How to fix a p1121 code on a 2002 tundra
P1121 code
How to fix p1121 code in dicor 1.4 l disel
P0120 Throttle/Pedal Position Sensor/Switch A -Circuit Malfunction
P0121 Throttle/Pedal Position Sensor/Switch A -Circuit Range/Performance Problem
P0122 Throttle/Pedal Position Sensor/Switch A -Circuit Low Input
,try changing the throttle pedal switch/mechanism on the floor in the cabin
Aug 05, 2014 | Tata Indica Cars & Trucks
2000 ford ranger p1121 code
Sounds like the computor has gone into limp mode. Have you heard any strange noises coming from under the hood lately ?
Feb 03, 2018 | 2000 Ford Ranger SuperCab
Nissan serena p1121
code p1121 refers to throttle position motor---malfunction===causes--throttle position motor
--- fix--replace the unit.
Dec 30, 2013 | Nissan Nissan Cars & Trucks
P1121 nissan
Hi, code p1121 its about electric throttle control actuator. That why your car engine is not reving,
Jul 19, 2013 | Cars & Trucks
How to fix code p1121
P1121-Throttle Position Sensor Inconsistent with MAF Sensor.
Air leak between MAF and Throttle Body (Ducting)
TPS Sensor
MAF Sensor
Don't throw parts at it. The code doesn't tell you what to do or change.
Look for the easy stuff and learn how to uses a volt meter on the TPS
Aug 31, 2010 | 1999 Ford Explorer
I recieved a DTC P1121 on my 2002 Toyota Camry. What do I need to do to fix it and is it safe to drive in the meantime?
Hi, the DTC P1121 sets when a problem has occurred in the accelerator pedal position sensor. I would recommend you take it to your nearest Toyota dealer.
Aug 26, 2010 | Toyota Camry Cars & Trucks
OBD2 TROUBLE CODE P1121 HOW TO FIX OR WHERE TO START.
P1121 means that the TP (throttle position sensor) does not match what the MAF (mass air flow sensor) reads
the two leading causes for this are the TP or the PCM (powertrain control module)
you will need a professional scan tool to diagnose in detail
Mar 27, 2010 | 2000 Ford Explorer
Where do i find manafacturers fault codes for a fiat stilo 2002 p1121 p1687
Trouble code P1121 means: Throttle Position Sensor A Inconsistent With MAF/MAP Sensor
P1687 Metering Oil Pump Stepping Motor Circuit Malfunction
Sep 01, 2009 | 2006 Fiat X1/9
26 people viewed this question
k24674
jasbo
jasbo
