Goldline Controls Goldline GVA-24 - Valve Actuator, 24v Logo
A
Anonymous Posted on Apr 24, 2013
Goldline GVA-24 valve actuator is leaking
A GVA-24 valve actuator set on a pool solar system is leaking when it turns. A pool man told me the problem could be solved by replacing an o-ring (or two). A set of o-rings cost about 500 ILS which is approximatelly 130US$ while a full replacement of the gva-24 unit will cost ...145US$! Is there a less expensive way to get it work?
Why won't the main water supply knob turn to allow water to the water heater
Shut off unit then turn off water to house at water main out side. Drain water heater remove old valve install new
Leaking relief valve on solar panel
I had to replace mine a few years ago. Just look on line. Search for pressure relief valve, or add solar. You will get a lot of responses. Comparison shop and buy. On line auctions work well also.
Heat pump i dont know the model
The "R" terminal on the back of the stat should be 24 volt supply to the stat. For a heat pump, when the stat calls for heat, the "W" terminal goes hot (24 V) and should actuate the reversing valve and start the outside unit for heat. when the stat calls for cooling, The "Y" terminal goes hot and starts the outside unit without the reversing valve. The heat strip is used to temper the air while the outside coil is defrosting when in heating. You need an OHM meter to test for a short in the heat strip. A lot of installers are wiring it to heat all the time when in the heating mode if the heat output is too low on really cold days. Try jumping "R" to "Y" and the outside unit should start. Disconnect the heat strip from power while testing. This is really brief, its a big subject. Good luck.
Excess Hit Water Bill from Solar/electric Hot Water System
10-30-12
Cost calculations for recirculation system vary widely.
These systems cost more, and they cause higher operation cost of water heater.
1) When pump is OFF, then hot water is no longer leaving the tank.
Most recirculation systems have choice of timer for setting specific times of operation, or thermostatic operation that activates pump when sensor detects temperature less than 90 degrees
BUT...
2) Condition of plumbing is suspect here because you are not receiving fully 90 degree hot water from the recirculation system.?.
Bad single-handle faucet cartridge, or bad recirculation check valve, are causes of crossover. Clean recirculation check valve with white vinegar. Replace worn faucet cartridge.
Test for crossover.
http://waterheatertimer.org/Crossover.html
3) There are other suspects, such as water leak.
Drips, broken pipe, bad TP valve.
Turn off all taps and put ear against pipe to listen for running water.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#listen
4) High costs: Lifting single-handle faucet in middle will immediately cause cold water to enter tank. Even if no hot arrives at tap, because the cartridge is drawing both hot and cold in equal amounts when handle is lifted in middle.
Today it is more efficient to install dual-handle faucets so tank is not receiving constant dose of cold water when single-handle faucet is not used correctly or tediously.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
We just bought a house with an AquaStar II solar pool heater, when we try to adjust the temperature we get a flashing check sensor error. Can anybody help us find the sensors or how to fix it?
On the Goldline controllers, the check sensor light flashing means the sensor on the roof is either bad, disconnected or shorted out. When the check sensor light is solid on, that indicates it is the pool sensor. Check the wiring from the controller to the sensor on the roof. If the wiring is not damaged, most likely you will need to replace the sensor. You can check the sensor with an ohmeter, it should register 10,000 ohms at 77 degrees.
Has Leaking noise very audible on hotwater line but no flood in the house or outside the house, and the water meter records unusually high. Three certified plumbers checked the house but could not find...
First, find out if you have a leak.
Turn off all water faucets inside and outside.
Record water meter register with camera.
Wait several hours.
Record water meter register again, and compare photos.
If you have a leak, contact city water department and report leak so bill can possibly be adjusted.
Ask city water department what they suggest.
If you had certified plumbers look at problem, it would be a guessing game for internet plumber to start listing things.
My guess would be crossover on single-handled faucet that runs the hot water into cold pipe that is filling the swimming pool that is leaking. But you might not have a swimming pool.
Another guess would be a leaking TP valve that drains directly into a sewer vent line.
But certainly the plumber checked the TP valve.
http://waterheatertimer.org/How-to-replace-TP-valve.html
Add a comment and say how the problem was solved.
Low Water Pressure Gas System but High Pressure when Solar Water
if you have a gate valve on the unit from the hot water tank it could be as simple as the valve on the gas system being clogged going to that bathroom,, from how it is described it sounds like that would be the problem check to make sure all valve are not stuck in the on position ans change the valve if it is frozen in place
1helpful
I have a raypak heater with robertshaw 7000 gas
Remove the wires from the gas valve and call for it to light. While it is trying to light, take a voltage reading on the wires that go to the valve. If it is sending voltage to the valve and it won't energize the valve then the valve is defective. Just make sure that the valve is being told to come on. It could just be a limit switch. Double check the manual reset limits also before doing the vavle check. Hope this helps.
Top Goldline Controls Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Goldline Controls Water Heater Expert? Answer questions, earn points and help others
