Cisco dpq3925 WHAT IS THE USER NAME AND PASSWORD for this router.
Hollyecho
  • 313 Answers
SOURCE: forgot my user name and password
The default username for the router is admin all lower case. The default password, is blank.
Try this first - if that does not work, you will have to set the router back to factory defaults, then do any setups on it that you had before.
To perform a reset on the Actiontec - Press and hold the reset button on the back of the Gateway for 15 seconds. This will reset the unit back to its factory default settings.
Posted on Mar 29, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: I can't remember my user name and password to my router
You will need to reset the router. On the back of the router hold down the reset button for 30 seconds release the button and then wait for the power light to stop blinking. If it doesnt stop blinking within 1 minute unplug and wait 30 seconds plug back in and the router will be reset
Posted on Feb 15, 2009
kvgopi
  • 73 Answers
SOURCE: user manual for cisco 1800
1800 series is a MSR (Multi Service Router) with that you can build a network with voice,data and enhanced security. In selected models Wireless is also available.
Check the manual in the following link
http://www.cisco.com/en/US/products/ps5853/index.html
Posted on Mar 17, 2009
etaf
  • 779 Answers
SOURCE: i have a U.S. Robotics USRobotics USR5461 Wireless router
heres the online installation manual http://www.usr.com/support/5461/5461-ug/index.html
see configuration tab - You will not be prompted to login the first time you connect to the Web User Interface during the initial setup. During the Setup Wizard procedure, you will be prompted to create a user name and password to log on to the router. If you create a user name and password, you will need to use these whenever you want to log on to the Wireless MAXg Router. The user name and password are case-sensitive.
------------- so if you cannot remember the username and password - you will need to reset to fsactory condition and reset all the settings in the router for it to work with your ISP again
the reset button is on the back - RESET Button: To restore the factory default settings, use a paperclip to press in and hold the RESET button for five to ten seconds. If the RESET button is pressed for less than five seconds, the Wireless MAXg Router will reboot.
Posted on Apr 24, 2010
mpcheeseman1
  • 1400 Answers
SOURCE: can not reset router , netgear wgr614v9 user name
Hello
First unplug router.Then hold reset button in for 30 seconds,button is usually in the back may need a pen tip or paper clip to hold it in.
Then plug back in.Try logging on using admin as username and password as password.
Posted on Nov 02, 2010
How to a change password wifi cisco dpc2320
plug ethernet cable directly between a pc and router and then type in dos prompt ipconfig to find ip address of default gateway if this is the only router. Then note ip addressd it will be most likely 192.168.0.1 or 10.0.0.1 and put this into an internet brower url address box and you should be able to log into the router unless it has a password and user name set . Go may need to google the default user name and password for the router . go into wireless security settings and then you should be able to change the encryption key.
Oct 28, 2014 | Cisco Model DPC2320 DOCSIS 2.0 Wireless...
Tip
Changing Channels on your Routers
You may try to use different channels on the router to get a better signal. Follow the steps below how to change channels on your router:
1. Connect your computer to the router via an Ethernet cable and open your web browser (normally Internet Explorer, which can be found on your desktop or on the Start Menu in Windows XP).
2. Once your browser opens, input http://192.168.1.1 into the "Address bar".
3. You'll be prompted for a User Name and Password. Leave the User Name blank and type in admin as the password.
Cisco Interface (if the setup page has a Cisco Logo)
Go to Wireless Tab
SSID: (e.g. Vic or your name or last name)
Channel: Any from 1-11
Then hit Save Settings.
Regular Linksys Interface (if the setup page has no Cisco Logo)
Under Setup:
Then hit Apply
After doing this you should have a better Wireless signal from your router....
on Jan 08, 2010 | Linksys Wireless-G WRT54G Router
Tip
Changing Channels on your Routers.
Go to Wireless Tab
Under Setup:
Then hit Apply
on Jan 03, 2010 | Linksys Wireless-G WRT54G Router
Cisco user name and password
either admin/admin or admin/password are the defaults.
Dec 30, 2013 | Cisco Linksys E2000 Advanced WirelessN...
DPQ3925 not working with comcast
If they are not providing you any further assistance, then ask for a list of supported Modem/Routers, Return the Cisco, and purchase one that they will help you with.
Tallon41
Sep 16, 2012 | Cisco Computers & Internet
Tip
How to change Wireless Channel on LInksys Routers...
Try to use different channels on a wireless router to get a better signal. Follow the steps below how to change channels on your router:
1.Connect your computer to the router via an Ethernet cable and open your web browser (normally Internet Explorer, which can be found on your desktop or on the Start Menu in Windows XP).
2.Once your browser opens, input http://192.168.1.1 into the "Address bar".
3.You'll be prompted for a User Name and Password. Leave the User Name blank and type in admin as the password.
Go to Wireless Tab
SSID:(e.g. Vic or your name or last name)
Channel:Any from 1-11
Under Setup:
Then hit Apply
Hope this help everyone.
Help!!!!!!!!!!!
Leave the user name blank and enter the password admin ( admin once only ).
Try this.
If that doesn't work then search for the Cisco connect software on your main computer. You might have installed the cisco connect software on your main computer while installing your router.
If it is windows computer then cisco connect software might be under All Programs.
If is a MAC computer then cisco connect might be under Applications.
Open cisco connect software.
Click on router settings. You will see the router name and password. If you click on Advanced settings, it will open the setup page.
If nothing is working then you will need to reset the router and reconfigure it.
Remember once you reset the router, you will need to reconfigure it from the scratch.
Click to see more information about Linksys E1000 cisco connect software
Apr 12, 2012 | Cisco Linksys E1000 WirelessN Broadband...
-where can i find my cisco password? -what is my user name and password?
You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Let me know if you need further assistance. Thanks for using FixYa.
Jul 02, 2011 | Cisco Linksys E1000 WirelessN Broadband...
What is the default enable Password for cisco 7604 - sup720-3b
The default user name and password for Cisco routers and switches is usually:
user name: Cisco password: Cisco
Make sure to capitalize the C's.
Mar 16, 2011 | Cisco 7604 Chas 4-slot 2 SUP720-3B 2 PS
Computers & Internet Logo
143 people viewed this question
David Payne
David Payne
