Question about Ryobi Multi-Volt Battery Charger
RYOBI P117 CHARGER
I just unplugged my ryobi p117 charger + and plugged it back in and it will not power up.I tried to open it up but i do not haver a tool for the screws under the rubber feet. Is there a reset button or fuse somewhere and how do you get the screws out
SOURCE: What is the replacement fuse for a Ryobi 18v charger?
The fuse in mine said 4 amp. I have also used. You can use a 4 amp or lower to replace the original one that blew.
Good Luck
Posted on Mar 22, 2009
  • 672 Answers
SOURCE: NEED A MANUAL FOR A RYOBI BATTERY CHARGER
This link should help in finding a manual. Good luck. http://powertool.manualsonline.com/manuals/mfg/ryobi/ryobi_battery_charger_product_list.html
Posted on Jul 04, 2009
centurion_BB
  • 83 Answers
SOURCE: Can I leave my Ryobi P113 charger with a P103
Yes you can that is an automatic charger when it is fully charged it shuts down the charging portion but keeps the charged light lit however this does not effect the battery.
Posted on Aug 13, 2009
  • 13 Answers
SOURCE: Green & Yellow light on 14.4V charger
It sounds like your battery is bad.
If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
Posted on Nov 24, 2009
HomePlicity
  • 41 Answers
SOURCE: Does it harm a Ryobi 18v lithium battery to leave on Charger?
Lithium-Ion batteries require careful charging and temperature monitoring while in the charger. Ryobi's Charging station monitors many functions and shuts off when the battery has gone through a complete charge. This is indicated by a steady Green light. Once the Charge indicator is a steady green the charger stops charging. With any battery It will slowly discharge and I don’t think the Ryobi will maintain a battery that is never removed. For example, if after a complete charge cycle if the battery was left there for 2 years and then you went to use it, it would likely be completely discharged. However if the battery charger is unplugged then plugged back in a new charge sequence would start. I lose power at my house about every 6 months or so. Once power is restored a new cycle would start and the charging cycle begins again.
Hope this helps and have a great day.
Posted on Apr 01, 2010
Testimonial: "This is the best answer I received! Thanks!"
Ryobi p117 charger not charging batteries
  • Defective charger
  • Defective batteries
Mar 24, 2018 | Ryobi Drills
Ryobi P117 charger power LED flashes when plugged in with no battery inserted. Is there an easy place to start checking?
There are replaceable parts for this unit. It may cost more to to Ryobi and back plus parts and labor.
Mar 13, 2018 | Ryobi Drills
How to replace it,the fuse
Hi P117 charger green ::::: fuse is inside remove 4 screws on back, Cheers
Nov 27, 2016 | Ryobi Drills
Ryobi charger 18v lithium ion P117
check if battery is good
check if bulb not busted
Feb 04, 2016 | Ryobi Drills
Lights will not light on ryobi battery charger/cannot charge fairly new battery
Bad contact on battery use multymeter to check if voltage is there if not open the battery pack and see if bad connection exists or try another battery
Dec 25, 2017 | Ryobi Multi-Volt Battery Charger
Will the P110 charger charge a lithium ion battery
No, the P110, 18V NiCad battery charger, will not charge a 18V lithium ion battery. You need one of the dual-chemistry chargers. If you have the Ryobi ONE+ batteries, you can get the P117 charger ($30) or a charger with an extra battery (P126) from a store like Home Depot. A 6 battery charger and a 12V in-car charger are also available.
I wish that I had better news for you.
(who has the Ryobi 12V drill and charger, a few of the 4V tools, and a number of the ONE+ 18V devices and chargers. The single chemistry battery charger is not used much any more.)
Nov 24, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
I purchased a brand new P113 Ryobi charger about 2 years ago. It has never worked. If I put a P104 battery in for a charge, it looks like it works correctly. I push the battery tester on the battery...
If you have your receipt, check with Ryobi to see if it is still under warranty. It comes with either a 2 or 3 year warranty, depending on when it was purchased. If it is still covered, get it replaced/repaired. If it is not, buy the P117 charger. $30 at Home Depot. It has a 90 day satisfaction guarantee. If it charges your batteries properly, you're good. If not, bring it back if you don't like/want it. My P113 won't get out of test mode now, or charge Lithium batteries anymore. So I bought the P117 yesterday. Works great, and it's a lot cheaper than new batteries! And it has a 3 year warranty.
Aug 28, 2012 | Ryobi P113 18 Volt One Charger 140501001
Ryobi Multi-Volt Battery Charger Logo
1,631 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
