Question about Symbol PPT 8800 Portable Terminal
Cable pinout serial - Symbol PPT 8800 Portable Terminal
SERIAL CONSOLE PORT PINOUT 8N1
Here is a page that lists a plethora of details concerning 9-Pin Serial Pinouts. I have also included a limited diagram.
docstore mik ua
As for the settings for 8-bit ' None (Parity) ' 1 Stop Bit, that is configured via the comm utility you are using.
Hope this helps.
Jun 27, 2014 | Computers & Internet
My cash drawer in not working
Kindly check the Data cable ( RJ11) if connected properly, connector points turned green. Try Changing it.
hope below links help you
6 pin RJ12 6P6C male connector diagram and applications pinouts RJ12 to rs232
Pinout cable and connector diagrams usb serial rs232 rj45...
Sep 13, 2012 | Partner Tech PT-8800 POS Terminal -...
Pin diagram for psc 8-0065-56 RS232 cable
Hello friend,
Despite seeing his request the RS232 serial cable pinouts 8-0065-56 is old, I wonder if you got the pinout of this cable and could send me, I have a big problem to solve and need this pinout if I could help will be very grateful
Hug john son
Mar 05, 2010 | PSC VS1000 & VS1200 Accessories - P/N...
I need the pinout for the serial cable? RJ45 to DB9
f211598.png This is for a newbridge or alcatel 3624 mainstreet channelbank - do not use the modem side, only use the terminal side - all is needed is Rx, Tx, and ground - if looking from the "window" side of rj45 connector, or pins-side up on rj45 socket.
Aug 03, 2009 | Alcatel Newbridge MainStreet 3612...
Pinout rs232 I want to print directly form handheld falcon 310 using rj45 jack
The pinout for that type of device is most likely in the yost format. It is a standard used with most pos equipment. You can get a diagram here : http://www.lammertbies.nl/comm/cable/yost-serial-rj45.html
Hope this helps
Jay
Jun 29, 2009 | PSC Falcon 310 Portable Terminal
NewBridge 3600 Mainstreet
Hello
The pinout is determined by the serial port you are plugged into. Are you using serial port 1 or 2. This is pinout from a standard DB9 PC serial port should get you into SP1.
Blue-8
Orange-7
Black-2
Red-3
Green-5
Yellow-4
Brown-6
White-No Connect
Write back and let me know - BAD421
Aug 01, 2008 | Alcatel Newbridge MainStreet 3600...
Need pinout for octopus cable
Try http://www.bobdbob.com/~protius/pinouts/
Jun 04, 2007 | Addonics FlexPort 42 (AEFLEX42) Parallel /...
E200 Serial Port URGENT
You will not find any matching connector to connect the JK-744 host adapter for attaching to the 9 pin serial port on the pc. If you want full pinout details please contact me directly. Please do include some information on what you are trying to achieve. Maybe I can be of help in that department. I however have a feeling that trying any micro surgery on the JK-744 or trying any kind of non Casio adapter is likely to mess up the JK-744 device itself.
Sep 05, 2005 | Casio Cassiopeia E-200 Pocket PC
Symbol PPT 8800 Portable Terminal Logo
135 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
