Question about Jenn-Air Ovens
Replace control board jenn-air ww30110w - Jenn-Air Ovens
4 Suggested Answers
  • 508 Answers
SOURCE: jenn-air sce30600 just replaced membrane offswitch
sounds like more than switch issue probably main circuit board!!!! :) have you tried jenn aire support?
Posted on Jul 07, 2009
Daniel S
  • 4323 Answers
SOURCE: jenn-air sve47600w, clock control board
Hi
If you have connected correctly and the ribbon cable is also fine then it seems that the touch pad is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on May 30, 2011
mc1bean
  • 3053 Answers
SOURCE: Jenn air /maytag JJW8130DDB control
Hello, Dadt
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and farther back, It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your oven, from repair to trouble shooting it. Even pictures and video's. Just scroll around and you will see tons of information to almost any question you might have on your Oven. If you go to this link and click around, I am sure you will find out so much about your oven, you will know more than the company that made it. The good thing about this link is, then you can make the decision of DIY or hiring a pro. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
I get an F5 code. I have replaced the ERC, what next?
it seems like you have a bad control board. we can help you with that if you want to send it to us.
Dec 20, 2015 | Jenn-Air Ovens
Jenn-air oven error code 4d22
Hi. Erorr 4d22 indicates that the control board isn't seeing the fan speed signal from the fan on that oven. It's the lower oven, right?
Check the connection to the Fan and Control board, and if that's not it replace the fan.
HTH.
Jul 25, 2011 | Jenn-Air Electric Double Oven
F1E1 error happened repeatedly, jenn air says cut
F1 - E1
EEPROM checksum error
1.
Disconnect power for at least 30 seconds.
2. Re-apply power and observe for
at least one minute.
3. If code re-appears, replace control board (also
called ERC or clock).
Note: Applies to all F1-E...
codes except F1-E3.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Jenn
Air Range / Stove / Oven Fault Codes#ixzz19GMNtS3r
Dec 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
What does F1 mean on my oven
F1 code for Jenn Air is related to the main electronic control board. If you can turn your breaker off for a few minutes then back on it may reset. If not you will most likely need a new control board. Depending on your model number and age there may be extended warranty on the parts, check with Jenn Air to be sure
Apr 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn Air oven keeps beeping F2 and the upper oven broiler won't shut off. We do not have a manual. Please help!!! Briezee85@netscape.net (925) 672-1279
Sounds like a welded relay on the control board. You can replace the board or have the board repaired for much less expense.
Feb 20, 2010 | Jenn-Air JJW8230D Electric Double Oven
My oven was beeping with a code of FO. Do you know what that means? It's a jenn air oven.
HI. This code will appear when one, or more of the function keys on your unit has failed. If your control board has the key pad integrated into the main board(combination design), simply replace the entire control board. If the unit has a separate control board, that is not combined with the key pad, simply replace the key pad.
Nov 27, 2009 | Jenn-Air Ovens
Jenn-air sce30600 just replaced membrane offswitch
Jul 07, 2009 | Ovens
Jenn air oven
More then likely your electronic clock control board is going bad. After turning the power off, you can also try cleaning the connectors on the clock board and make sure the connectors are tight.
Mar 23, 2009 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air coolimg fan problem
Good Morning!
What youre experiencing could be a result of a faulty oven temperature sensor, a faulty oven control board or relay board. Youre more than welcome to send both the main control board and relay board for evaluation. Fixyourboard will test and repair both as needed for less expensive than buying new, and include a two year warranty.
5700M662 60 Jenn Air OVEN CONTROL BOARD
May 15, 2017 | Jenn-Air JJW8230D Electric Double Oven
Ovens Logo
37 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
