Question about HP Compaq dc5700 Microtower - Free Flat Panel until 113007 EW287AV-KIM PC Desktop
  • 51 Answers
Get an external USB DVD drive and connect it that way
Posted on Mar 13, 2009
Add floppy drive
What model Lenovo ??...
Because PC makers no longer include floppy drives in computers, many new PC users have never used one.
Nevertheless, there are many occasions when a floppy drive can be the most convenient form of file storage and transfer for small files.
On most Lenovo ThinkCentre PCs, a floppy drive is an add-on option and most packages do not include the device unless you specifically request it.
If you purchased a ThinkCentre PC without a floppy drive, you can add one to the system yourself and save some money vs. taking the system to a shop.
Shut down the ThinkCentre computer.
Disconnect the AC power cord and other peripherals.
Move the computer to a sturdy work surface.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Use your fingers to push inward on the two buttons on either side of the computer.
Lift upward on the front edge of the cover to open it.
Open the cover until it stands at a 90-degree angle to the computer chassis.
Disconnect the ribbon cable from the optical drive.
Lift up on the rear edge of the drive bay tray until you can see the rear of the CD/DVD drive.
Orient the new floppy drive so that the diskette slot faces down.
Connect the floppy drive cable to the motherboard.
Slide the floppy drive part way into the floppy drive slot.
While holding the floppy drive, connect the other end of the cable to the diskette drive.
Lock the ZIF connector on the cable, then slide the drive all the way into the slot.
Slide the blue drive lock downward to secure the floppy drive in the slot tray.
Close the cover and reconnect all cables.
Power on the computer.
The ThinkCentre BIOS detects the new floppy drive automatically and configures it as the "A:\" drive on your computer.
Lenovo support
Sep 13, 2013 | Lenovo Computers & Internet
I have a GF615M-P33V2 - how can I get Windows Server 2003 drivers and software? Also, IDE CD/DVD only work intermittently. Is there any way I can connect a CD, DVD and a floppy. I've already an IDE HD...
Hi, the download site is here:
But there is no drivers for windows 2003.
The 32 bit driver for windows xp will sometimes work
if it is a 32 bit system.
You can buy an external floppy drive and a cd/dvd drive to
connect the usb.
But the mainboard has a connector for the floppy drive.
Try to install the chipset drivers first and unzip the file before installation.
Consider to buy a mainboard compatible with windows server 2003
I will recomend a ASUS mainboard.
Sep 17, 2011 | MSI GF615M-P31 AM3 NVIDIA GeForce 6150SE &...
Disc slot
If you are speaking of a 3.5 floppy, you won't find one on the newer systems. 3.5 Floppys are out of date and are rarely put into new sytems. If you have data that you would like to retrieve from some old floppy disks, you will need to go to a computer store ie: Bestbuy or CompUSA and get an external USB Floppy drive. Then you can save them to your hard drive and then burn them to a CD or DVD.
Hope this helps you.
Apr 08, 2010 | E-Machines eMachines Desktop PC
How do I turn one slot # 1 of T5048
Please describe in detail what slot it is that you want to turn on so that I can help you with your problem.
Jan 27, 2010 | E-Machines T5048 (7136) PC Desktop
Where do you insert a disk in a laptop
Check in right side of laptop .
You find i small button press it so you cna ejct it.
Also you can find with my computer .
open my computer thne right clcik on your cd drive icon then click on EJECT so your disk drive is eject.
Put your disk there.
Let me know if you need more assistanse.
Aug 27, 2009 | Acer Aspire 5500 5570-2609 Laptop
Jumper setting
you can keep master either hard disk or rom not both. there must be one slave and one master for one ide slot
Jun 12, 2009 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
Floppy is stuck in slot
The most comprehensive information that I have found is located at
Floppy diskette stuck in floppy drive
If the above does not work then you will need to replace the floppy drive and take apart the old floppy drive to remove the disk.
May 11, 2009 | Computers & Internet
Drive does not opens even when the button is pressed number of times.
One of the things that I have noticed about these drives have been the complications that will be experienced with the tray motor assembly. Often the gears on the tray that connect to the motor become worn from jamming and use. Another problem that takes place is that the tray never returns to the proper position once the disk is inserted.
I would like to know the age of the drive since the MTBF is only 70000poh
Feb 27, 2008 | Sony (CRX320E-10) CD-RW/DVD-ROM (Combo)...
Ibm t30
The T30 comes with ‘One, integrated, easy-loading modular Ultrabay(TM) 2000 Plus.’
You should be able to buy a DVDR Ultrabay™ 2000 Plus drive that will replace the floppy drive.
For example:
Dec 03, 2007 | IBM ThinkPad T30 2366 Notebook
HP Compaq dc5700 Microtower - Free Flat Panel until 113007 EW287AV-KIM PC Desktop Logo
29 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
