Question about New Balance N4 Womens Heart Rate Monitor Watch
How to stop the heart rate beep
The monitor constanly beeps is there a way to stop the beep?
How do I turn off the beeping sounds on my watch?
Go into the alarms setting menu. You will have an opportunity to turn of alarms.
Oct 10, 2012 | EKHO E-15 Heart Rate Monitor Watch
How do I turn off beeps on my ekho E-15 watch
Go into the menu, turn off alarms, beeps and chimes.
The battery was flat. renewed it and all working EXCEPT it no longer can pick up heart rate from monitor (tried it with another monitor and still will not pick up heart beat) Help Please...about...
i guess stopped of use your strap for a long period of time. so you need to nicely clean the strap and try a lot of times until it work again.
I happend to me before and the strap worked only after the 10th session on the treadmill
Feb 11, 2011 | Polar FT60 Heart Rate Monitor (Purple)...
I have turned my sound off on my watch and the alarm sound but when I am working out my watch beeps at every heart rate, its annoying I know there is a way to have no sound, I had it that way before but...
Assuming that your limits are set correctly, this is a job for a Polar Authorized service center.
There is most likely a problem with the computer, depending on the age of the watch this will be taken care of under warranty. The link above explains the process.
If you replaced the battery yourself (never recommended) some contaminant could have gotten into the electronics, or the seal is no longer working allowing moisture into the unit. These are highly sensitive electronics and should only be handled through the service centers. The work they do is covered with a warranty and they replace seals and vaccuum pressure the watch to make water tight again, as well as run a diagnostic on the computer.
In the mean time if you don't want to send in you can set the Heart Rate limits - both low and high well above your actual limits and that will stop the beeping, as the beeping while you are working out is an out of limit/ zone alarm.
Nov 19, 2010 | Polar F6 Watch for Women
Sportline S7 HRM watch users guide?
To get a manual for your monitor, go to "sportline.com",
Select "products" and then "see products" in heart rate monitors.
Go through the list of models to find yours and then click on "learn more".
Details of the monitor will be shown and you then click on the tab marked "manual".
Download your manual.
Jan 27, 2010 | Watches
I have a mio euorfit heart monitor watch. During my workout I
Yes, you definetely need battery replacement.
As the hart rate monitoring is most sophisticated part of the device, it has more IC (Integrated Circuits) than any other features.
More IC's means more power is needed, so, if the heart rate monitor is starting to malfunction, that's the very first sign of underpowered battery.
Find your nearest watch repair shop and ask for battery replacement.
Do not forget to rate, please.
Jan 23, 2009 | Mitac Mio Fit Heart Rate Watch
New Balance N4 Womens Heart Rate Monitor Watch Logo
Top New Balance Watches Experts
Ansel Alberto
Ansel Alberto
Are you a New Balance Watch Expert? Answer questions, earn points and help others
