I have a rca srs wow hdtv flat screen reading unusable signal how do I fix the problem
2 Suggested Answers
mpaint
  • 36 Answers
SOURCE: 42 inch rca lcd tv says unusable signal
This is a very common problem with these models.
The problem is very likely a fuse that has blown, if the following is true:
No Video on any input BUT HDMI and
No Audio at all.
Purchase a fuse, these are freaking tiny from digitalkey.com or mouser.com F1455ct-nd
Pull the back off of your unit
Pull the cover off of the PCB housing. It is the box that contains the hook ups including the cable tuner.
The silver box that you screw the cable to is where you begin to look for this fuse.
About two inches behind this silver box is some numbers printed on the board 7c32 and partially obscured will be 1c33
Using a big magnifier look next to the numbers listed above, you should see a tiny rectangle fuse with an F on it.
This F fuse is a 500ma fuse that is too small for the load
The fuse listed above will have a G on it. It is a 750ma fuse.
Call the repair shops in your area, tell them that you know the problem, have the part and you want to know how much the bench time and labor will be to repair your unit.
Posted on Jul 23, 2010
Hi, I have an RCA HDTV SRS WOW Model RCA L32WD12YX5, Serial G482CJ060. It powers on and has sound for about 15 minutes then shuts itself off and restarts with no sound. As an experiment, I used the Menu...
The tv main Tuner signal board have problems and the causes.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Jun 09, 2011 | RCA L32WD22 32 in. LCD HDTV
Unusable Signal Message
I can;t keep my DISH satillite to turn on. when I turn the tv on and hook up the cales i get unusable signal and blue screen
May 21, 2010 | RCA TruFlat 27F520T 27" TV
42 RCA TV flashing unusable signal
Ur backlight video board it dead,must replaced.
Dec 05, 2009 | RCA L42WD22 42 in. LCD Television
RCA SRS Wow problems.
my pic has 1 1/2 in on each side that is black
Sep 07, 2009 | Televison & Video
Hi i have a strato lcd26dvb tv but it has no sound, i jus purchased it from john lewis as and ex display, any advice?
I have a hdtv rca 37 inch on my screen it has unuseable signal can you please help me get that off
Jan 22, 2009 | Televison & Video
Unusable signal
it was a fuse in the digital board i took it to an rca repair shop and had it fixed has been working great since
Sep 25, 2008 | RCA L46WD250 46 in. LCD HDTV
Help rca 46inch
I have the same problem using HDMI cable, I was able to get it working using composite or RCA
cables. I still cant get it working on none of the 3 hdmi inputs
May 31, 2008 | RCA L42WD250 42 in. LCD HDTV
RCA L37WD22 not receiving analog
The problem is on the signal board. Same problem and fix for L42wd22, and L46wd22 models.
I can fix this board for a FRACTION of what a repair tech will charge you. Email me at aplusrepairs@triad.rr.com
May 11, 2008 | RCA L37WD12 37 in. LCD HDTV
61" RCA Projection TV, no picture, "unusable signal" message
Read the suggestion of unplugging the TV for at least 4 hours to re-set to factory specs and that took care of it!
Apr 03, 2008 | RCA HD61LPW165 61" Projection HDTV
Rca rear projection model#p52926s
The unuseable signal is a common thing that rcas do when the input rf signal is No good . You could have a bad cable line an bad ant. line or a bad tuner or the set is switched to the wrong anttenna input. No for a Hd compatable componet I always start with 1080i and go from there cause thats what is needed for an hdtv set. Good luck
Apr 21, 2006 | RCA P52926 52" Rear Projection Television
Televison & Video Logo
Top Televison & Video Experts
