Question about Electrical Supplies
Leviton 16592 GFCI - Electrical Supplies
2 Suggested Answers
mydogisk
  • 50 Answers
SOURCE: Leviton 8299 Combination Switch / Smart lock GFCI Outlet Leviton-
power coming in from the breaker box: black wire will go to line-hot screw, and the white wire will go to the line-white screw. the switch wires coming out of the back of the gfci- 1 will go to the load-hot screw & the other black wire will wire nut to the black wire going to the light. the white wire going to the light must go to the load-white screw.
Posted on Apr 13, 2009
Wy is my GFCI triping without interference?
You have a short somewhere?
If you have AFCI (arc fault) instead of GFCI, then there is probably a loose wire
Troubleshoot steps on following link:
http://waterheatertimer.org/How-to-wire-GFCI.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 28, 2015 | Leviton 8299 Combination Switch / Smart...
I replaced my gfi outlets with leviton x789k plugs and now none of them work
http://waterheatertimer.org/How-to-add-outlet.html
http://waterheatertimer.org/Basic-house-wiring.html
leviton X789k? Or MX789?
Make sure your incoming Hot and Neutral connect to the wiring module that twist locks onto back of each device.
One strategy for discovering problem is replace the new leviton with ordinary outlet or put the old GFCI back into place and see if circuit is tripped..
Do this for each GFCI outlet and see if each issue is different or maybe the lot of Leviton products is defective.
Gene
Sep 27, 2014 | Electrical Supplies
Electrical gfui reset keeps popping out. Located on patio.Does not lock[n position.
There is a short, or GFCI outlet is bad.
Copy following links for help with GFCI:
http://waterheatertimer.org/pdf/GFCI-outlet-will-not-reset.pdf
May 23, 2012 | Leviton Electrical Supplies
What model Leviton GFCL should I use? My wire is a 600 volt 12/2 with ground. Said wire feeds other GFCL outlets.
Any off-the-shelf GFCI sold today with work on 12-2 wire:
By code, 12-2 wire should be connected to 20 amp circuit breaker, but typically most switches and outlets wired to that circuit are rated 15 amp. Amp rating is printed on electrical devices.
Leviton 15 amp 7599-W:
http://www.amazon.com/Leviton-7599-W-Receptacle-Feed-Through-SmartlockPro/dp/B000VYO9MU/ref=pd_cp_hi_3
Leviton 20 amp 7899-W
http://www.amazon.com/Leviton-7899-W-SmartlockPro-Indicator-Wallplate/dp/B000N663PM/ref=pd_cp_hi_0
Wiring:
Jun 17, 2011 | Leviton R01-7299-0NI Switch And GFCI...
How to connect leviton 5634 from GFI
GFCI device is not identified.
Leviton 5634 is typical double switch.
Open following link for image showing double switch connected to typical GFCI outlet.
Add a comment with details about your wiring and GFCI for more help
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 09, 2011 | Leviton 5634 Dual 1 Pole Switch Decora...
What does the orange light on my Leviton GFCI receptacle mean when the GFCI is not tripped and still has power?
Has indicator always been ON?
Or did it suddenly turn ON recently?
Usually small indicator lights show that device is working, and has power.
Then when GFCI trips, the light goes off.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail or phone while you work on circuit or any do-it-yourself project.
Feb 23, 2011 | Leviton 8599 GFCI Receptacle
My CHI straightener has a GFI plug that needs replaced.
look up leviton 16592 on amazon or something similar. I just had to replace this on a sedu iron. About $20, but cheaper than a new iron.
41x1vrxnoql._sl500_sl135_.jpgtransparent-pixel._v192551059_.gif Leviton 16592
Jan 23, 2011 | Chi Nano Digital Ceramic Flat Iron 1.25...
Screwless GFCI plug plate
You first install the adaptor then "snap" the screwless cover to the adaptor. See link to leviton web site: http://www.leviton.com/OA_HTML/ibcGetAttachment.jsp?cItemId=2gfWNEOgKddmIKzlZrTgaw&label=IBE&appName=IBE&minisite=10026
Jul 11, 2010 | Leviton 8599 GFCI Receptacle
Apr 12, 2009 | Leviton 8299 Combination Switch / Smart...
Electrical Supplies Logo
65 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
