Question about Ryobi Garden
Manual for Ryobi Grass Scorpion Line Trimmer
I have opened the petrol lines from the line trimmer and dont know which goes where
KINDLY HELP
My ryobi scorpion only has twofuel lines but two on primer can you help
Posted on Aug 21, 2009
The top line is the return to the gas tank. The bottom one is the gas in line.
Posted on Apr 12, 2014
How to change nylon on my Scorpion Stinger line trimmer.
ryobi site with user manual download dont say scorpion
just the engine size .. and they want money for them
http://lawnandgarden.manualsonline.com/manuals/mfg/ryobi/ryobi_trimmer_product_list.html
the trimmer head looks like a button type
when apart should have a hole for the trimmer line
to be held in place in the middle of the length
so two lengths are there for winding
should be an arrow showing wind on rotation
and two holes feed out for the cutting line
if you wanted to get away form that button type head you can now buy universal cutting heads suits that ryobi from mower shops .ebay . bunnings
with much simpler line fitments
26324907-v2dqkn1y3jbmwvzbgpmxj0lw-3-0.jpg26324907-v2dqkn1y3jbmwvzbgpmxj0lw-3-2.jpg26324907-v2dqkn1y3jbmwvzbgpmxj0lw-3-3.jpg
Oct 24, 2016 | Garden
Ryobi Grass Scorpion Petrol lines from tank to primer to carby where to where
Thanks to doityourself.com.
The line off the top of the primer bulb goes to the top of the carburetor.
The line on the bottom of the primer bulb goes to the fitting on the center of the fuel tank and the line off the side of the fuel tank goes to the bottom of the carburetor.
Regards,
Worldvet
Oct 28, 2008 | Ryobi 15" Electric Factory Reconditioned...
Where can i buy a new complete line trimmer assembly for a Ryobi grass scorpion RTC2500 trimmer?
Hi Gary,
You may already have found what you are looking for but if not, here's a site that will help:
http://www.ereplacementparts.com/ryobi-trimmer-parts-c-7931_15633.html
Good Luck!
Jim
Feb 09, 2016 | Ryobi Garden
How do i get trimmer line holder cap off my electric ryobi trimmer rlt 1038
Hi, I wished I had read this before I bought my rlt1038, I used it for
8 mins and 1) long grass caought around the drive head, 2) I tried to undo the screw holding the line head. Fortunately I have a wide pair of foot prints to go across the line head and a central heating pump adjustable spanner- after 5 mins I had undone it. Yet another bad design !
Good Luck
Mar 16, 2013 | Ryobi 15" Electric Factory Reconditioned...
How do I use the B & D edger and trimmer
This is for a MCCULLOCH TRIMMAC 210, 21CC (petrol/gas Line Trimmer).
http://safemanuals.com/user-guide-instructions-owner-manual/MCCULLOCH/TRIMMAC%20210-%2021CC-_E
Operation of this and other Line Trimmers are all the same with some exceptions with optional attachments.
Aug 31, 2009 | Black & Decker 14" Grass Hog Xp...
Fuel line positions ?
The longest fuel line, which has the filter attached to it, goes to the brass fitting furthest from the primer bulb. The short fuel line goes directly under the primer bulb. Which hole to put it in doesn't matter if the lines are the same size. Just choose the shortest path for each. However, if the lines are different sizes, then the longest line (smallest in diameter), goes in the smallest hole of the tank.
Jim
May 25, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi line cutter - petrol lines all broken
Petrol lines disintegrate when fuel is stored in the trimmer for long periods of time. These can be obtained from any small tool repair store. Just remove them and install new ones. They just slip through the holes in the tank, re-attach the fuel filter on the supply line. Make sure that the line is long enough so that the filter rests on the back/bottom corner of the tank. Be sure that the lines are attached to the proper ports on the carb>
Dec 22, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi rlt30ces trimmer
Hi there, takes a bit of working out without a manual, but try this....take bottom half of trimmer line spool off, get piece of spool line approx 60 cm, long and thread through centre holes, ( bit fiddly but ) pull line through until you have equal length on both sides, dont try and wind it up onto the spool, just put ends of line through outside cover holes, then lock spool in place in other half. now simply wind the knob at the end and the line should retract into the spool., sounds complicated but really isnt, best regards and good luck, Philbee
Oct 24, 2008 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
How do I connect the fuel lines on the Ryobi 31cc petrol edge trimmer.
I have a Ryobi 31cc 17inch cut with gas line problems and this answered my questions. Thank You
R Green
Oct 18, 2008 | Garden
Garden Logo
4,932 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
