
The compounds used in the spreaders are corrosive. Usually the gears and axle become bound due to corrosion. By oiling the bearings and wiggling the wheels they will free up,
Hope this helps?.
Apr 19, 2013 | Scotts Company 589384 Scotts 5000 SQFT...
Ez republic broadcast setting for expert gardener St Augustine Weed and feed for southern lawns
The bag should have a phone number for customer support. They would be the ones to give you the conversion rate for your spreader. How many square feet are you treating?
www.naturewestinc.com
Mar 04, 2012 | Earthway Ev - N - Spred Model 2050p Estate...
I have a EZ Grow broadcast spreader model 545 that needs a frame leg part number 545-12. The leg broke. I have not tried anything to fix it. Where can I get a new frame leg? I live in Barberton Ohio
I am sorry for the problems you are experiencing with your EZ Spreader. Unfortunately, due to the age of the spreader, we no longer have replacement parts available. Please give Scotts a call at 800-543-8873 so we can help pick out a new spreader for you. Hilary @ Scotts
May 08, 2011 | Garden
Republic EZ broadcast spreader...what number to use when lining up the mark to calibrate the spreader...lost the instruction book
I hope this helps!
Apr 02, 2011 | Garden
As the cyclone brand spreader is "gone" from use, what are the equivalent settings to currently match spreading rates as listed on fertilizer bags for spreaders currently in use.
CYCLONE ROTARY
2.0
EARTHWAY ROTARY
6.0
EV-N-SPREAD
6.0
K-GRO ROTARY
.75
ORTHO ROTARY
.75
PRECISION ROTARY SB50
1.50
RED DEVIL ROTARY
1.50
REPUBLIC EZ ROATRY
.75
SCOTTS SPEEDYGREEN 1000,2000,3000
2.12
SCOTTS BASIC BROADCAST
2.12
SCOTTS EDGEGUARD BROADCAST
2.12
SEARS ROTARY
.75
TRUE TEMPER ROTARY
1.5
VIGORO ROTARY
1.50
SCOTTS STANDARD ROTARY
2.12
CRAFTSMAN
6.0
SCOTT’S EASY GREEN
25
SCOTT’S HANDYGREEN
__________________________________________
Drop Spreaders:
K-GRO DROP
2.25
ORTHO DROP
2.25
REPUBLIC EZ DROP
2.25
SCOTTS ACCUGREEN 1000
3.0
SCOTTS ACCUGREEN 2000
3.0
SCOTTS ACCUGREEN 3000
3.0
SCOTTS DROP PF1, PF2, PF3, PF4
3.0
SEARS DROP 2.25
Apr 29, 2010 | Scotts Company Scott'S& Lawn Pro Spreader...
Wheel and axle broke
If the unit will not broadcast when pushed, try drilling a small hole through the inside of the wheel where the axle enters the wheel and insert a small cotter pin. This worked on mine.
Oct 09, 2009 | Earthway Ev - N - Spread Estate Grade...
Repair parts for a Republic EZ Broadcast Fertilizer Spreader
Sep 06, 2009 | Garden
Lost agitater for my Scotts Spreader
Aug 08, 2009 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
