Question about Kitchen Ranges
Broken knob knobs just spin and dont catch in order to torn burners on
  • 30 Answers
Take the knob off and use a small piece of duct tape. this should create some grip for the burner to turn.
Posted on Apr 25, 2013
  • 22 Answers
SOURCE: All the Burners click when I just turn on 1 knob
The manual tells you this will happen. Just adjust the flame for your intended use and start cooking
Posted on Dec 03, 2007
SOURCE: I have GE Sealed
AH ha, I found one with these guys after a painful online hunt. I hope this helps. it was like $7.57 after the cheapest shipping option. but you can get the part number from the same link and keep hunting. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=214753
Posted on Jul 20, 2008
SOURCE: Range burner will not turn off, the knob is tight and stuck
Not knowing age - very often older (standing pilot) ranges will have burner valves that become hard to operate. These are usually a tapered core valve that can be greased with a high temperature valve grease.
Posted on Jan 28, 2009
  • 10865 Answers
SOURCE: Can't Remove Broken Electric Stove Burner Knob
Spray each of the screws with a little WD40, available at any autoparts store. This will dissolve any rust that may have formed. Leave it over night. Then loosen the screws and the knob will come off.
Posted on May 07, 2009
SOURCE: Burner knobs melt on GE Profile XL44 gas range.
I had the same problem and searched extensively for a solution. They even have a video from GE on the net telling you how to avoid melting them, which is basically don't open to broil and make sure the seal is good on the oven. Essentially, don't use their oven normally like the rest of the ovens in the world. Finally I went to a few show rooms to look for a knob to substitute for the garbage ones from GE. On one of the new models they have a solid cast stainless knob (with a plastic shaft, I think it is delrin) which looks identical but has a longer shaft. I obtained the PN which is WB03T10262 and ordered one. I trimmed the shaft length to match the length of the defective knob with a hack saw, and had to trim out some mold flashing in the cavity. After a couple of fittings I was finshed and it looks fine. I then ordered 3 more from the Appliance Zone for $15.98 each. GE's price for the same part was $25.25!!
Posted on Aug 22, 2010
Cant get knob off to install door lock
Dont have an answer, but have same problem. Any thoughts ?
Jan 05, 2014 | Master Lock BAO0103T Keyed Entry Door...
The knob just spins round and doesn't catch. It received a bash and it now won't accept a wash cycle. Any thoughts?
It seems that the timer has failed and needs a replacement. If this seems to turn around without clicking and if there is no action when the program cycle is initiated, this seems a failure of the timer controller unit. This happens in cases when it is turned around in reverse order or violently.
Jan 14, 2013 | Zanussi Washing Machines
Knob on jenn aire under counter oven fell off. I lined it up and put it back on but it spins 1/8 of the way before it works. It doesn't look broken.
THere is a pin in the middle of the PLASTIC knob that probably broke off. It is not your fault, just cheap construction. Order the part, you have the code!!
Dec 27, 2012 | Jenn-Air Maytag Range Oven Burner Knob...
I have a broken wash cycle timer knob on my whirlpool LTE5243BN0 thin twin washer/dryer. Ordered a replacement part, looks the same as my old one, threads okay, can't seem to screw it all the way on. The...
you might have broken something else off of the timer go here
https://www.repairclinic.com/PartDetail/Timer/WP3946432/4434024
is the white part still on timer shaft?this is the piece that the indicator knob slides onto so it's not loose and free spinning,i looked up your model and the indicator knob is no longer available
www.searspartsdirect.com/model-number/LTE5243BN0/1198/0152000.html?searchType=modelSearch&q=LTE5243BN0&searchTerm=LTE5243BN0
go here and you can see your machine
Oct 01, 2017 | Whirlpool LTE5243D Top Load Stacked...
R rear burner not sparking
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 02, 2010 | Dacor Preference SGM365SS Gas Cooktop
May 07, 2009 | Kitchen Ranges
Program knob on GE washing machine not functioning
The teeth on the knob are gone. You need knob. Pull knob out (on pos.) look down on knob& in see clip push clip off to remove knob. Need screw driver
May 05, 2009 | GE WJSR2070B Top Load Washer
Kenmore Gas Range - 2 knobs don't activate ignitor
there is a switch that is broken behind the knobs they cost no more than $15.00. remove the knob so that you can see it it's white in color.
Dec 10, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Both 6'' & 9'' burners come on however I turn the 6/9 knob.
may be a problem with the switch itself, but honelstly dont take offense but make sure the knobs are on correct knob stem, it squite common for someone tho clean the knobs and not put them on correct valves
Nov 16, 2008 | GE Kitchen Ranges
Burner knob wont turn
appliance repair and yes you can fix it you likely need an infinite switch
Apr 17, 2008 | Cooktops
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
