Question about Ariens Garden
Battery cables hooked up backwards on ariens model 927041
Cables hooked up backwards for about 10 sec., some smoke came out from under the housing. Re hooked up the battery cables the proper way and no power at the key. NO obvious signs of any wires burnt. This is on a Ariens ride on mower, model 927041. It has a 12.5 I/C Briggs&Stratton, model 289707 type 0115.01, code 93030144.
Thanks, Andy
  • 70 Answers
You may have blown a fuse. Follow the wires from the ignition to the battery and look for the fuse housing also from the starter to the battery. There may be more than one fuse so look good. If all your fuses are ok then it's possible you may have fouled the battery in which case it's time for a new one.
I'm a little worried that the smoke you saw was coming from the starter moter in which case you may need to replace but there should be fuse to protect it so let's not worry about that yet.
Hope you get it running but if not post back and we will figure it out
Sean
Posted on Mar 14, 2009
When I put batteries in and turned it on, it started smoking and a wire heated up very quickly. Is there anyway this one candle can be replaced because it is a manufacturing flaw?
Search Results
    Smoking battery and wires HELP - Moderated Discussion Areas ...
    continuouswave.com/ubb/Forum6/HTML/001938.html
    Jun 13, 2008 - 10 posts - ‎5 authors
    The motor started to turn BUT the battery began to smoke , the wires ... Set the dial on the continuity function and put the leads on each of your battery cables. ... Thebatteries and cables are not reported to heat up when first connected. ... button verybriefly and get ready to pull the pos cable quickly in case ...
    Smoking Battery Cables - Moderated Discussion Areas - Continuous Wave
    continuouswave.com/ubb/Forum6/HTML/001003.html
    Jul 19, 2006 - 24 posts - ‎9 authors
    Are the terminals on battery cables supposed to be hot? ... amounts of resistance cause significant heating, which is why battery cables need .... Yesterday I went out and hooked up the new battery, turned the key and got absolutely nothing. ... Good thing I had the cowling off because a wire started smoking.
    Why did my Jumper Cables burn in half after attempting a jump
Jan 18, 2016 | Cars & Trucks
I have a 98 isuzu rodeo and my friend hooked up the jumper cables wrong one day and now none of my dash lights or any of the switches on my dash work (4x4, cruise control, etc.) and it's stuck in 4x4
What can be damaged by hooking jumper cables up the wrong way ...
https://answers.yahoo.com/question/index?qid..
May 3, 2011 - My car battery was dead so we asked someone for a jump and when we tried starting the car, the negative jumper cable on my car started ... what happens when you hook up car battery cables wrong?
Apr 12, 2013
Hooked jumper cables up wrong and radio won't work, why?
May 26, 2010
Hooked up jumper cables backwards now my car wont start no ...
Apr 2, 2009
What happens if you hook up jumper cables backwards on a car ...
Oct 4, 2008
More results from answers.yahoo.com
Do not connect your jumper cables backwards or bad bad ...
https://www.reddit.com/.../do_not_connect_your_jumper_cables_...
RedditOct 25, 2012 - Do not connect your jumper cables backwards or bad bad things ...What I'm trying to say is, does this usually happen when you hook the cables upwrong? ... So basically there is only one way to find out for sure what going to .
Oct 16, 2015 | Isuzu Cars & Trucks
John deere lawn tractor. Had a dead battery. my son tried to jump it but cables got hooked up backwards, cranked 10 sec. Now turns over but wont start and smokes under the flywheel
Because he shorted out the alternator under the flywheel. There also maybe other damage as these are not protected from reversed voltage.
Apr 30, 2015 | John Deere Garden
Saturn jumper cables hooked up backwards
Try charging the battery more. Even though your lights may come one, starting a vehicle requires massive amounts of amperage from the batter. It's possible that your jumper cables aren't a thick enough guage to supply enough power as well. Sometimes the vehicle you're jumping from might not have enough power to support your vehicle's starting power requirements.
Apr 15, 2014 | 2001 Saturn SL
Main fuse location
kim do not when hook up the battery or even jumper cables backwards it most likely cooked your brain if all it did was pop a fuse you would be very lucky go to a locale car auto shop they could give you a hand
Dec 26, 2012 | 1999 Dodge Durango
I'm trying to install a new battery in my 1984 Nissan Sentra. When I hook up the terminals, the wiring starts to smoke leading me to believe that the hook up is backwards. What is the correct hook up for...
Hi and welcome to FixYa, I am Kelly (Electrician since late 1960's)
Ground goes to the - pole. Hooking it up backwards can damage your alternator, wiring harnesses and fuse links. (Fuse link damage is a nightmare to sort out!) What you do by hooking up a battery backwards is turn your vehicle wiring harness into a giant heating element. (<-Very bad!) If you just changed the battery and then you hooked up the cables with the smoking cable result you certainly did connect the cables backwards. The ground cable... will connect to chassis and in most cases the engine body / transmission somewhere.
The positive cable will eventually connect to the starter. Follow the ground lead from the battery to the chassis or engine body connection. (metal to metal contact) Once your sure that is the ground cable; connect it to the - post of the battery AFTER connecting the positive post terminal.
If you have a newer audio system you will have lost your radio codes. We can not provide the codes for anti-theft reasons. Activation Codes must be from the car dealer or audio system retailer.
Thanks for choosing FixYa,
Kelly
Feb 27, 2011 | Nissan Sentra Cars & Trucks
I bosst my baterry due to dead pawer,sudenly it
Did you determine the cause of your battery going dead in the first place? Did you hook the cables to your battery correctly? What is happening in your car now?
Several things might have happened. I can only speculate from the limited information you gave. You could have had a short under the dash which caused the battery to discharge in the first place. You could have hooked the booster cables up backwards. If you will post additional comments, I will try to help you further. Out of curiousity, have you recently installed a new stereo system or amplifier?
Feb 02, 2010 | Pontiac Vibe Cars & Trucks
Hooked a battery up backwards because the cables were backwards and i just trusted the colors.. was hooked up for a few seconds. saw white smoke come out of a small box that reads.. (Brown 0.3 | Red 0.7 |...
if it's the box near the battery that would be a fuse panel. under it will be a main fuse that if you are lucky is blown. replace it and it should work fine.
please take a moment to rate this solution thanks
robert
Oct 29, 2009 | 1987 Isuzu I-Mark
Older model Ariens ride around lawn mower - drive belt slips off
it could be the belt has streched
check tensioner if has one and check all nuts and bolts tight
Jun 21, 2009 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
883 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
Are you an Ariens Garden Expert? Answer questions, earn points and help others
