Question about Brother HL-2240D Laser Printer with Duplex Printing
Brother printer ink problem
Black ink is not clear
  • 9 Answers
SOURCE: borther mfc210c black ink not printing even after cleaning
if your brother machine is within warranty, give the tech support a call. if not,replace the black cartridge with a new one. it may be a defective cartridge that you have or if you are using refilled cartridges, it will also give the same problem
Posted on Nov 19, 2008
SOURCE: I installed a new black
You will receive messages like this if you are using remanufactured or compatible items. If the machine will not let you print, you most likely have a defective cartridge. Try to turn the machine off, restart, and do a print test. With low quality recycled cartridges, they sometimes don't have proper chipping (the microchip that tells your printer what the ink level is) and it can cause this error as well. Most of the time you should still be able to print. If restarting the machine doesn't fix the problem, you should be able to contact your cartridge vendor and have them send you a replacement. For Quality remanufactured and compatible items, contact MTek, INC at 866-345-2737 or visit http://www.mteksol.com -customer service
Posted on Feb 12, 2009
  • 127 Answers
SOURCE: Brother printer won't recognize ink cartridge.
I use generic cartridges all the time in my brother printers with no problem. better to pay $2 per cartridge than whatever the brother brand ones cost!
Posted on Jan 05, 2010
raman_jhanje
  • 27 Answers
SOURCE: My printer Brother DCP 165C cannot print in black ink.
Your black printhead is blocked.
The printhead is deep inside the printer and has to be taken out by the expert and cleaned with the help of 'steam' and hot water. This is because not using the printer for a long time. or using low grade refill inks.
Please select new cartridge only if you are inserting a new cartridge or fully refilled cartridge. Otherwise use old cartridge option. Brother printer has a mechanical sensor and not the electronic chip in the ink cartridges.
After inserting the old used cartridge if you choose 'new cart' option it will show the "Full" ink. You can still print from the exhausted ink cart after covering the sensor in the middle by a piece of paper in emergency.
Posted on Mar 05, 2010
  • 1382 Answers
SOURCE: brother MFC-290C not printing black
The nozzle may be blocked. So take out the colour cartridge and place its nozzle in a bit of water for about 10 mins. Bring it out and dab the nozzle with folded paper. If the tissue is blotted with the three colour it means you have unblocked the nozzle. Try now to print after returning the colour cartridge. You may need to repeat to get good results.
Thank you!!
Posted on Jun 25, 2010
Black ink won't work. prints out blank pages.
go to ink mangment scroll down to clean press yeas and do about three that should clear problem
Jun 22, 2011 | Brother MFC-290C Printer
Brother MFC-290C not printing black
Thank you!!
Jun 25, 2010 | Brother MFC 420CN All-In-One InkJet...
I have the Brother MFC440cn printer. Whenever one or two of the color ink cartridges are out, it won't let me print in black ink. Is there a way to bypass this problem without having to buy color ink if I...
Sorry, but no. The machine needs to have fluid in the printhead and ink tubes to keep them from drying out and clogging. And even if you never printed a color page, the machine would use colored ink in its automatic cleaning cycles, shooting it through the print nozzles to blast them clear.
Apr 03, 2010 | Brother MultiFunction Center MFC-440CN...
I have a Brother LC61 series printer. Replaced the ink cartridges when it indicated they needed to be replaced, but now the Black ink will not print. I have tried 2 different cartridges.
Hello Acerilli
Sounds like the print head is either blocked or defective.
Try cleaning the print head first to see if this clears up the lack of black ink.
Press the "menu" button and then scroll down to the "ink" option and press OK
Now scroll down to "cleaning" and select OK.
Select "Black" and press OK then Black Start.
Repeat this process up to a maximum of 5 times.
If this does not clear it up, try a "purge".
Press "menu" "black start" "0 7 6" in sequence as quickly as possible (within 5 seconds)
All the lights should flash and you will see "cleaning_all" on the screen.
Now press 3 and Black start.
If this still does not work and there is no black, the print head is defective and needs to be replaced.
If you are under warranty, you can check here for a service center.
http://www.brother.ca/en/customer_care/service_centers.asp
If there is no service center in your area and you are under warranty, call brother for an exchange.
Mar 25, 2010 | Brother MFC-290C Printer
My Brother MFC-290C printer is displaying "cannot detect black ink" on the screen. I tried to re-install slowly and it is still not detecting the ink.
With the full ink installed you might try plugging in power while you hold the stop key, sometimes the error is just locked and not cleared until you power up this way.
Oct 13, 2009 | Brother MFC-290C Printer
New ink printer says its out of ink
Sometimes you can clear that error by holding the cancel or stop button as you power up. Make sure that all inks are installed properly first though.
Oct 09, 2009 | Brother MFC-425CN Multi-Function Center...
Black ink is not dispensing
There may be an air bubble in the black tubing, it will take several more cleaning cycles to clear. You can tell it to clean only the black and save the other inks.
Jul 01, 2009 | Brother MFC 490cw Color Inkjet...
Printing only in grey
Can you do simple copies in b/w without probs?
If yes, you might have checked the greyscale at the printer settings.
If no, do a quality test print (pressing ink etc.). If you cant read the instructions in black, the ph or circuit board is defectiv.
Dec 05, 2007 | Brother MFC 240C All-In-One InkJet Printer
Brother HL-2240D Laser Printer with Duplex Printing Logo
15 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
