How do i fix my washer
F1 error code on my washer
  • 49 Answers
I think check the air dome transducer hose first, If the hose is OK, then you will need to replace the control board of your washer.
Posted on Apr 25, 2013
SOURCE: Whirlpool Cabrio Washer Error message code F1
I have started a petition to be sent to the CEO of Whirlpool Corp., Jeff Fettit.
Follow the link, and please sign it! The more the better! Spread the word!
You may also copy and post it to any other groups/discussions about this problem.
http://www.petitiononline.com/cabrio08/petition.html
Thank you!!!
Posted on Aug 02, 2008
jgwhomeequip
  • 1902 Answers
Whirlpool did a recall on this problem here is there number try this first. Whirlpool 1-800-253-1301
On a number of ranges this can mean a number of things, the most common being a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using a recent Maytag range it may pay to test the oven sensor as described above as this may cause an F1 error if faulty (may apply to some other ranges as well) this is not a common cause but is worth discounting. To check the ERC and touchpad
  1. Disconnect the power
  2. Gain access to the back of the ERC
  3. Disconnect the ribbon cable that connects the ERC to the touchpad
  4. Check nothing will short when power is reconnected
  5. reconnect the power and switch on
  6. Watch for F1 and listen for the beep
  7. If you get the F1 and the beep this means the fault is with the ERC and it will need replacing
  8. If after 30 mins you do not see the F1 error and hear the beep, replace the touchpad
Posted on Feb 14, 2009
  • 530 Answers
SOURCE: F1 error code on Kenmore Oasis He
I think there might be a recall on your washer call to see. I am not for sure that there is a recall but I a m pretty sure there is. So don't quote me on that. the f1 error code usually means that you have a bad board. f1 means that your pressure switch line is failing and this is all in your board. check your owners manual if whirlpool is not going to pay for this repair sometimes there are extended warranties in your manual
Posted on May 29, 2009
  • 3 Answers
SOURCE: maytag bravos top load washer error code F1
Well, you're not gonna like this, but here's the deal.
Remove the three screws on the rear of the control panel and lift it up. Disconnect the rubber hose on the right side of the gray control module and blow through it to make sure it is clear and not kinked. If this check is fine then your control module needs replaced.
Note that Maytag knows this is a fairly common problem. My washer failed 9 months out of warranty with this problem.
The only good news is that it is an easy, though expensive, replacement.
Posted on Sep 25, 2009
barkencoa
  • 3463 Answers
SOURCE: error codes f1 + f7 on washer
Error code F01 indicates a short circuit motor triac.
Chek all connections on and to the motor, motor plug and control module.
Code F07 indicates heater relay stuck.
Check all connections to and from the heater and control module.
Hope this helps you.
Posted on Jan 05, 2010
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    What is the error mean f1 E1 on my may tag front loader washing machine
    Barbara, F1 E1 error is your washer doesn't think the drain pump is working properly.bad CCU or pump.
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    have E1 and F1 error code fleshing and wate Sears PartsDirect
    http://forum.appliancepartspros.com/washer-repair/443358-f1-e1-error-fault-code.html
    Appliance Repair Forums
    Error code F1E1 null ShopYourWay
    Central Control Unit CCU Maytag MHW6000XW Washer
    Mar 07, 2016 | Washing Machines
    What is F1 failure code on a kenmoore oasis washer
    check your owner manual section troubleshooting for error code very important.
    Normally this error code can be meansL a) pressure out of range.
    or b)eepron error.
    or call the factory and get support online via chat or phone for to fix it.
    God bless you
    Sep 25, 2012 | Kenmore 4.7 cu. ft. High-Efficiency Top...
    What does code F1 mean for a Kenmore Elite Oasis model 27032?
    Here is a link to some good information on your error code. This should explain the error code you have.
    http://www.theworldofwashers.com/2009/03/reader-mail-f1-error-code-on-kenmore.html
    Nov 21, 2010 | Kenmore 27032
    Stopping after start with F1 error
    Hi
    Thanks for using FixYa. Error code F1 indicates primary control failure and to resolve this you'll have to replace the machine control assembly. Yes you are right, this error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please rate the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    Oct 11, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    My washer was supposed to go in to spin cycle and alarmed with I believe F1. Is there anything I can do to fix this problem
    There is a recall for the Cabrio for having the "F1" error(I had mine fixed by whirpool for free). Sounds like you are getting the F1 error code. If you have not had the washer repaired under the warranty program then you should give Whirlpool a call and get it repaired under warranty. When you call them say that you are getting the "F1" error code and have read on the internet that there is a recall. Have your model number,serial number and date of purchase available. They will send someone out to inspect the washer and repair if they have the control board in stock(they had to order mine and it took 2 days for it to arrive). I also located the phone number you will need to call for service...1-800-253-1301
    Jan 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    I keep getting an F1 error code on my top load Whirlpool Cabrio HE washer. I do what the manual says to do which is to hit the Pause/cancel buttom and then start....I continue to get the F1 error code for...
    There is a recall for the Cabrio F1 error code issue. I had mine fixed for free. They will have to replace the control board. You will need to call 1-800-253-1301 and tell them that your Cabrio washer is having the F1 error code and you read on the internet that Whirlpool has been making repairs. Have your model number, serial number, and purchase date ready for the person on the phone. The guy that repaired mine also replaced the washboard at the bottom for free...just ask the tech about it when he is there.
    Dec 07, 2009 | Cars & Trucks
    May 29, 2009 | Kenmore Oasis HE 27082 Top Load Washer
    WASHER HAS F1 ERROR CODE
    the f1 code turned into a f21 code. if you take off the front panel of the washer the manuel is in there it tells you how to reset it by pushing 4secs, releasing 4 secs for three times. To fix the F21 code unscrew the white drain after taking the front panel off and clean the drain. it will be cloged with lint, coins, bobby pins and whatever else can fit in there. LOL 10 minutes and it will be fixed like mine was, hopefully.
    Nov 26, 2008 | Kenmore HE2 Plus Front Load Washer
    Washing Machines Logo
    46 people viewed this question
    Top Washing Machines Experts
