Question about Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 5 Hp, 230 Volt 1 Phase, Model - 2340L5
En6f75 ingersol rand compressor wireing diagram
I have a ingersoll rand en6f75 3 phase compressor does anyone have a wireing diagram i dont know where it goes in the star delta starter box done the motor connections but dont know where the presure switch wires go 2 reds 1 earthand the 48 volt solanoid discharge goes 2 reds 1 earth any help from anyone would be good.
  • 52 Answers
SOURCE: Compressor wired wrong from the factory and will not run.
I cannot find any diagram from this description. do you have a model # of motor?
Posted on Mar 10, 2009
compman66
  • 169 Answers
SOURCE: i have a ingersoll rand type-30,model#2475 7.5
from what you are describing it sounds like you are missing a couple wires somewhere or you do not know what you are looking for. The pressure switch, low oil switch motor starter coil, and overload relay should be wired in series to provide a control circuit for the motor starter. I would highly advise seeking the help of a certified electrician if you are not experienced in working with these machines. You can not only risk personal injury, but also damage a lot of expensive electrical item's real quick if it is not done correctly.
Posted on Dec 06, 2009
  • 205 Answers
SOURCE: I believe that the motor
You should not be pulling over 30 amps. If you are you may have low voltage, incorrect wire size or to long of a run for wire size. I would use a hand held meter and check the amps at full load.
Posted on Nov 14, 2010
  • 99 Answers
SOURCE: trying to rewire my ingersoll
Please check out the Web Site Below. It is a Quick Start manual for IR Compressors.
It should have everything you need. It DOES NOT Show you any wiring connections AT the motor.
Hope this helps....Jim
http://www.irtechpubs.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/80445703.PDF
Posted on Feb 19, 2011
SOURCE: Need wiring diagram to wire
3 phase 7.5hp magnetic start wire schematic
Posted on Dec 06, 2011
Whare can i get picture of ingersoll rand type 30 model 234 with serial no 645261
Hi Omran,
The capacity of your compressor is 7.46 if the motor drive is 2 hp. 9.79 if the motor drive is 3 hp.
Hope i can help you.
Sep 13, 2012 | Ingersoll Rand - Rand Type - 30...
Need plug hook up diagram for 220 for Ingersoll Rand 2475N7.5 Type 30 2-Stage Air Compressor
Hi dcrouch537
Found these pictures on another webpage..
This should make your wiring much easier
"A picture is worth a thousand words" Please take time to rate mehunter19_46m_1.jpghunter19_46m_2.jpg
Sep 07, 2011 | Ingersoll Rand Type - 30 Reciprocating Air...
I NEED THE WIRING DIAGRAM TO HOOK-UP AN INGERSOLL-RAND TYPE 30, MODEL V 234 N4, SER. # 30T 37128 I UNDERSTAND THAT IT CAN BE WIRED FOR 110 VOLT OR 220 VOLT POWER.
The wiring diagram is on the outside of the
motor case, on most motors,on the label
Also on the inside of the wiring connection
cover
May 25, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
I have a Ingersoll Rand en6f75 compressor. Does it have to run in a particular direction as I cannot see any direction arrows on it.
We provide tech manuals for all of our products at www.irtechpubs.com. We also supply technical information on our website www.ingersollrandproducts.com. Hope this is helpful.
Ingersoll Rand Employee
May 13, 2011 | Ingersoll Rand - Rand Type - 30...
Trying to rewire my ingersoll rand air compressor motor, psi switch motor starter, need some kind of diagram, it has a 5hp single phase 220
Feb 18, 2011 | Ingersoll Rand - Rand Type - 30...
Need wiring diagram for 'Low Oil Level Switch, part # 32276313.
trying to find diagram for you. LOLS will be wired in series with pressure switch.
Jan 26, 2011 | Ingersoll Rand - Rand Type - 30...
All three of my capacitors blew in my IR T30. I failed to diagram the wiring. There are two start capacitors and one run cap. There are two white and two black wires from the motor. Does anyone know...
Hi, my name is John. Welcome to FixYa. Both of the black wires go to the + side on each capacitors, and the white wires go to the - side of the capacitors. Thanks For choosing FixYa...John
Nov 29, 2010 | Ingersoll Rand - Rand Type - 30...
I have a ingersoll rand type-30,model#2475 7.5 hp,3 phase.need a wire diagram or how do you wire up the low oil and pressure switch? this is a used compressor with wiring still conected, has 3 leads to the...
Dec 04, 2009 | Ingersoll Rand - Rand Type - 30...
Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 5 Hp, 230 Volt 1 Phase, Model - 2340L5 Logo
49 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
