Question about Intel Computers & Internet
I need a manual for power sw, hdd sw ,led sw HP dc7600 Mother Board pn 380356-001 380356
I suggest you go to the INTEL Support website. You should go to this page. https://downloadcenter.intel.com/default.aspx
On that page figure out what Motherboard you have. Use that number to locate the page for that board. Then click on that board.
First you should look for the word 'Documentation" Clicking on that should get you to the Manual for your board. Once you get
that page up look for any reference to the manual for that board.
Download the manual for that board. Most of those manuals are
in .PDF files so you will need to have a pdf reader installed on a
machine you can use. Open the manual in the pdf reader and look for instuctions explaining how and where the cables are laid out on the Board. This set of connections is usually called a "Front Panel".
NOTE: These plugs are often shown with + and - signs. You may have to try turning the plugs 180 degrees once of twice
in order to get them working right. The plugs are usually labeled
as follows. PS = Power Switch, HD LED= Hard drive LED lamp.
RESET = Momentary Contact Reset Switch. (Do not use unless
necessary). and Pwr LED = Lamp that lights up telling you the machine is powerd up and ready to go. I strongly suggest that
you do not "guess" at which pins are which. Look them up. That
manual will explain everything you will need to know. Look at the pictures. that will help you understand the layout. Best Wishes.
Posted on May 10, 2014
  • 198 Answers
SOURCE: i unplug the power led, power sw and HHD led
Gateway's support site should have a nice diagram for you in your manual--they are also quite helpful if you have trouble locating it.
Posted on Apr 05, 2008
  • 357 Answers
SOURCE: ATX-SW Motherboard?
The manufacturer website should have what you need.
You also might need to know what chipset is on the board as well.
If it is the AMD board, go to www.amd.com
I hope this helps.
Good Luck.
Posted on Feb 26, 2009
  • 70 Answers
SOURCE: need help with enachine t2528 wiring power sw wire on mother board
If you open the CPU cabinet you will find the front panel connection pins at opposite right corner to the motherboard IO ports (where we connect all the power,monitor,keyboard,mouse chords) You can easily identify it as below these pins it will be named as P_Sw or P_Bt,Pw_led ,Hdd_led etc
Posted on May 30, 2009
garnedd
  • 31 Answers
SOURCE: need a diagram for the powerswich hdd led reset swich speaker setup on the main board
simple just(google it)on google search engine with the above info you have typed in and you wil get reviews to diagrams,good luck.
Posted on Aug 21, 2009
  • 255 Answers
SOURCE: Power Button wire to mother board power led power
There are may motherboards, but most have writing on them as to what is suppose to plug where. For example, for the power switch, the lettering might be "Pwr" or "Power" or "Pwr sw". The pins are usually together and should fit the plug on the end of the wire.
Posted on Nov 25, 2009
Power sw reset sw power led hdd led where is located in the mother board intel e 210882?
Hi Dear
For the installation the new motherboard in you PC, click here and find the guide book for mother board installation.
God luck
Sep 08, 2011 | Intel Motherboard
Just had to reatach my fan back over the processor but i took the mother board out and my wires came off the mother board which where for the power switch and the reset button, can anyone tell me which...
Hello Sir, hi, the wires on your casing are usually labeled, like in the picture below: cyberdyers_0.jpg
the power led green wire goes to the power led + and the white goes to the - . Now the HDD + goes to the HDD + the red wire, power switch can be interchange, same as the reset switch.
Dec 01, 2010 | Computers & Internet
Configuring motherboard powerswitch leds reset
u will find front pannel connection pins on mother board. its in 2 lines. in onle row there is one pin slot idle. next to that vacant pin slot u insert reset sw, next to it insert hdd led, behind hdd led insert power led, next to power led (behind reset sw) insert power sw. thats it done
Jan 06, 2010 | Dell Dimension 2350 PC Desktop
Power Button wire to mother board power led power sw HDD Led . what pin connects to the three wires from power button. Led Power wire to what pins, HDD Led to what pins and power SW to what pins on the...
Nov 25, 2009 | E-Machines eMachines Desktop PC
How do i plug in power button in on mother board? Lost my manual so I can't find the model #. I was just switching my mother board and all other hardware to new case and my power button (or switch or...
> power led,
Runs to the LED (Light Emitting Diode) labelled "power" on the front of your computer-case
> H.D.D led,
Runs to the front-panel LED that lights-up whenever the Hard Disk Drive is being used.
> reset sw,
Runs to the "reset" button on the front panel.
> speaker
Runs to the internal speaker
> s/b sw
Very briefly touch a metal-tip screwdriver between these 2 pins.
If the computer powers-on, you've found the "power" connector.
Nov 06, 2009 | Intel Motherboard
Need to know where LED wires connect on Foxconn mother board.
You can try going to the following site and download the user manual for the motherboard , which would give you the detailed diagram of which cables to connect where
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=661FX4MR-ES&TypeID=en-us0000001
Thanks
proton
Apr 08, 2009 | Foxconn 661FX4MR-ES Motherboard
NEED POWER SWITCH WIRING FOR A EMACHINE T-3095
check on the motherboard there should be a small prints on it near control panel.
Mar 05, 2009 | E-Machines eMachines T3830 PC Desktop
Motherboard
To download you're manual for the D815EEA2, please click the link below.
ftp://download.intel.com/support/motherboards/desktop/D815EEA2/EA2FV_English.pdf
You need to go to page 85.
7482c11.jpg Starting at Pin 1 (Hard drive LED) is positive + & pin 3 is ground -. Next, Power LED, Pin 2 is + & pin 4 is ground - .
Letter C, is for the reset switch, Pin 5 is + & pin 7 is - .
Power on/off switch, pin 6 is + & pin 8 is - .
The letter I is used for the internal speaker. The positive pin number 16 & ground pin number 10, letter G
Good Luck!
Have more questions? Please feel free to ask.
Mike
Jun 02, 2008 | Intel Desktop Board D815EEA2 Motherboard
I unplug the power led, power sw and HHD led
Apr 05, 2008 | Gateway 3250X Media Center PC Desktop
Computers & Internet Logo
65 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
